Author Topic: favorite utility (Stanley) knife?  (Read 12444 times)
Offline Packard
Re: favorite utility (Stanley) knife?
« Reply #30 on: February 22, 2021, 08:23 AM »
Milwaukee Fastback for me.  It's replaced my pocketknife, in fact.
Is that the same as "Olfa"?  Olfa is my favorite.  They make several types, the ones with a thumbwheel lock are the most durable.
Offline Imemiter
« Reply #31 on: February 22, 2021, 03:13 PM »
I love this thread. Several interesting knives I've never heard of.
For the last six or seven years my favorite has been this safety orange Techni-Edge Swift Switch. It has my preferred bent handle and a more solid blade purchase than most of the non-retracting knives I've had. The black spring-loaded block pivots off the back allowing the two halves to separate for tool-less swift blade switches. There's space for ten extra blades, and the blade retainer is held in place by a magnet so it doesn't fall out during swift switching. The magnet also snicks the new blade in place until the two halves can be swiftly reassembled.
These were on display at the board store and came with the same plastic sheath Occidental now includes for sharps with their toolbelts. initially, the sheath caught my eye more than the knife. But after a week of use, and intuiting that like so many good ideas it was doomed to be discontinued, I went back and got another for a spare. Pictured is the first one.
In 2018 Stanley bought Techni-Edge and from the look of things, drowned them in the bathtub. They were too swift to live.
CT-SYS, CT-Midi, HKC55, OSC18, PSC420, OF1010, OF1400, MFK700, ETS125, DTS400, ETS EC150, RAS115, RTSC, CT26, CT VA, T18+3, TID18, CSX, DF700
Offline harry_
« Reply #32 on: May 08, 2021, 07:31 PM »
« Reply #33 on: May 08, 2021, 09:44 PM »
It’s nice to be able to change blades quickly but sometimes you want the most rigid blade possible and that kind of knife has to be screwed tight. My favorite of that kind is a really old DEFIANCE cast iron knife. It is heavier than most but the handle halves are perforated to lighten it up and the holes also improve the grip. That blade does not wiggle a single nanometer.
Offline Packard
« Reply #34 on: June 04, 2021, 02:38 PM »
I have this light-duty breakaway knife from Olfa.   I find that the thumbwheel lock is the most reliable.
For heavier cuts I use this Olfa, again with the thumbwheel lock:
In my pocket is this Gerber lock back knife.  The blade is held in place with a set screw.  Slower to replace, but no wiggle or wobble. Very compact with a money clip or belt clip included.  All stainless steel.
For cutting larger boards I use a Fletcher 3000 mat/glass/plastic cutter.  Wall mounted and not portable, heavy and expensive (about $3,000.00 currently); it was left over from my picture framing business.  It cuts up to 40" tall, in mat boards,  glass or plexiglass with the use of a turret head holding various cutters.  I am not recommending its purchase, but if you have one it is great.  Limited to 90 degree cuts.
Offline demographic
« Reply #35 on: August 20, 2021, 09:12 AM »
The 'MUTHA'...  accept no Other.
Yeah, me too.
They're big, kind of heavy but the floorlayers use em cos theyre comfortable and last well.
Can't see me changing and the ones with too much moving parts just get ,clogged up with plasterboard dust and die.
Offline rst
« Reply #36 on: August 20, 2021, 09:22 AM »
I helped a flooring guy back in the early seventies.  We kept a sharpening stone to tune up our blades back then as the billions of Chinese ones were not as available.  I exclusively use Olfas now, four different sizes, but still keep an extra fine DMT file to tune up for an even sharper edge at times.
Offline JimH2
« Reply #37 on: August 20, 2021, 11:31 AM »
+1 on the Milwaukee. Wore out my old Stanley favorites and switched to the fastback. It is well-built and the folding mechanism is a plus.
Re: Favorite Utility (Stanley) Knife?
« Reply #38 on: August 21, 2021, 09:54 AM »
Here are a couple I just ran across.
203994
498183
Offline Imemiter
« Reply #39 on: August 21, 2021, 11:39 AM »
I'm not a massive fan of snap-off cutters, but I'll probably pick up a Knipex CutiX just to throw in the toolbox. The extendible "spine" seems like a feature that might be useful a couple of times a year or so.
