Author Topic: Hultafors EDC Chisel's  (Read 9829 times)
Offline Throwback7r
« on: July 17, 2014, 08:52 AM »
So I found these and decided to give them a try, I don't have any other chisel's so thought why not buy the entire set, and a few knifes. They are made really nice and I like the holster, very good design I like that you can see the size really easy and the holes for water to escape are large and plenty full.
Offline bijeshj
Re: Hultafors EDC Chisel's
« Reply #1 on: July 17, 2014, 09:25 AM »
they look really cool. where did you buy them?
Offline Throwback7r
« Reply #2 on: July 17, 2014, 09:29 AM »
http://www.repconnw.com
You have to call them. They were really nice on the phone and super fast shipping from portland to chicago area in 2 days, I was expecting to wait a week.
Offline PeterJeffrey
« Reply #3 on: September 05, 2014, 05:15 AM »
Personally I don't like the looks of the chisels, but I do however like the fact that they come with holsters, just like Bahco's do! Does anyone know where they are made and what steel?
Offline SittingElf
  • 66 Systainers and rising! YIKES!
« Reply #4 on: September 05, 2014, 09:03 AM »
From their website:
"The Chisels EDC is made of perfectly sharpened Japanese steel and a heavy-duty handle, made of glass-fiber reinforced PP-plastic, that can stand even the most hard-hitting treatment. The blade tangs are provided with barbs to prevent the blade from being forced inside the handle when hitting, making the chisel feel and perform as one solid part. In addition, to make them all highly accessible, we have also designed a smart new holster that can be easily attached to a belt, pocket, or jeans-button. "All in all, every function needed – right at hand," says Håkan Carlsson.
Still think the actual manufacture is probably China.
Cheers,
Frank
« Last Edit: September 05, 2014, 09:05 AM by SittingElf »
Woodworking is 3% talent and 97% paying attention to the FOG!
hammerfelderowners.com
Offline Throwback7r
« Reply #5 on: September 05, 2014, 09:22 AM »
There is nothing on the chisel's I do like them though.
Offline PreferrablyWood
« Reply #6 on: October 26, 2014, 03:58 PM »
I think they would be interesting, if the performance is great, and the price is right.. I'll check them out..
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline DAZ40
« Reply #7 on: October 26, 2014, 04:51 PM »
Does the holster have a belt clip on it so it will fit on a toolbelt
Offline Throwback7r
« Reply #8 on: October 26, 2014, 08:03 PM »
Yes it does just like the Hultafors knife's
Offline sae
« Reply #9 on: January 08, 2015, 09:12 AM »
Any long term feedback on these?
I have a Hultafors axe, and have been very pleased.
Offline Throwback7r
« Reply #10 on: January 08, 2015, 09:59 AM »
I have been very pleased with the set of them. The most used out of the set is the Chisel knife. I really don't know how I even did somethings with out it. I have since bought snickers pants and they have a spot for the holsters so that helps. If you have any questions just PM me.
Offline richy3333
« Reply #11 on: January 08, 2015, 03:32 PM »
They are designed to fit on Snickers trousers or Snickers tool vests. I use the electricians knife and go through a couple a year. They are cheap and I consider them disposable.
Never tried the chisels.
« Reply #12 on: May 21, 2015, 02:45 PM »
They are carbon steel and they take to sharpening well. I think the price is fair.
The steel is not quite the same quality as they were before, as with older Bahco steel chisels, or the "E.A Berg", which I have plenty of and which are among the very best on the market regardless of price.
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
