Author Topic: Tsc-55 panther blade  (Read 829 times)
Offline pettyconstruction
« on: April 28, 2020, 11:03 PM »
I had a project the other day that required a lot of ripping on 3/4” plywood . Went through a lot of batteries on the tsc saw.
Got me thinking about the ripping blade, is it that much better
I will probably get it anyway , but what the thinking out in Festool land. Worth it or not.
Thanks, Charlie
Offline ScotF
Re: Tsc-55 panther blade
« Reply #1 on: April 29, 2020, 12:37 AM »
Not sure it would be that great for sheet goods. Better in solid wood. I find the 28 tooth is fine ripping plywood.
Offline Chris Cianci
« Reply #2 on: April 29, 2020, 05:59 AM »
Make sure your current blade is clean.....mine is always dirtier than I think. I have a Panther I use for ripping hardwood it rips incredibly well. I see it as a specialized blade for ripping hardwood I recently saw a video from Colin Knect ?spelling ? WoodWorkWeb he demonstrates different woods including sheet goods and the different blades It was a concise clear demonstration the best I’ve seen.
Offline cpw
« Reply #3 on: April 29, 2020, 06:31 AM »
I'm not sure about plywood, but my TS75 with the standard blade was bogging down straight line ripping 8/4 white oak.  With the ripping blade it made it right through no problems.
Offline johan139
« Reply #4 on: April 29, 2020, 08:12 AM »
« Reply #5 on: April 29, 2020, 06:14 PM »
Thanks guys,
I keep forgetting about the clean blade thing. It may be gummed up.
Is acetone a good cleaner or what’s the preferred product?
Cheers Charlie
Sent from my iPhone using Tapatalk Pro
Offline WoodButcher204
« Reply #6 on: April 29, 2020, 07:18 PM »
Re cleaning- I keep a two gallon pail in my shop with a very strong solution of liquid laundry soap to water. A 20minute soak and a good scrub with plastic brush yields great results for me. Just make sure to rinse thoroughly and dry blade very well. Ymmv.
« Last Edit: April 29, 2020, 07:24 PM by WoodButcher204 »
Offline waho6o9
    • Garage Door Handyman.com
« Reply #8 on: April 29, 2020, 09:47 PM »
313713-0
313715-1
I've had great results with CMT blade cleaner.
Offline ScotF
« Reply #9 on: April 30, 2020, 12:45 AM »
I just use Windex...works just as well as blade cleaners. Simple Green works great too.
Online Cheese
« Reply #10 on: April 30, 2020, 08:03 AM »
I use CMT or Simple Green. Don't forget to use a small brass brush, that will help remove the burned on resins from the sides of the teeth.
https://simplegreen.com/cleaning-tips/rooms/garage/saw-blades/
