The HGTV show “Fixer to Fabulous” is hosted by Dave and Jenny Marrs. Jenny does the design work and Dave acts as the general contractor and also makes some of the special projects in his shop in his barn.
In an older show I was watching he was building the shelves for a large pantry cabinet. It was about 8 feet tall and about 8 feet wide. The unit looked like a grid with 24” x 24” openings. A total of 16 openings.
In his shop he was building the face frame which he would be adding to the shelving unit on site with a nail gun.
On the show he was shown at the beginning of the face frame build. He was using a domino machine and he said, “I will be assembling this with dominoes”. The face frame material appeared to be 3/4” x 2-1/2”.
However, when he was shown later doing the installation onsite, each joint clearly showed two pocket holes located at the center of each piece of stock.
My guess is he changed construction methods after he realized he did not have bar clamps to span the 8 foot structure and he switched to pocket holes.
He could have used both, if he placed his pocket holes wider. But that that did not appear to be the case.
The should have re-shot the assembly scene or simply edited it out.
I don’t think he could have driven the pocket hole screws through the dominoes.
But I don’t use dominoes, so what do you think?
I think he could have done the glue up in smaller sections and then a 30” bar clamp would have been fine.
Of course I am guessing:
1. That he actually abandoned the dominoes
2. Why he used the pocket holes
Anyway, what do you think?
