Author Topic: Sharpen and clean your blades!  (Read 15806 times)
Offline ear3
« on: February 18, 2018, 02:02 PM »
No horror show stories to drive home the point, but just an observation that it seems like I have to relearn/re-remember every few months.  This specific remembrance was triggered by a switchover to a freshly sharpened blade on my TSC55, and my marveling with how effortlessly I pushed through a rip on a 6/4 piece of hardwood.
The thing about dulling blades is that while sometimes you might get dramatic signs, like burning or a ragged cut, it is more often for me like the boiling frog scenario.  Over time the saw just requires more force to push through the cut, but you don't really notice since it's only marginally more than the day prior.
But then you swap out for a fresh blade and BOOM!, you're back to cutting like a hot knife through butter.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
Re: Sharpen and clean your blades!
« Reply #1 on: February 18, 2018, 05:21 PM »
Good public service post! Blade sharpeners say many blades sent in for re-sharpening really just need to be cleaned.
Offline rst
« Reply #2 on: February 18, 2018, 06:32 PM »
I haven't replaced a saw blade in ten years and I cut wood, plastics, aluminum, and brass.  Cutting plastics tends to coat the blade bodies so I remove and clean with conditioning buffs.  That being said, I only buy industrial blades made for day in/out constant use.
Offline fignewton
  • "Fine Quality Sawdust"
« Reply #3 on: March 15, 2018, 09:02 PM »
I use Rockler's router bit and blade cleaning kit regularly on all my blades.  Amazing how much stuff builds up around the teeth, and this stuff takes care of it.  Really cuts down on the heat generated and improves cutting.
TS55, MFT3+, OF1400, C12, CT-26, LR-32 system, Domino 500, RO125, MFK 700, Carvex w/ accsy, Sys-roll,  CXS, Kapex, UG with extensions, RO90
Offline Z48LT1
  • My excuse is I never expected to be caught.
« Reply #4 on: March 15, 2018, 11:44 PM »
Does anyone have good experience with cleaners/solvents that aren't necessarily sold for blade cleaning but may be hiding in plain sight the shop or kitchen cleaning cupboard?
Offline Alex
« Reply #5 on: March 16, 2018, 02:54 AM »
Anything that solves grease works. Ammonia, WD40, thinner, white spirit, normal soap.
Offline Twoodman66
« Reply #6 on: March 16, 2018, 04:15 AM »
Dollar store oven cleaner
Offline GoingMyWay
« Reply #7 on: March 16, 2018, 09:09 AM »
We've been using Krud Kutter: https://www.findkrudkutter.com to clean our stovetop for a while.  I started to use it to clean my TS55 blades after I saw Sedge use it: https://www.instagram.com/p/BYbAbOWHIHU/?taken-by=festoolsedge.
Inquiring Minds Want to Know
Offline Mario Turcot
« Reply #8 on: March 16, 2018, 09:44 AM »
I found that , to me it`s a no brainer since baking soda is part of the kitchen. Make sure to dry up the blade, you can use a hair dryer and after apply a coat of libricant.
Mario
Mario
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #9 on: March 16, 2018, 11:53 AM »
My sharpener said that more than half of the blades he gets really just need a good cleaning.
Online Cheese
« Reply #10 on: March 16, 2018, 12:27 PM »
I use CMT blade cleaner or Simple Green. The Simple Green needs to soak a little longer than the CMT product.
Online Cheese
« Reply #11 on: March 16, 2018, 12:42 PM »
Be careful, CMT along with others advise against using oven cleaner. They claim it attacks the binder in the carbide insert and can also affect the tri-metal brazing process.
Offline Sparktrician
« Reply #12 on: March 16, 2018, 02:23 PM »
I'm with @Cheese on this one. Most of the time, it's Simple Green sprayed on, then let to sit in a mud bucket top for an hour or so, then scrubbed as necessary with a stiff bristle brush.  If Simple Green has difficulties, it's CMT blade cleaner.  Blades get a good spray of WD-40 afterwards and a detailed wipe-down before being put away.
- Willy -
Offline ProCarpenterRVA
« Reply #13 on: March 16, 2018, 02:28 PM »
EZ Off Oven and Grill Cleaner. Wear protective gloves, respirator and eyewear
Sent from my Pixel XL using Tapatalk
Offline Rob-GB
« Reply #14 on: March 16, 2018, 02:31 PM »
I'm not a metallurgy expert but my understanding is that tungsten carbide is a sintered product that uses heat and pressure to form the powdered material into any form required. It requires no binding agent.
Maybe CMT are looking after their sales revenue with their claim.
Years ago we had need of cutting some brass angle to a narrower size and decided to use an old triple chip blade that looked quite gunked up. It seemed to get quite clean and serviceable afterwards so got put back in the "good to go" pile  [big grin] Not saying to use cutting up brass as a cleaning method but there are many ways to do so.
Rob.
Offline RustE
« Reply #15 on: March 16, 2018, 03:41 PM »
Only “binder” I know of is used in the brazing process. For lack of a better phrase, the binder gets cooked-off during the furnace brazing cycle.
Offline ChuckS
« Reply #16 on: March 16, 2018, 03:52 PM »
When it comes bade cleaning, I follow my hand tool sharpening philosophy: do it often.
I have two go-to blades so I can switch one with another when cleaning is done (once every three to four months or so).
I use Simple Green (usually soaked for two hours, if not more) and a brush. Before I put it away, I clean it with WD40 to remove moisture and then spray a thin coat of Fluid Film or similar rust preventative on it. The Simple Green is reused a couple more times before disposal.
Online Cheese
« Reply #17 on: March 16, 2018, 05:59 PM »
Well FWIW...
Forrest does not recommend oven cleaner and recommends Simple Green.
CMT does not recommend oven cleaner and recommends their own orange cleaner.
Freud does not recommend oven cleaner and recommends a citrus based cleaner.
They also go a bit further than the others by referencing common oven cleaners,  “These attack the binder in the carbide and, on Freud blades, they also deteriorate the special tri-metal brazing we use. This can cause carbide or brazing failure and could lead to injury.”
Offline rst
« Reply #18 on: March 17, 2018, 09:20 AM »
I cut aluminum and plastics more than anything.  Aluminum is a sticky metal which can gum up blades especially bandsaws.  I keep old 1/8 brass lock covers and run the blade through them to clean off the aluminum.  Works for plastics too, although, I often have to use conditioning pads and bobs to clean the plastic off the blade body.
Offline RustE
« Reply #19 on: March 17, 2018, 12:42 PM »
My curiousity got the better of me and I did some reading on carbides.
Cemented carbides are made like @Rob-GB posted above.  Tungsten carbide powder is mixed with nickel, cobalt, or iron powder as the binder alloy.  Heat and pressure make the powders into a solid form.  There is a balance between hardness and toughness based upon the amount of each alloy used in the mixture.
The information @Cheese posted above suggests that oven cleaner attacks both the microstructure of the carbides and the braze joint.
« Last Edit: March 17, 2018, 12:44 PM by RustE »
Offline HarveyWildes
« Reply #20 on: March 18, 2018, 10:12 AM »
This thread inspired me - I cleaned my blades yesterday.  There was more gunk on them than I would have guessed - it snuck up on me.
Offline JCLP
« Reply #21 on: March 18, 2018, 10:26 AM »
I have been using this stuff for years. Works great.
Spray-on resin and pitch remover.
Simply spray on wipe off.
Ideal for sawblades, router cutters, planer blades, files, wrenches and drill bits etc.
Excellent lubricant. Provides rust and corrosion protection.
Has unique properties which break the molecular bond and lifts the dirt from the tool as opposed to eating away the dirt like citrus cleaners and other chemicals.
Industrial strength cleaner that increases tool life.
Biodegradable and user friendly.
Non-toxic and non-flammable.
Supplied in pump action dispenser.
Cheers,
JC
Online Cheese
« Reply #22 on: March 18, 2018, 10:37 AM »
Before I purchased the TS 55 & Kapex, every circular saw blade I owned was either a Forrest or a Freud. Thus the reason I decided to contact both manufacturers for their blade cleaning recommendations.
In the past, I've cleaned blades with oven cleaner but that's such a messy process. Everything needs to be covered with newspaper and if any oven cleaner gets on the grass or flowers, they're dead.
It's much easier to put some CMT or Simple Green in a mud bucket lid and let the blade soak for 10 minutes, then simply rinse with water. No need to wear gloves or a respirator.
Offline leakyroof
« Reply #23 on: March 26, 2018, 02:47 PM »
  Regardless of what cleaner you use, I love Rocklers dedicated saw cleaning pan that they sell for very little money. Takes up small space in shop and no regular cleaner seems to attack the plastic that it's made out of . Since it comes with a lid, it beats having to cobble something up to fit a 12" or 10" saw blade[  My Miter Saw has the larger 12" blade]   Thumbs up to Rockler for making a task easier that I SHOULD do more often.... [embarassed]
Online Cheese
« Reply #24 on: September 01, 2018, 10:46 AM »
Well this is kind of a goofy post but it's a good reminder, call it a public service announcement.  [big grin]
I've been using my TSC 55 with a diamond blade to cut porcelain tile. Yesterday my neighbor asked me to trim her Doug fir picnic table to remove some soft end pieces. I went down stairs, grabbed a blade and cleaned it with Simple Green.
I took the TSC, the clean blade and a rail over to the picnic table and changed out the blade on the spot. I placed the rail in position, put the saw on the rail and proceeded to cut a 3 foot width of fir 2x4's on each table end. I did notice that the saw wasn't cutting as fast as usual, however I chalked it up to just being aged Doug fir which grows harder with age.
Then this morning the light bulb came on...did I cut the Doug fir yesterday at the same speed as the porcelain tile?
Yup...speed 1...2650 RPM. [doh]   [oops]   [doh]
Online waho6o9
    • Garage Door Handyman.com
« Reply #25 on: September 01, 2018, 11:52 AM »
CMT is quick and effective.
284624-0284626-1
« Reply #26 on: September 01, 2018, 12:36 PM »
I’ve never owned such a shiny blade (as above).
Anyone have experience using the Infinity blade on the tracksaw?
https://www.infinitytools.com/saw-blades-accessories/plunge-cutting-track-saws/track-master-saw-blades
Offline tjbnwi
« Reply #27 on: September 01, 2018, 01:51 PM »
I own a lot of Infinity cutting tools but no track saw blades.
I’m happy with all their tools I do own.
I do have a few blades sharp and ready.
« Reply #28 on: September 02, 2018, 09:12 AM »
Did Tom drop the mic again?  [big grin]
Offline tjbnwi
« Reply #29 on: September 02, 2018, 12:51 PM »
CMT Blade and Bit Cleaner also, either end of a bucket works....
Offline tjbnwi
« Reply #30 on: September 02, 2018, 01:00 PM »
There are 2 fresh blades in each of the saw Systainers also...
