Author Topic: Festool connectors with jig  (Read 170 times)
Cheese and 2 Guests are viewing this topic.
Offline Tobiasz
« on: Today at 04:56 AM »
Hi.
Small question to you guys, does any of you used those festool KV-LR32 connectors without domino using some  diy jigs?
I wonder would that be possible without df500 and all this fancy hardware out there
Offline squall_line
Re: Festool connectors with jig
« Reply #1 on: Today at 10:23 AM »
Hi.
There are dozens, if not hundreds, of videos showing how a router and other tools can be used to substitute for a Domino joiner.
I don't know what other "fancy hardware" you're referring to, but if you also mean the jig to drill the 15mm holes for the connectors, that one is somewhat essential for the proper placement of the hole, along with the drill bit itself.  If you already have the bit and a stop collar, I'm sure with enough trial and error you could get the placement correct.
If you don't have a Domino or the knockdown connector set, you'd probably be better off with a cross-dowel jig and hardware, IMHO.  The KV-D8 system isn't exactly cheap when it comes to consumables, and the time and effort to make your own jigs wouldn't really get you much of anything that a cross-dowel jig couldn't get you in a fraction of the time.
Offline Crazyraceguy
« Reply #2 on: Today at 06:19 PM »
Cutting the required slots without a DF500 would be pretty easy, depending on location/orientation. The  rest of the connector set would be a must.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
TS60
