Author Topic: Kapex hose  (Read 491 times)
Offline pettyconstruction
Kapex hose
« on: May 08, 2020, 05:18 PM »
I searched the forum for a source of a 36mm hose for my new Kapex , and I know that Bob used to have one,but how about now?
I know I can cut one down,but would like a better solution .
I have a Bosch hose , but I don’t think it’s A.S
Thanks in advance ,
Charlie
Btw I’ve been wanting that saw for a long time but waited till the motor issues got worked out. Hopefully
Offline Bohdan
Re: Kapex hose
« Reply #1 on: May 08, 2020, 08:17 PM »
You don't need an AS hose on the Kapex as it doesn't produce dust for long enough to build up any voltage. I also think that the frame is already earthed via the power cord.
I have been using a short length of 50 mm black hose (off an old shop vac) without any problems but with a huge improvement in suction. I had to make an adaptor out of some PVC plumbing to fit the Kapex.
Re: Kapex hose
« Reply #2 on: May 08, 2020, 08:41 PM »
Thanks,
I was thinking about a 50mm hose also.
I cut and rigged up a old Bosch hose I had laying around so I’ll run that.
Thanks again,
Charlie
Offline ChuckM
Re: Kapex hose
« Reply #3 on: May 08, 2020, 08:45 PM »
I have used my Kapex with a regular (non anti-static) hose for years. The Kapex's power plug is two-pronged, so not grounded.
