Author Topic: Best $100 or so spent on festool or other  (Read 1038 times)
Offline guybo
« on: May 25, 2022, 10:29 AM »
Found this to be a good buy
Offline ChuckS
Re: Best $100 or so spent on festool or other
« Reply #1 on: May 25, 2022, 11:23 AM »
I know a couple of guys who do something similar with the original bags, and they reuse them at least a few times before throwing away the bags. They reseal the partially open end with dust tape (and staples?).
I think not everyone wants to deal with the emptying part that can be pretty dusty. Better do it outdoors.
Offline jeffinsgf
  • Woodpeckers Marketing Department
« Reply #2 on: May 25, 2022, 11:27 AM »
Don't remember exactly how much it was, but it was less than $100.
Best thing I have ever done for my Festool gear was sleeving my hose and power cord together. Game changer.
Offline TinyShop
« Reply #3 on: May 25, 2022, 11:56 AM »
Take a look on eBay for a seller who adds zippers to a range of standard Festool bags. This is a super easy project to tackle yourself but for all those who don't want to get involved with sourcing a zipper and sewing, much cheaper compared to the Festool option:
https://www.ebay.com/itm/174575092078?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=ZAU-SyOgR9a&sssrc=2349624&ssuid=ddSuuhNeSOW&var=&widget_ver=artemis&media=COPY
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline usernumber1
« Reply #4 on: May 25, 2022, 12:52 PM »
i prefer to just dump the bag myself and not deal with the mess.
however, sleeving the vacuum hoses was definitely the best $30 spent on festool
Offline jeffinsgf
« Reply #5 on: May 25, 2022, 01:28 PM »
+1
I know the bags are spendy, but why pay for top quality filtration, then breathe THE WHOLE BAG full of dust by emptying it? I pull that little seal over the hole, say a thank you to the Festool engineers and dump the whole thing in the dumpster.
Offline ChuckS
« Reply #6 on: May 25, 2022, 01:31 PM »
The best money spent is on the Dust Deputy in conjunction with the iVac auto switch. No more bags changing (at least not until a few more years later), and without opening the vac lid, I can tell if it's time to dump the sawdust. I have one for the Kapex, and one for the drill press/stationary sanders.
Offline ChuckS
« Reply #7 on: May 25, 2022, 01:36 PM »
Snip.
I don't see that a problem at all as long as the emptying is done with a mask worn. Even if we can avoid handling the dust extractor bags, what about the dust collector bags and dust deputy cans that we need to deal with periodically?
« Last Edit: May 25, 2022, 01:39 PM by ChuckS »
Offline Vtshopdog
« Reply #8 on: May 25, 2022, 03:37 PM »
M-18 Compact vacuum.
I grab it constantly for little jobs that aren't worth getting a big vac out and a broom doesn't quite get things done.
344854-0
https://www.homedepot.com/p/Milwaukee-M18-18-Volt-Lithium-Ion-Cordless-Compact-Vacuum-Tool-Only-0882-20/300510229
Offline Thompmd
« Reply #9 on: May 26, 2022, 06:30 AM »
Is the sleeve #500670 for $28? Does it fit CT36/std hose that came with it. Thanks
Sawstop Industrial Saw, TS75,2 800,2 1400 & 2700 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160, TSC 55, T18 E
Offline etds4u
« Reply #10 on: May 26, 2022, 12:26 PM »
Bluetooth remote control kit for my CT vacs is my favorite sub-$100 Festool purchase.
Offline jeffinsgf
« Reply #11 on: May 26, 2022, 01:07 PM »
No, we're talking about braided sleeve covering the old plastic hose. It was (is) notorious for snagging on anything it touched. For the last 5 years or so, Festool hoses have had a fabric sleeve over them. For those of us with older hose who are too frugal (cheap) to buy a new hose, this stuff: https://www.cabletiesandmore.com/flexo-pet-braided-sleeving is a reasonable facsimile of a new hose. Added benefit is there's room to thread a power cord in there, too. 1-1/4" diameter, Uptown Green.
Online Cheese
« Reply #12 on: May 26, 2022, 02:44 PM »
This is what Jeff was referring to, the RH side is the standard hose covered with Flexo PET braid and the LH side is the standard hose covered with a Festool zip-on cloth sleeve.
I used the Flexo method for 3-4 years but noticed the hose became quite stiff and just was not as flexible for sanding and getting into tight areas. At which time I abandoned the Flexo PET braid and went to the Festool offering instead on the CT 22 & MIDI. I like this a lot more.
Here's what the Flexo looks like when it's removed from 2 hoses.  [smile]
Offline afish
« Reply #13 on: May 26, 2022, 03:42 PM »
(Attachment Link)
Im with cheese here but will add it depends on if the hose is suspended from above or not.  I agree the PET cover does make the hose much stiffer and for sanding its better without when suspended from above.  Now if its plugged into a CT and prone to be catching on the edge of a bench etc. It might be better with.  So it depends in my opinion.
(Attachment Link)
