Author Topic: Anybody have concerns about their DF 700 getting overly hot during operation?  (Read 557 times)
Offline scbucc
I had my DF 700 repaired recently and now I’m probably overly sensitive to it’s operation, but it does seem to running hotter than I remember prior to the repair.  is this common?
RO 150, TS 75, , BHC 18, RS 2, HL 850, DF 500, KS 120, ETS 150, T15, T12, MFT/3, OF 1400, VS 600, LHS 225, OS 400, DWC 18, BR 10, CT 36, CT 48, BOOM ARM 48, WCR 1000, Shaper ORIGIN, Apollo Precision 5, RISD, NU.
Offline tsmi243
Both of my domino machines run pretty hot.  Been wondering about it myself
Offline squall_line
Here are two relevant and worthwhile conversations on this topic here on the FOG, found with a quick google search:
From 2009:
https://www.festoolownersgroup.com/festool-tool-problems/domino-running-hot/
From 2020:
https://www.festoolownersgroup.com/festool-tool-problems/new-df500-domino-running-hot-and-tenons-too-loose/
It may be a calibration issue during the repair? Definitely worth reaching out to Festool, if they were the ones who provided the repair service.
Online Crazyraceguy
I use my DF500 quite a bit, likely more than most, in a commercial cabinet shop. It has never gotten more than what you would call warm. It's really just warm enough that you could tell it had been running, if you just walked up and touched it. I use 6mm Dominos about 90% of the time and 8 x 50 the rest, so not a great load on the motor. I usually go through about 3 of the 1140 count boxes in a year, but I'm more than half way through the last bag of the second box and it's only mid June.
I have seen posts about heat from users of RO 150 too? I've never had a heat problem with any of my Festool gear.
« Last Edit: Yesterday at 07:42 PM by Crazyraceguy »
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Offline RO
  • May the best of today be the worst of tomorrow
I think you should take it back to the
No this is not common, if it was done by festool take it back and let them check it out.
