Couple years ago I was running screws down through the subfloor in a room I was re-doing. The impact driver will zip those screws down quick, you just have to start slow gripping the screw somewhat loosely so the threads don’t slice your fingertips. Once it gets a few turns into the wood, move your hand out of the way and let the impact driver rip. They make a magnetic screw and bitholder with an extending sleeve to hold the screw (and keep your fingers clear). I had one in the basement, but never brought it up. Anyway, I ran down over 50 screws already. 2nd to last screw I needed to run, the screw works loose, torx bit drops straight into my index finger with my weight behind it. There is a brief moment when you think it’s not that bad, it might sting a little. And it did. Then I watch fluid quickly filling my finger tip, and I can feel the pressure building fast. I dropped the impact driver, ran downstairs, grabbed a container from the cabinets, filled it with ice and submerged my hand. So while you’re waiting it out for the next 30 minutes, after you’ve finished explaining why you’re an idiot to your wife, you ask yourself if it was really worth the 5 minute trip to the basement to get the right tool in exchange for a trip to the ER (which will consume the next 5 hours). The answer is always no. The trick is to ask yourself that question before you take a shortcut.
As mentioned above, when you’re tired is another prescription for trouble. I try to stop before i get to that stage when the mistakes start piling up. Usually they just cost me rework, but when sharp tools are involved, that’s added motivation to stop.
