Author Topic: Not able to see images in my own post  (Read 9600 times)
Offline Michael H
    • MDH Woodworking
« on: July 27, 2014, 08:50 PM »
I'm new to the forum and only have a few posts. I just listed a couple of items for sale in Classifieds. But when I open my post, it says IMAGE NOT SHOWN - GUESTS CANNOT VIEW ATTACHED IMAGES
Why can't I see the images I've attached to my own post? I am logged in under my username, not as a guest. I believe I attached the images correctly. I frequently post and attach images on other forums, so I think I know what I'm doing.
Thanks for any help or insights.
Michael Heffernan
MDH Woodworking
Offline Peter Halle
Re: Not able to see images in my own post
« Reply #1 on: July 27, 2014, 09:04 PM »
It seems that some settings might need to be changed.  Can you see them now? Were you logged in before when you tried?
Offline Michael H
    • MDH Woodworking
« Reply #2 on: July 27, 2014, 09:18 PM »
Peter, I was logged in when I checked my posts. I am logged in now and still get the same message for each image I attached. Can you see the images in my classified posts?
Michael Heffernan
MDH Woodworking
Offline SRSemenza
« Reply #3 on: July 27, 2014, 11:42 PM »
I can see your images. Did you get this squared away?
Offline Alex
« Reply #4 on: July 28, 2014, 06:51 AM »
I can't see his images.
Apparently all permissions haven't been set correctly yet. You guys are moderators, your permission level is higher by default.
I'm sure Shane will sort it out.
Offline Peter Halle
« Reply #5 on: July 28, 2014, 07:14 AM »
Alex,
There might be a couple of things going on.  I could see the images after Shane edited the classified listing for the CT.  I could view it until a couple of minutes ago.  Then I logged out.  As a guest I could not see the images.
As a moderator I don't think that we have higher level permissions as far as viewing images.  Mainly we have permissions regarding dealing with modifying posts and removing posts and members.  It looks like Shane resized the images down to 1024 in one direction.  SittingElf, in another thread indicated that he thought the limit was 1000 in one direction.  I am going to download the images from the  classified thread and reduce them to less than 1000 and then post back here if you can see it.  It will take me a couple of minutes but I will do right now.
Offline Peter Halle
« Reply #6 on: July 28, 2014, 07:53 AM »
Here are the images form that other post.  I have included two copies of each image.  One has a max dimension in one direction of 1000 pixels, the second one is max 999 pixels.  Let me know what works.
Thanks, Peter
Offline Alex
« Reply #7 on: July 28, 2014, 07:59 AM »
Yep, I can see these pics in this thread. So you think it depends on size?
Little test, pic = 2592 x 1944  at 1.156 MB
« Last Edit: July 28, 2014, 08:53 AM by Alex »
Offline Michael H
    • MDH Woodworking
« Reply #8 on: July 28, 2014, 08:02 AM »
Good morning. I still can't see the images in my post and I am logged into the forum. All the images still show the message that Guests Cannot View Attached Images. Is there something I am missing when I originally attach images?
Michael Heffernan
MDH Woodworking
Offline Peter Halle
« Reply #9 on: July 28, 2014, 08:04 AM »
Yes,
Below are three images sized to 1001 pixels in max dimension.
Let me if these show.
Offline Alex
« Reply #10 on: July 28, 2014, 08:05 AM »
I doubt it is something you are missing. You did it alright. This forum has had a very recent software update. There are a few kinks to work out. Give it some time.
Perhaps you should post a couple of pics in this thread to see if it works.
« Last Edit: July 28, 2014, 08:17 AM by Alex »
Offline Alex
« Reply #11 on: July 28, 2014, 08:10 AM »
@Peter, I can see my picture above though it has a very big size. Maybe the problem is with the Classifieds section, it has different permissions than the rest of the board.
File size has been reduced by the board to 384Kb instead of 1.156MB, but the dimensions are still 2592 x 1944.
Offline Peter Halle
« Reply #12 on: July 28, 2014, 08:12 AM »
Try going to that thread, and if you are using Windows hit F5 and see what happens.  You can also clear your cache to make sure you aren't looking at old data.
Offline Peter Halle
« Reply #13 on: July 28, 2014, 08:18 AM »
Alex, I use Photoshop to resize.  When I resize I use the "save for web and devices" option just like I've been doing for the last 5 years.  The 384KB amount is what the software shows when I saved it.  In my software I saved that to max resolution.  I could have probably resized and reduced the quality to get down to less than 80KB without anyone noticing.  I don't have the ability to see the permissions or rules.
Offline Alex
« Reply #14 on: July 28, 2014, 08:20 AM »
I was talking about the picture of my CS70 I uploaded a few posts above as a test. The size is very big but I can see it without problem.
Offline Alex
« Reply #15 on: July 28, 2014, 08:57 AM »
I can't see the pics in your test post in the classifieds.
http://festoolownersgroup.com/classifieds/test-post-only/msg330577/?topicseen#msg330577
Offline Peter Halle
« Reply #16 on: July 28, 2014, 09:08 AM »
Weird,  looking at it thru tapatalk the inlines are there but the thumbnails are.
Offline Festool USA
  • Festool USA Employee
    FOG Administrator
    • Festool USA
« Reply #17 on: July 28, 2014, 09:13 AM »
Sorry for the trouble. I just checked and there was yet another setting to enable viewing attachments. This must be new in the new version of the forum software as it was unchecked for the Classifieds section, which has unique permissions compared to the rest of the forum.
Have a look now. Again, sorry for the issues.
Shane
Offline SittingElf
  • 66 Systainers and rising! YIKES!
« Reply #18 on: July 28, 2014, 09:15 AM »
Maybe it will change soon, but I just checked Peter's Test post in Classifieds.
This is the result:
Woodworking is 3% talent and 97% paying attention to the FOG!
hammerfelderowners.com
Offline SittingElf
« Reply #19 on: July 28, 2014, 09:18 AM »
OK... SUCCESS!!!  [thumbs up]
Pics visible in Classifieds now.
Cheers,
Frank
Offline Alex
« Reply #20 on: July 28, 2014, 09:19 AM »
I can see the pics now in the classifieds section, works for me. Both Peter's and mheffernan's posts.
Offline Michael H
    • MDH Woodworking
« Reply #21 on: July 28, 2014, 10:00 AM »
I can see the pics now. Thanks.
However, in my other classified post for the RO 150 FEQ Plus, image one shows up 5 times, before the other images as thumbnails. When I added the files to the post, I then clicked the [Insert attachment 1 in the message]. Now looking at the post in the 'modify' window, all 5 images have [Insert attachment 1 in the message], not 1, 2, 3, 4, 5. So this inserts the same image (#1) for each unique image uploaded.
I removed inserting the image in the message, so only the five individual thumbs show up.
Michael Heffernan
MDH Woodworking
Offline Festool USA
    FOG Administrator
    • Festool USA
« Reply #22 on: July 28, 2014, 10:21 AM »
Inserted those images for your Rotex post, Michael.
Offline SRSemenza
« Reply #23 on: July 28, 2014, 01:07 PM »
The insert choice from the drop down does not automatically change the number of the attached picture, yet. When click Insert Full Size picture , for example, they will all show number 1. You just need to change them from 1   to  2,  3 etc. or just replace with the # symbol and it will take them in the order  of upload.
See the red part below.  The parenthesis would normally show as brackets. I had to change them to make the example show in the post.
(attachimg=1)
(attachimg=2)
(attachimg=3)
        OR
(attachimg=#)
(attachimg=#)
(attachimg=#)
The duplicate thumbnails at the bottom are a separate issue which require a code change that Shane will also be take care down the road.
Offline SRSemenza
« Reply #24 on: July 28, 2014, 01:15 PM »
Scratch the above post. It is now automatic.
Offline Paul G
« Reply #25 on: July 28, 2014, 01:19 PM »
The other day I was logged in and saw the same message in your Classifieds post. It's fixed now though.
+1
