@RobBob@Peter Halle@Alex@PaulH99@koenbroI should have been clearer on just what I meant by "Threads disappearing"The only time threads normally seem to go away, is after I have viewed them, or they have spent too much time on the
default unread list. Even then, the thread is still available elsewhere, just not on the
default unread page. Should I not view a thread, normally it stays on the default "
unread" page. If I have read a thread, and it no longer shows up, the only time it comes back to the "
default unread" page is if someone has posted a new comment.
The issue I have noticed is when the I log into the
default unread threads page, they disappear without being read by me.
Usually, this happens once a day sometime in the evening, and it seems normal because otherwise the unread list of threads would continue to grow out of control. I understand the need to "trim" the list down occasionally. Having said that, yesterday I noticed only 4 threads on the list when I logged in around 5:00a.m. (and I did not read any of them). When I logged back in around 8:00a.m., all 4 were gone.
Someone said only the threads that appeared since my last visit will appear on the
default unread page, but this is certainly not the case either. As I already mentioned, normally a thread does not disappear until after I have viewed it, and then comes back when someone else responds.
What I have noticed as of late, is the
unread list being trimmed more aggressively and more often than usual.
