Author Topic: lights on sanders  (Read 3547 times)
Offline Timtool
    • My website
lights on sanders
« on: February 25, 2013, 03:06 PM »
Lately i found myself using the syslite more and more while sanding with the ETS150/5, in normal diffused workshop light or daylight you cannot see if you are properly removing the swirl marks from the previous grit. And they suddenly pop out while applying the finish.
So by holding the syslite in one hand on the workpiece shining as perpendicular to the surface as possible to highlight all the swirl marks, i am getting significantly better finishes and i also feel it helps me correct my methods.
So i was wondering if the ultimate sander wouldn't be one with an incorporated light shining almost horizontally around the base, that you could turn on of off??
All tools could generally use a Led lighting these days for visibility reasons, but in this case it would improve the work quality.
BR10, MFK 700, OS 400, ETS EC 150/3, KA 65-plus,TS55R, CT22E, CTLmini, CTL MIDI, CTM 36 AC HD, Kapex KS120, ETS125, ETS150/5, RO150, RO90, CXS-set, T-15+3 set, DTS400, OF900, OF1010, OF2200 set, Carvex PS420 EBQ set, EHL 65, SSU 200, Centrotec installer set, LR32-sys, FS-800, FS-LR-1400x2, domino 500+domino sys, domino 700 XL, Surfix-sys, Sys-box 1, Syslite, LEV-350, Sys-box,MFTB/1-2-4... MFTC, MFSC
Offline Alan m
Re: lights on sanders
« Reply #1 on: February 25, 2013, 06:32 PM »
thats a good idea.
i often use a light to check for scratchs. iv had to resand a few time after spotting something while finishing.
Offline Scott Burt
  • Magazine/Blog Author
  • painter/writer/educator
    • Prep to Finish
« Reply #2 on: February 25, 2013, 07:05 PM »
This is a great idea (albeit probably pricey to do). We sometimes wear led (camping style) headlamps as a small scale solution. Trying to figure out how to ratchet a syslite to my head.
Offline Saskataper
« Reply #3 on: March 15, 2013, 01:51 AM »
Kinda like this?
sorry, this link should work
« Last Edit: March 15, 2013, 08:56 AM by Saskataper »
Offline jmbfestool
« Reply #4 on: March 15, 2013, 03:50 AM »
*********************************************************************** [thumbs up]UK members click me
Offline Kev
« Reply #5 on: March 15, 2013, 04:53 AM »
Offline Saskataper
« Reply #6 on: March 15, 2013, 08:56 AM »
fixed the link
