Author Topic: Kapex clamps  (Read 6462 times)
Offline SRSemenza
Kapex clamps
« on: September 25, 2011, 01:24 AM »
I would like Kapex hold down clamps with a longer reach. I was using a spacer for trenching today and wished they would have been able to clamp the work piece beyond the 2" spacer.
Offline jonny round boy
Re: Kapex clamps
« Reply #1 on: September 25, 2011, 06:27 AM »
Seth,
I don't see why you would want this. Surely if you're trenching, you want the clamp to hold the spacer in place, and then hold the workpiece by hand. When trenching, the piece needs moving after every cut, and there could be dozens of passes needed.
I can't see anyone wanting to clamp the workpiece, make a cut, unclamp it, move it 2mm, clamp it again, make a cut, unclamp it, move it 2mm, reclamp it, make a cut, unclamp it, move it 2mm, reclamp it.....etc etc.
Unless of course you're trenching very small pieces? In which case, I'd do the trenching part on a longer piece and then cut it shorter.
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - PDC18/4 drill - PSC420 jigsaw - OFK500 trimmer
Offline jmbfestool
Re: Kapex clamps
« Reply #2 on: September 25, 2011, 06:34 AM »
JRB.  Remember Seth is from USA they seem to love clamping. I have  watched videos from our USA friends and they clamp der pieces to do one cut  were I would of just cut it holding the piece. They seem to have more time on jobs I think  [tongue] [tongue] [poke]  I don't think I have seen any uk carpenters have clamps on der saws I don't even know where mine is any more I took it of the day I got the saw and have never used it since.
Jmb
« Last Edit: September 25, 2011, 10:41 AM by jmbfestool »
*********************************************************************** [thumbs up]UK members click me
Offline johnnyinnb
Re: Kapex clamps
« Reply #3 on: September 25, 2011, 08:39 AM »
I`m on the east coast of canada, been in the trades since 82, i have never used a hold down clamp or seen anyone else use one.
Johnny
He`s a block off the old chip
Offline SRSemenza
Re: Kapex clamps
« Reply #4 on: September 26, 2011, 12:45 AM »
Well I wanted to clamp both the spacer and the work piece. I wanted to be able to clamp the work piece just for the outside cuts for the lap joints to make sure I didn't move the piece even a smidgen. They needed to be very precise for a good fit. The possibility of using clamps in the base extensions also exists, but only if the piece is long enough. Mine were not.  Yes, trench a longer piece and then cut it to length but that is not always possible either depending on the stock you have to use.
Also having extended clamps available would make it possible to clamp shorter pieces because the length would allow them to swing closer to the blade.
I think extended reach clamps would be a useful option.
Offline Dovetail65
Re: Kapex clamps
« Reply #5 on: September 26, 2011, 01:09 AM »
I have run into the exact same situation myself. Hey I dont clamp when doing trim work or whatever you call it across the pond. But for fine work where a piece of wood can cost a 100.00 and a 1/32" or 1/64" makes a difference you bet I clamp it. A miter saw tends to move the piece as you cut, not enough to notice for some work, but definitely enough to ruin other work. The flex in the blade has ruined cuts for me as well in the past.
I never noticed any of that when I worked on homes. My quality either went up and my eye got more critical or the caliber work I have to do now has increased or maybe a bit of both. Definitely where work needs to be done fast clamping is out, but some of Seth's work is amazing and I am sure he would rather lose a bit of time than lose the material.
« Last Edit: September 26, 2011, 01:11 AM by Dovetail65 »
Online WarnerConstCo.
    • Warner Mill Works
Re: Kapex clamps
« Reply #6 on: September 26, 2011, 11:19 PM »
I used my clamp on my Kapex probably 20 times today.
It takes like a whole 2 seconds to set it.
Offline EcoFurniture
    • Eco Furniture
Re: Kapex clamps
« Reply #7 on: September 26, 2011, 11:39 PM »
The Kapex clamp is only  mitersaw clamp I ever liked using... Therefore I used it all the time! Super easy to use. You can't compare it to the junk other brands put on.
Offline SRSemenza
Re: Kapex clamps
« Reply #8 on: September 27, 2011, 12:37 AM »
Dovetail,  not so sure my work is "amazing"
Eco and Darcy, I too really like the way the Kapex clamp functions.
Offline stairman
Re: Kapex clamps
« Reply #9 on: October 13, 2011, 12:13 PM »
hmmm,  so that's what that contraption is for...   I'll have to give it a try sometime ::)
I've not used a clamp on a miter saw for ...  come to think of it, I dont think I have ever used one!
see,  we aren't all "clamp-crazy" over here!
Kapex on a UG, TS75, OF1400 (x2) OF2000,,HL850,  Domino, RO90, RO125,  LS130, RAS115, MFT3, C12 Set, CXS Set, LR32 Set,  arsenal growing as fast as I can afford it!
Looking to buy: RO150EQ+ ; LR32 guide rails, 3000mm guide rail, parallel guide set   ;  another TS55 to replace the 1 I sold...   OF1010 and additional Festool Routers ;  RS2  ;    and a FESTOOL BS105 BELT SANDER SET
OK, let's face it, I'm always looking for any Festools / accessories.
Offline jmbfestool
Re: Kapex clamps
« Reply #10 on: October 13, 2011, 02:23 PM »
 [tongue]
Offline MrMac
    • Laurie's Custom Finishing Carpentry
Re: Kapex clamps
« Reply #11 on: October 26, 2011, 04:08 PM »
I've noticed that that saw hits the clamp when I move it to the 45 degree position, necessitating me to remove the clamp and store it somewhere else.
serving the greater Vancouver area.
Offline SRSemenza
Re: Kapex clamps
« Reply #12 on: October 26, 2011, 08:19 PM »
Yup. witch makes it nice that they install / remove so easily  [thumbs up]
Offline woodwreck
Re: Kapex clamps
« Reply #13 on: November 01, 2011, 12:06 PM »
I confess to ignorance/stupidity - what is "trenching." Perhaps it is something known but by another name?
TIA
Start slow, wind down gracefully
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
Re: Kapex clamps
« Reply #14 on: November 01, 2011, 12:22 PM »
TIA
They are referring to using the Kapex to cut a dado.
