Author Topic: Fill in the blank: I wish Festool made a ______!  (Read 602912 times)
Offline yetihunter
Re: Fill in the blank: I wish Festool made a ______!
« Reply #1140 on: July 29, 2020, 12:37 AM »
They just discontinued their half sheet finish sander and the rotary sander.  I’d also stop everything to drop $$$ for a brand new 110v AEG/Holz-Herr belt sander with Festool written on it, but I’m certainly not holding my breath.
Seriously though, slap a Festool battery on the really awesome variable speed Fein die grinder.  If you need a marketing angle, just position it against Foredom or Proxxon and say a bunch of cheesy stuff like “power unmatched” or whatever.
Offline James Carriere
« Reply #1141 on: July 29, 2020, 09:27 AM »
A dual SCA 8 battery charger would seem like a logical addition with the current Festool push for cordless tools and it would be especially helpful with the TSC55 REB.
Online Cheese
« Reply #1142 on: July 29, 2020, 10:05 AM »
A big +1 for this item.
Offline mino
« Reply #1143 on: November 20, 2020, 01:11 PM »
A range of cordless tools that utilises the the CXS 10.8v platform. Utterly bewildering to have only a single type of tool for a battery platform.
Festool is not as big as other tool manufacturers. I doubt they even have 1/10th the sales of brands like DeWalt, Makita, Metabo or Milwaukee.
This.
Plus their philosophy is to make one tool only when it can be in some way special - and make it "right/perfect". Cost be damned.
Now thinking of it, the original CXS was a "wondertool" back when it came out during the NiCd era with its special battery shape to allow good performance in a very small package for the time.
Today, I am confident Festool would not have developed a CXS-type tool at all as the mass market is flooded with adequate up to excellent tools in the category using cheap high-amperage LiIon cells. I am sure the CXS volumes are quite small and it is kept only because there is a historical market for such a tool.
The Machine does not have a brain. Use Yours!
Protool: AGP 125, VCP 260
My Precious: 376, 376, 376 holy, 632, 1016 holy, 1400 holy, 2400, GECKO, GRS 16 PE, GRS 16 PE
Offline FestitaMakool
« Reply #1144 on: November 20, 2020, 01:35 PM »
Are the BS 75 and BS 105 NAINA in 110V?
Offline Alex
« Reply #1145 on: November 20, 2020, 04:58 PM »
Yep.
Online Cheese
« Reply #1146 on: November 20, 2020, 05:36 PM »
Maybe I’m wrong  [jawdrop]    but I think I did a search and couldn’t find those sanders in anything but 230 volt.  [sad]
And unfortunately the 230 volt version is NAINA.
« Last Edit: November 20, 2020, 05:44 PM by Cheese »
« Reply #1147 on: November 21, 2020, 02:37 AM »
I see my post could be misunderstood in a way that the belt sanders are available in 110V but not for you, but no, only 230V [oops]
You need a sparky to tweak your home Cheese, then a fair amount of $ and it’s away from the other side of the pool.  [wink]
Offline demographic
« Reply #1148 on: November 21, 2020, 03:21 AM »
This^.
For the people working at home it might not make much difference but on site it would be really helpful.
Offline acknowlli
« Reply #1149 on: December 16, 2020, 05:04 PM »
I wish Festool made a battery charger for car use, on 12/24V.
Offline Bugsysiegals
« Reply #1150 on: December 16, 2020, 06:11 PM »
Sedge Christmas Ornament!
Offline Imemiter
« Reply #1151 on: December 19, 2020, 04:00 PM »
Hard structural foam inserts for all the tools. Like the foam insert my HKC came with.
CSX T18+3 TID18 HKC55 OSC18 OS400 OF1010 LR32 DF700 RAS115 DTS400 ETC125 CTSys CTMidi CT-VA
Offline Imemiter
« Reply #1152 on: January 15, 2021, 12:41 AM »
A cover plate (Festool 491750) for the HK-55 that improved dust collection, but also incorporated some kind of replaceable outboard splinter guard.
Offline Svar
« Reply #1153 on: January 15, 2021, 12:58 AM »
I wonder why they left it open in the first place. Cover it, leave a hole for Allen key.
Spotted home made cover on Youtube (FESwoodTOOL):
Offline notenoughcash
« Reply #1154 on: January 15, 2021, 05:17 AM »
better sightline to the blade more than likely.  after all its a framing tool, unlike the TS/C that is a finishing tool.
turns out that woodworking is 1% making things you'll use, 4% making bespoke high end firewood, 15% cleaning, and 80% looking for the bl**dy thing you just put down
Offline Eorlingur
« Reply #1155 on: January 15, 2021, 07:44 AM »
A smaller version of the OF 2020. The ergonomics and dust collection is spot on, but the base is too wide for some applications. Scaling it down to 2/3 of the size would be perfect. With a less powerful motor it could perhaps be battery powered and a light is an absolute necessity. I really like the self centering inserts so the 1010 isn't quite as attractive to me.
Offline Imemiter
« Reply #1156 on: January 15, 2021, 11:05 AM »
Thanks! I see in another he makes a plexiglas cover for the TS. I'll try something this weekend.
Offline Gerald_D
« Reply #1157 on: January 16, 2021, 06:26 PM »
This is quite a long thread so this may have been mentioned already, but sure would like to see a cordless vacuum.  I have the CT-Sys which is a nice vac but sure would be much handier being cordless.  May be too late for me though- getting ready to pull the trigger on one of the Milwaukee versions.  Just need to decide which one will work best for me.
Regards,
Gerald
Gerald
I have Festools- Big and Small and a few other tools
« Reply #1158 on: January 17, 2021, 03:06 PM »
a quiet rattle gun
Offline SDWW2019
« Reply #1159 on: January 17, 2021, 03:28 PM »
A lower priced Edge Bander
« Reply #1160 on: January 22, 2021, 05:07 AM »
ksc 60/120
it needs to run on 2 batteries, but like the tsc can run on one if needed.
come on.  makita has made a 260mm cordless mitre saw (i have one) so it can't be that hard to do.
Offline SilviaS7
« Reply #1161 on: February 02, 2021, 08:32 PM »
A cordless pin (23 gauge) nailer by Festool would be amazing.  Forgive me if it already exists and just isn't available in North America.
« Reply #1162 on: February 03, 2021, 04:27 AM »
it doesnt exist, but if you have milwaukee m12, they are bringing one out sooner rather than later.
« Reply #1163 on: February 03, 2021, 08:39 AM »
ksc 60/120
It’s available soon in, teal... [big grin] Pre-order in AUS: (Soon to come is a 165mm version too)
https://www.makita.com.au/building-construction/combo-s-kits/40v-max-kits/mitre-slide-compound-saws/ls002gm201-40v-max-brushless-216mm-8-1-2-slide-compound-saw-kit
Offline mino
« Reply #1164 on: February 03, 2021, 11:55 AM »
SYS-Powerstation covers that "high end bat vac" use case more than nicely ...
For a VAC to be powerful, it would have to have huge batteries. All the bat vacs out there are pretty meager for this reason - to have some sensible runtime it is the only way.
I have the small one-battery Makita which is really fine but in no way in the "Festool market" price/performance-wise.
For a proper one, if I had the use case, the SYS-Powerstation + Mini and there you go!
« Reply #1165 on: February 04, 2021, 04:33 AM »
ksc 60/120
hummmmm..
i dont need another battery platform............ [unsure] [unsure]  (lets do a quick count, lxt, festool 18v, m12, old B&d, parkside, and probably sommit else.)
but on the other hand, i might pick one up coz u can charge lxt batterys on a xgt charger........  and its a darn sight lighter than the 260mm bohemoth.  that is stupid [censored] heavy.  and that drill is the most powerful on the market, the impact has a zillion and 1 settings, and i have been eyeing up the sds plus with the sucky thing.......
Offline Imemiter
« Reply #1166 on: April 05, 2021, 02:53 PM »
... a twin-battery HKC 185 (7.25" blade) that'll fit on my FSK rails. And cringe if you must, but copy Makita's flipping inner arbor washer so we can use cheap blades.
Offline jcrowe1950
  • Festool Dealer Affiliate
    • Woodcraft Chattanooga, TN
« Reply #1167 on: April 05, 2021, 04:27 PM »
CNC Templates for routing cavities in Kaizen foam for Systainer3s.
Festool Specialist at Woodcraft, Chattanooga, TN
Latest Festool purchase...TID18 T18 set....love them
Offline SDWW2019
« Reply #1168 on: April 05, 2021, 08:38 PM »
It's not a product, but I wish Festool also sold new items directly to customers. While I have received great service from local distributors here in San Diego, it would be so much easier than tracking things down or dealing with the handful of larger dealers online or taking a chance with the smaller guys.
Offline mino
« Reply #1169 on: April 05, 2021, 08:50 PM »
Seconded.
If there was a concern for "competing" with the dealer network, as that is the main reason no to do this, it can be handled by (intentionally) substantial shipping/handling charge.
Especially for the odd accessory here and there, it would me much easier to just click on festool.XYZ, add to basket and have it shipped instead of hunting for a dealer. Especially for the more obscure pieces where it makes no sense to stock them.
This can be combined with a "direct-order for pickup at registered dealer" so that one can leverage the Festool site + central warehouse but still pickup locally.
