« Reply #3 on: August 06, 2019, 03:41 PM »
@htroberts - In a few months Festool will be releasing an updated (rebranded Wera Rapidaptor) Centrotec-shafted
locking bit holder, an update to the disappointing-to-
some BHS 65 CE, that's apparently actually going to be able to lock pretty much any wire detent bit out there into the holder. The problem with the existing BHS 65 is that only some wire detent bits by some manufacturers are compatible (and there's no official list available anywhere to narrow things down). So, assuming the new version works as pre-advertised, you could pick up a set of wire detent nut driver bits like the
set I bought and you'll essentially end up with a decent set of Centrotec nut drivers. I'm really hoping that the improved locking bit holder is as widely compatible as its being made out to be, since I already have the aforementioned nut driver set which I purchased expressly to work in conjunction with the BHS65 CE only to find that they don't actually lock into that holder. We'll see.
« Last Edit: August 06, 2019, 03:43 PM by TinyShop »
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame, stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [n], Hitachi C 8FB (JP) [h]
[po] pre-owned [n] new [h] heirloom (XX) country of origin
