Author Topic: Centrotec nut drivers?  (Read 1908 times)
Offline htroberts
« on: August 06, 2019, 09:04 AM »
I love Centrotec. But... the weakness of the system is the lack of comprehensive driver bits.
Is anyone aware of availability of Centrotec nut drivers?
(yes, I know I can use the 1/4" adapter, but then what's the point of the Centrotec system?)
Offline Alex
Re: Centrotec nut drivers?
« Reply #1 on: August 06, 2019, 10:14 AM »
Here in Europe there is a 1/4'' socket adapter 495131 and a 3/8'' adapter 495133.
Offline blaszcsj
« Reply #2 on: August 06, 2019, 12:59 PM »
you can get the socket adapters in the states. I got mine from toolnut.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
Offline TinyShop
« Reply #3 on: August 06, 2019, 03:41 PM »
@htroberts - In a few months Festool will be releasing an updated (rebranded Wera Rapidaptor) Centrotec-shafted locking bit holder, an update to the disappointing-to-some BHS 65 CE, that's apparently actually going to be able to lock pretty much any wire detent bit out there into the holder. The problem with the existing BHS 65 is that only some wire detent bits by some manufacturers are compatible (and there's no official list available anywhere to narrow things down). So, assuming the new version works as pre-advertised, you could pick up a set of wire detent nut driver bits like the set I bought and you'll essentially end up with a decent set of Centrotec nut drivers. I'm really hoping that the improved locking bit holder is as widely compatible as its being made out to be, since I already have the aforementioned nut driver set which I purchased expressly to work in conjunction with the BHS65 CE only to find that they don't actually lock into that holder. We'll see.
« Last Edit: August 06, 2019, 03:43 PM by TinyShop »
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline yetihunter
« Reply #4 on: August 27, 2019, 01:34 AM »
There are plenty of wire detent nut drivers out there if you do the looking.
However, in a pinch, the Eccentric chuck’s (offset) bit holder happens to randomly be a ball dentent mechanism on a drill/driver system that is (otherwise) specifcally adverse to power bits.   I literally, to this day, have Centrotec, wire dentent and ball detent driver bits (all three) in my T18’s Systainer.
Offline Richard/RMW
« Reply #5 on: August 27, 2019, 08:09 AM »
You nailed it. Love the system but still cannot rely on only centrotec. Worse, @ $12 a whack for the basic 4" driver bits I'm reluctant to use them.
FWIW, so far the only Non-Festool alternatives I've found are the Atlas bits from Toolnut, Snappy's drill adapters and some items @ Axminster.
RMW
Offline Claimdude
« Reply #6 on: August 27, 2019, 08:21 AM »
Glad to hear about the Wera Rapidaptor centrotec compatible offering soon. I have used the Wera Rapidaptor stuff a long time in my Makita drills. Getting real close to relying on my Festool drills only.
Jack
Offline Alex
« Reply #7 on: August 27, 2019, 12:18 PM »
... on a drill/driver system that is (otherwise) specifcally adverse to power bits.
@yetihunter Just curious, what exactly do you mean by this?
Offline six-point socket II
  • formerly @the_black_tie_diyer
« Reply #8 on: August 27, 2019, 04:55 PM »
Hi!
personally, I'd buy a couple of CE nut drivers in a heartbeat if they were available.
One thing to take into consideration: while I see them constantly being used by electricians, HVAC specialists, (and other trades) in North America and parts of Oceania - both with regular drill/drivers and impacts - I have yet to see them being used in Germany to that very same extent. My guess, it would be a very slow seller around here, except for those already available small nut drivers for use with the depth stop chuck.
It's another product that could be made for/ made available to specific/exclusive markets like North America and Oceania.
I think its one of those topics were Festool could improve it's stand. Same goes for the imperial drill bits, square drive bits, (...).
Kind regards,
Oliver
Kind regards,
Oliver
