Author Topic: Batterycharger in a Systainer!!  (Read 3555 times)
Offline amcore
« on: June 22, 2020, 08:31 AM »
I want to see Fast Battery Charger for the 18volt line in a T-Loc systainer, for 2 or 4 batterys.. Maybe whit the base from the Powerhub so there is outlets to? USB outlet and Bluetooth connectivity to check the health of the batterys
Brainstorming now but also a digital display that show how long the charging process go in % instead of a bounch of small lights, also the health of the battery
now i have 8 batterys and 5 chargers and its frustating every time. [huh]
Well thats my tougts  ;D :P..
Festool addicted!
Offline Cypren
Re: Batterycharger in a Systainer!!
« Reply #1 on: July 12, 2020, 07:26 PM »
This is a great idea, and now you've got me mulling over ideas for building a custom version, since I don't think Festool's going to give us a multi-charger anytime soon. Anyone have a suggestion for good sources to find broken tools to scrap for parts? Getting a plug-it port to use for the external power would be ideal.
Offline threesixright
« Reply #2 on: July 13, 2020, 04:04 AM »
Not sure if that  is same thickness as a SYS PH external cable.
Maybe in EKAT you can find a plugit connector. Isn’t  this connector proprietary FT?
Offline jonnyrocket
« Reply #3 on: July 13, 2020, 06:17 PM »
@amcore  I couldn’t agree more. I have 2 dedicated systainers that house my batteries and chargers. Now I make sure these come with me regardless of which tools I grab.
I like the idea about a percentage display...one for the charger hub but also a similar system for the storage case. It would be cool but doubt it will happen.
My current method is to rotate discharged batteries to the back of the case and keep the charged ones in front.
« Last Edit: July 13, 2020, 06:35 PM by jonnyrocket »
Online Bob D.
« Reply #4 on: July 14, 2020, 04:01 PM »
Those Wago lever nuts are great aren't they?
Offline jonnyrocket
« Reply #5 on: July 14, 2020, 06:37 PM »
Wahl Lever nuts are the best thing since ground crimp sleeves :)
Offline SRSemenza
« Reply #6 on: July 23, 2020, 10:13 AM »
Good topic  .... Wago. Should be useful to be able to refer to it easily.
               Split to  here ------> Wago wire connector nuts.
« Last Edit: July 23, 2020, 10:20 AM by SRSemenza »
Offline ToolGuy42
« Reply #7 on: July 24, 2020, 02:17 PM »
This is a great idea!
Offline Gregor
« Reply #8 on: August 04, 2020, 07:47 AM »
I would add a cord grip to the green cable (likely attached to the woordenbaseplate or the systainer iteself) to prevent tripping over a connected plug-it ripping at the cables of the chargers.
