Author Topic: Yet another "Which router should I get" question  (Read 2851 times)
Offline motorhead9999
« on: November 10, 2022, 06:18 PM »
So I'm new to the Festool arena, and I'm a little confused as to which direction I should go with a router(s) purchase.
My interests at this point in getting one is mostly for (non-business) cabinet/shelf/furniture making, chessboards, cutting boards etc.
I (eventually) plan on getting a Woodpecker lift with their 3.5hp router as a dedicated table unit, so I don't think I really need the OF2200. So at this point, I'm a little unsure as to what to get outside of that. I feel like having a small MFK700 would be a nice thing to have to just do edging with, but then I realize that I'll still probably need a plunge/beefier router to do other stuff with. So that brings it down to the OF1400 or OF1010. I feel if I get the 1010, that would eliminate the need for an MFK700, but makes me worry that I'm going too light and should just get the OF1400 instead, and then if I feel I need it, get the MFK700.
any thoughts from everyone else?
Offline woodbutcherbower
Re: Yet another "Which router should I get" question
« Reply #1 on: November 10, 2022, 06:34 PM »
Welcome to the FOG. You join a great group of users with an enormous knowledge base.
As a pro, I have the luxury of four routers, all to do specific jobs. Only one of these is a Festool (an OF2200, the most sublime power tool on the planet IMO), the others are 'foreigners'. I think you'll find that the consensus here is initially to go for the 1400. It's a good all-rounder which will accept both half-inch and quarter-inch collets. Big enough for beefy stuff, small enough for delicate stuff. I'm sure other members with greater specific Festool knowledge and experience will be chiming in any time soon........
Best wishes
Kevin
« Last Edit: November 10, 2022, 06:39 PM by woodbutcherbower »
Offline luvmytoolz
« Reply #2 on: November 10, 2022, 06:51 PM »
If you're buying your first router that's larger than a trimmer, I reckon the 1400 is definitely the lesser of the two best options if the 2200 is out of reach for the moment.
Offline Crazyraceguy
« Reply #3 on: November 10, 2022, 07:04 PM »
Kind of in the same vein as woodbutcherbower, I'm a pro cabinetmaker with what most would call an embarrassment of routers, so my opinion might be a bit biased.
I think you are probably on the right track of having a big router for the table, then looking for others as hand-held.
Since I have all of the Festool routers, except the OF2200, I can tell you that they are all great. It mostly comes down to what you are going to do with them.
If you are sure that you need to have the ability to use 1/2" shank bits in your hand-held router, go with the OF1400. It is very smooth and plenty powerful. The dust collection from it is very good, and there are several attachments included with it to work in different ways.
The OF1010 is a nearly identical unit, that is a little smaller. It is quite a bit lighter, which makes it easier to handle, especially when working over the edge. It also has the ability to work horizontally for flushing edges, with an added accessory. It is limited to 8mm shank bits though. They are available, but not as simple as in stock at the local store.
The MFK700 is more of a specialty router. It has limited travel with the vertical base as well as the opening in the horizontal base, but if you do a lot of edge flushing type work, it's hard to beat. I have two of them for this very reason (again pro, not normal)
It all comes down to what you need to do. If you can do all of your 1/2" shank bit routing at the table, go with the OF1010 and expand your 8mm shank collection.
If you do edge work, the MFK700 is a dream.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
« Reply #4 on: November 10, 2022, 08:20 PM »
If you don’t already have a big collection of 1/2” shank router bits I’d suggest the OF 1100.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #5 on: November 11, 2022, 05:29 AM »
Hi @motorhead9999
If you are new to router work then go small to start with - the Festool OF1010 is the router that I use the most. For a bit more discussion take a look at this:
Offline pixelated
« Reply #6 on: November 11, 2022, 08:08 AM »
I have 3 routers, an OF-1010, a large Porter Cable that live in the router table, and a Bosch colt. If I could only have one it would be the Festool. It’s a joy to use, which I think i high praise for a power tool.
In the US, it comes with 1/4 inch and 8mm collets, I try to buy 8mm bits any time I need a new one, but it’s fine with 1/4 bits too.
Offline SRSemenza
« Reply #7 on: November 11, 2022, 08:58 AM »
 @motorhead9999
         For a general purpose router the 1010 or 1400 is the way to go.
Offline rmhinden
« Reply #8 on: November 11, 2022, 09:05 AM »
I have three routers that get frequent use:
Festool OF-1010 (1/4" and 8mm collets)
Router table w/ lift and PC 3hp router motor
Shaper Origin (uses same collets as OF-1010)
I also have an old Ryobi 3HP router that I can't remember the last time I used it.  It used to be mounted in a home built router table, but at some point I upgraded the router table and got the lift and PC router motor.
I think you will be happy with the OF-1010, especially if you plan to get a router table later.
Bob
Offline JimH2
« Reply #9 on: November 11, 2022, 11:24 AM »
The 2200 is not really suitable for use as an everyday router. Not great for small pieces and you really need to accessory base kit piling even more money into the purchase. I have the Festool router lineup and some non-Festool router and my go to ones are the 1010 and 1400 and sometimes a battery powered Dewalt trimmer. No cord is very convenient. You could split the difference and get the 1400 which is more than enough for most any job.
« Reply #10 on: November 11, 2022, 11:41 AM »
Like the others have said, my go-to is the 1010...probably used 60%-70% of the time. After that it's a toss-up between the 700 & the 1400 and after that the 2200. The 2200 is kept in a table.
Offline jeffinsgf
  • Woodpeckers Marketing Department
« Reply #11 on: November 11, 2022, 04:11 PM »
I am not a professional, but still have an embarrassing number of routers...I can think of 5 off the top of my head, and I'm probably missing at least one. When a job comes up for a hand-held router it is rare that I will reach for anything other than my OF-1000 (predecessor to the OF-1010). If I'm using my OF-1400 it's probably because I don't have 1/4" or 8mm shank router bit for the job at hand. My laminate trimmers haven't been out of their boxes since I got the OF-1010. It's a little bigger, but so much smoother it makes the job more enjoyable. I feel I could easily live with just the OF-1000 and a 3HP table-mounted beast.
« Reply #12 on: November 11, 2022, 05:55 PM »
That's not even close to embarrassing and actually quite easy to justify.
My foolishness is 4 times that, yes 20.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Offline woodferret
« Reply #13 on: November 11, 2022, 06:14 PM »
I come from the Dewalt 611.  Bought a OF1010 and find that to be a good balance.
Setting a fixed depth on a OF1010 isn't as easy as say the MFK700 or the Dewalt where you can just spin up/down.  OF1010 is still at its heart a plunge base.  There is a micro-adjust on the depth stop, so you can dial it in pretty precisely, but it does require several operations of 1) move turret or unplunge, 2) dial, 3) re-plunge.  Unless I want the ergonomics of the OF1010 (omg that trigger control), I will just chuck it up in the DW611.
Offline luvmytoolz
« Reply #14 on: November 11, 2022, 07:41 PM »
I can relate to that! I hate changing out bits all the time and changing height settings, so I have a number of routers permanently setup with specific cutters and height settings that rarely get changed. Out of all of them though, my old OF900E gets used the most for odd jobs that require a 1/4" cutter, the OF1400 for anything bigger, and the OF2200 far less frequently for the really big cutters, or when really hogging material.
It's horses for courses, but having an assortment is extremely handy and a real time saver for me, although I totally get why most hobbyists want to limit the number of power tools they buy. I have of course built up my tools over the 4+ decades so it's been a gradual thing.
Then of course there are the sanders, the grinders, the hammers (I love collecting hammers!), etc! ;-)
I still think though if you had to buy just one router, it would absolutely have to be the OF1400, anything else would be buyers regret at being permanently limited in function, or necessitating another purchase later as I find it inconceivable that anyone buying a tool completely new for them, wouldn't expand their project scope with the new found capability a tool brings.
It's exactly the same as the "which CNC should I get" question, those who "bought the minimum sized one that should do everything I need" invariably wasted money upgrading through at least one or two more larger machines! Ask me how I know!
« Last Edit: November 11, 2022, 07:45 PM by luvmytoolz »
Offline Jim_in_PA
« Reply #15 on: November 11, 2022, 07:44 PM »
I use my OF1400 the most, even though I own the OF1010. Most of my tooling is .5" shank, so that's part of the reason. And a lot of what I actually use a hand-held router for is the more heavier cutting things when I don't do them on the CNC. The OF1010, for me, is more of a "detail" router and that's what I pull it out for when a lighter, smaller plunger is the right tool for the job. I have a yellow fixed base router for things where I prefer the lower center of gravity of a fixed base tool.
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax SC3C, FS350, MM16, Camaster Stinger II SR-44 CNC
Offline Vondawg
« Reply #16 on: November 11, 2022, 08:49 PM »
Well….see…there you have it …who needs the ‘search’  tab…
« Reply #17 on: November 11, 2022, 10:32 PM »
Funny... [smile]
Offline 4nthony
    • Slack for Recon Tools
« Reply #18 on: November 11, 2022, 10:38 PM »
This is my little router lineup:
- DeWalt DCW600. The router I grab for most simple tasks. Dust collection is decent and I have both fixed and plunge bases. If I'm doing any small edge details or light flush trimming, I grab the Dewalt. It sits under my workbench so it's easy to reach and I don't need to unpack it from a Systainer. I've got several Dewalt batteries from other drivers and drills so if it gets low on power, there's always another battery I can swap. Before getting a Domino, this was the router I used for making loose tenon mortises. It's limited to 1/4" bits but for light duty and/or simple work, it's fine. I also made an oversized baseplate that can span the width of most drawer boxes I build so I can soften most edges without the router being tippy on the of plywood.
- Bosch 1617. My first router. I picked up the kit about 15 years ago. It came with a fixed base and a plunge base. Dust collection isn't all that great, especially when compared to the 1400. These days, when I need to use a guide bushing, this is the router I use (though the DeWalt bases also work with threaded guide bushings). The Bosch fits most router lifts and it used to be in my router lift before I swapped it out with a Spinrite motor from Woodpeckers. I'll also use the Bosch when I don't feel like constantly swapping bits on the 1400.
- OF 1400. I bought this a little over a year ago, primarily for it's reputation it has for superior dust collection. The dust collection is great, especially when you're able to use the chip catcher. Unfortunately, some models have issues with guide bushing drift. It's well documented here on FOG and elsewhere. One of these days I'll get around to making a baseplate that'll work with threaded Porter Cable style guide bushings, but until then, I'll continue to use the Bosch or DeWalt. I don't know the exact specs but I believe the 1400 and the Bosch are in a similar power class. The 1400 really shines when combined with other accessories in the Festool system. I love using it paired with guide rails. The ratcheting spindle is also a nice to have feature. It's a really great router.
I've considered getting a 1010. I haven't used one but I would guess the dust collection is on par with the 1400. One thing I like about the 1010 is it accepts threaded guide bushings directly and there's no need to use the click-in adapters that have caused problems on my 1400. The 1010 works within the Festool system so there's also that.
For the type of projects I do -- household DIY, cabinets, small furniture, and built-ins (just for me and/or friends) -- the DeWalt and the 1400 are nice complementary tools that each have their place in my shop.
Good luck making your decision!
Recon Tool Notifications
Anthony
« Reply #19 on: November 11, 2022, 10:59 PM »
4nthony brings up an extremely valid point that's missed most of the time unless of course you get bit by it.
The 1400 and 2200 routers have "self centering" guide bushings that sometimes center themselves, but they will ALWAYS uncenter themselves when enough lateral pressure is applied to the router.
The 1010 guide bushings on the other hand, need to be manually centered which is great for inlays and precision work.
Offline Oilers
« Reply #20 on: November 11, 2022, 11:38 PM »
I have three routers I use freehand.  A Bosch Colt, a Bosch 1617 plunge/fixed kit, and an OF2200.  I have a 3 1/2hp Milwaukee in a lovely Jessem table with an integral lift.
The Colt gets used where I have to use 1/4 bits, i.e. fine detail or tiny edge profiles/trims.  But I almost never use the colt if I can help it. It’s great, but specialized.
The 1617 is a 2 1/4 hp unit and it was my primary router for a long time.   It’s fine.  It’s fiiiine.  I used it in my old rudimentary router table.  I can set it up for precise cuts or run it on straight edges for straight cuts, it just takes longer than the OF2200.  It also bogs down unless used at slow feed ratesor shallower cuts than the OF2200.  It’s louder pitched than the 2200.
My Milwaukee/router table set up is a joy.  All the power, all the safety.  Read a good quote somewhere: the smaller the work piece the bigger the machine you need.  I can do big and small with that setup and it’s accurate, adequately powered, and safe.  I’d don’t used routers freehand with small workpieces.  Routers scare me the most of my many tools, I treat the with respect and clamp/block/jig/vise as I think safe.
The OF2200 puts a smile on my face when I use it.  It’s got power which, properly used, is a safety feature.  It’s dust collection is a marvel.  It is easy to dial in.  Honestly, one of my favourite tools to use and I’ll choose it every time I can if I can’t use my router table (unless it is a trim router job).  I haven’t used my 1617 since I got the OF2200.  The 2200 cuts smooth as butter and spins bits in a way that feels safer than the 1617.
The only “downsides” of the OF2200 are size/weight and cost.   I’m a big fella, the OF 2200 is objectively large and heavy.  I find that a feature, not a bug.  More mass means safer for the spinning of bits, power for days.  Cost?  It’s a Festool.   I think the costs are a bit overboard, but I do love it.
As you’ve read, no one has just one router if they’ve been doing this for any amount of time.  As one other poster said, the OF2200 is one of his/her favourite tools.  It might not be my #1, but it’s up there.  If I could have just two freehand routers, I’d probably have my 2200 and then it’d be a real choice between another Bosch colt style router for cost/utility and the 1010.  I love, absolutely love, the Festool dust collection.  But for 7 times the cost, I can clean up the tiny shavings a palm router throws.
Interjection:  I always use a 1/2” bit if I can.  They’re more stable (safer/less chatter/more forgiving/handle knots better), leave cleaner cuts, and have lasted longer (for me).
So, I’ll answer your question with more questions:
1.  What size bits are you planning on running?  Given your projects, sounds more like 1/2” shank and multiple profiles.  You can downsize a Cooley, not upsize a motor.  Also, given your stated router table intentions, you’ll have a lot of 1/2” shank bits there.    Go 1400/2200 and avoid buying multiple buts if the same profile for different shank sizes.
2.  Are you strong/comfortable with big tools?  Don’t take this as a manliness tough guy challenge.  The one friend I have (also a hobbiest) that runs a 2200 is in his 50s and slightly taller than me.  We both have no problem with the 2200 and appreciate its mass size.  The 2200 is thiccc.   But if you want a sports car, not a truck, get the 1400.  If you want to haul bits and chips, get the 2200.  If you want a SmartCar, get a 1010 or equivalent.
3.  Are you trying for just one router?  The 1400 might be your huckleberry.   It’ll do most everything, and it will do most of what you need well. It’ll be clumsy for some smaller jobs (take those to the table where you can) and it can’t spin bigger bits (again, table if possible).  But I bet you wind up with a colt style /1010 at some point in the future.
4.  What is your dust collection setup?  If you’ve got a festool/Hilti/proper high end dust collection setup, get a festool router. If not. Heavily consider dust collection as part of your near future needs.  Routers are messy.  If you’re going to be removing material, not just making a few shavings, go big as you can for the router and get serious dust collection.
5.  Buy good bits, don’t cheap out and burn up your work after long prep by using non-carbide bits from questionable brands.
Be safe.   All routers can bite.  Do you know where your fingers are?
Offline Sometimewoodworker
    • Jerome's  Other work
« Reply #21 on: November 11, 2022, 11:57 PM »
- OF 1400. One of these days I'll get around to making a baseplate that'll work with threaded Porter Cable style guide bushings,
Why reinvent the wheel?? Why not buy the baseplate that is designed for exactly that?
Jerome
TS55, OF1400, Elu MOF96, Rotex150, DTS400, ETS150/3 Domino, MFK700, CXS, HL 850, Trend T11, Makita LS1212, Original Mini CV06 Cyclone, Workshop supplies drum sander, & WoodRat. Don't have don't want list: MFT
http://www.flickr.com/photos/nui-jerome/
Offline hdv
« Reply #22 on: November 12, 2022, 05:17 AM »
Because the clip-in rings do allow for lateral movement, as shown many time before on this forum. It is an unavoidable property of how they are attached to the router.
« Reply #23 on: November 12, 2022, 08:30 AM »
Exactly. The feature that allows for quick and easy insertion/removal also allows for the collar to move too easily.
I would assume that what 4nthony was suggesting is a separate base plate with a P/C style opening.
« Last Edit: November 12, 2022, 05:55 PM by Crazyraceguy »
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Offline woodferret
« Reply #24 on: November 12, 2022, 09:26 AM »
FWIW, the DeWalt and Makita trim routers can be equipped with 8mm collets, so there's some wiggle room and overlap with the 1010s.  About the same class spindle.
Offline Coen
« Reply #25 on: November 12, 2022, 09:30 AM »
Meh, I have the 1010 and the 1400, but for edge routing both too easily tilt on the corners as it's nearly impossible to hold the perfectly flat on the tiny portion of the base that is on the workpiece and the giant hole in it. I am looking to buy an MFK 700 now.
Offline Oilers
« Reply #26 on: November 12, 2022, 09:56 AM »
A smaller router hasn’t resolved this issue for me.  Can gouge a profile just as easily with my colt, the blemish is just typically smaller.  I’ve taken to using an extended baseplate that reaches to other parts of a carcass, clamping the edge flush to a bench, or clamping a wider board to the workpiece for a flatter, more stable workplace.   I’ll do one of the three regardless of router size.
Offline 4nthony
« Reply #27 on: November 12, 2022, 10:54 AM »
I'm thinking to make something along the lines of the Infinity Tools Baseplate. A proper baseplate that is larger than the router base and has a hole perfectly sized to the guide bushings to prevent any drift. The Festool clip is just an adapter and not a baseplate.
Yes and yes [cool]
Here are some references on guide bushing movement.
https://www.festoolownersgroup.com/festool-tools-accessories/of1400-guide-bushings-and-what-exactly-is-the-problem-and-solution/
https://www.festoolownersgroup.com/festool-tool-problems/router-model-1400-centering-a-guide-bushing/
https://www.festoolownersgroup.com/festool-tool-problems/festool-of-1400-guide-bushing-adapter-movement/
https://www.festoolownersgroup.com/festool-tools-accessories/of1400-are-centering-issues-still-a-concern/
Even with the guide bushing movement, it's still a great router to work with in every other scenario.
Anthony
Offline 4nthony
« Reply #28 on: November 12, 2022, 11:06 AM »
Yep. This works great.
Anthony
Offline Coen
« Reply #29 on: November 12, 2022, 01:43 PM »
Yes it's not about the size of the router, but about the dimension of the hole in the base and the presence of a larger base that allows to put pressure on one side. Like the OF 1010 and 1400 lack, but the MFK 700 has. That extended base for the OF-1010 is no longer in the catalog.
Offline Bob D.
    • My Cordless Workshop
« Reply #30 on: November 12, 2022, 02:34 PM »
"Yes it's not about the size of the router, but about the dimension of the hole in the base and the presence of a larger base that allows to put pressure on one side. Like the OF 1010 and 1400 lack, but the MFK 700 has. That extended base for the OF-1010 is no longer in the catalog."
For the DeWalt and Makita compact routers my Control Grip can help by allowing you to apply more force on the supported side of the router offsetting the imbalance. This happens without thinking, it's a function of the shape of the grip and placement of your hand.
The DeWalt grip also includes my Plunge Lockout feature.
Both are available in the standard finish and what I call the 'Fuzzy' grip which has a lightly textured finish that some prefer for a little more grip.
You can read more about them here:  http://cordlessworkshop.net/router-control-grip-handles.shtml
Offline Coen
« Reply #31 on: November 12, 2022, 03:11 PM »
The MFK 700 form factor is still way way superior for edging.
Offline Bob D.
« Reply #32 on: November 12, 2022, 03:56 PM »
True, but it costs way, way more. Like >25x more. And it has no plunge capability.
« Reply #33 on: November 12, 2022, 06:02 PM »
100% agreed. That is the exact reason I have one. It is just fantastic for flush trimming edges.
Plunging is not needed in this application. It's all about adjusting the base to the bit and setting the cut depth with the follower wheel.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
« Reply #34 on: November 12, 2022, 06:08 PM »
After everyone's time and input = please don't let this be yet another thread where a new OP asks a question and then evaporates .....
« Reply #35 on: November 12, 2022, 06:12 PM »
That does seem to happen with a lot of first post questions, doesn't it?
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Offline Coen
« Reply #36 on: November 12, 2022, 06:38 PM »
Yes, that's why I don't have it yet. My mind it torn between the 12V Bosch router that costs 1/4 as much... but has no dust extraction.
You mean the OFK 700? I do like radius routing a bunch and with the 1010 it's hard to prevent it tipping into your workpiece on the edges.
Offline Bob D.
« Reply #37 on: November 12, 2022, 08:19 PM »
"It is just fantastic for flush trimming edges."
It is, can't be beat.
But I didn't think that was a requirement of the OP when he asked which router to get. Guess I missed that.
« Reply #38 on: November 13, 2022, 09:23 AM »
No, the entire OFK series is unavailable here. I use the MFK700 with the zero degree base.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Socket/Ratchet set
« Reply #39 on: November 13, 2022, 03:09 PM »
The reports of my demise are greatly exaggerated. Things got busy on my end with the hurricane that passed over me (no damage, just some yard cleaning up and unprepping all the hurricane prep).
I think at this point, I'll be leaning towards the 1400, but I'm still on the fence about the mfk700 as an addition
1) Honestly, I haven't given much thought to that. Ideally (as you state), I'd get one shared set I can use elsewhere.
2) I'm semi comfortable I guess. I'm a bit of a smaller guy, so ergonomics can be a factor. I have a Bosch sliding compound miter saw, and I'm fairly comfortable  with that. I don't really need the power or size of the 2200, and the 1400 seems a bit of a better fit for me
3) I'd like to keep my tools to the smaller quantity I can. I recognize that I'll probably save the super powerful router motor for a table, and a non-festool product. But in terms of hand held, I'd like to keep it as close to 1 as I can. I mentioned I might get a mfk700 as a compliment to the 1400
4) Dust collection is non-existent at this point. I'm in between houses at the moment, so I'll probably think about that more once I'm in a new place and can think layout a bit better.
5) One of the most important lessons Harbor Freight taught me is never go cheap on sharp things that spin that are meant to cut something.
I do my best to always make sure that my fingers are nowhere remotely close to a blade. I know routers are often considered a higher danger item.
Offline luvmytoolz
« Reply #40 on: November 13, 2022, 03:34 PM »
The 1400 is a fantastic and versatile choice, but unless you plan on doing a lot of edging/benchtops, the MFK700 would probably be of less value than getting a 1010 I would suggest, just to have a lighter one handed router for the smaller stuff.
I have the 700 because I was offered one very cheap, and on the infrequent occasions I need it, it's extremely useful, but it spends most of it's life sitting in the box on the shelf compared to my OF900 and OF1400.
Offline Coen
« Reply #41 on: November 19, 2022, 01:26 PM »
Well, even your bed spends the majority of it's time unused.  [wink]
Offline luvmytoolz
« Reply #42 on: November 19, 2022, 06:12 PM »
True, but I'd imagine it's pretty rare you'd see someone collect 35 beds with different performance parameters and accessory kits so probably not a true comparison!;-)
Offline Vondawg
« Reply #43 on: November 19, 2022, 07:10 PM »
Let’s be real we have an awesome “ search” but as long as members wax on about questions that have been asked many times, sometimes several paragraphs, it will continue….the search button might as well be removed…then the OP disappears…I just move on to the next post…..but I guess we wouldn’t be here otherwise
« Last Edit: November 19, 2022, 07:18 PM by Vondawg »
