Author Topic: Woodpeckers Parallel Guide System now available permanently  (Read 3170 times)
Offline rexacademy
Woodpeckers announced today that their parallel guide system has become a permanent product: https://www.woodpeck.com/parallel-guide-system.html
I've been keeping an eye out for a reasonably priced used set to pick up, but haven't found one—excited to finally pick it up!
Offline StanB
Re: Woodpeckers Parallel Guide System now available permanently
« Reply #1 on: January 09, 2019, 12:26 PM »
I would be curious if this is the updated design with the wedge lock for how it attaches to the rail. All of the pictures indicate the original design. Originally this system had reputability issues and Woodpeckers issued an update in the form of a long bar similar to what TSO is doing for its rail connectors.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM SET | MX 1200 E MIXER | DF700 XL
Offline Mario Turcot
« Reply #2 on: January 09, 2019, 12:28 PM »
Yeah, I received the newsletter this morning. The Woodpecker parallel guide price is similar to the Festool one. 400$ versus 423$ for the Festool. The Festool PG have an extension guide to add to it, not the Woodpecker PG.
I'm wondering if the Woodpecker one is more versatile and easier to use. I watched a video of both and I'm still not convinced.
Mario
Offline StanB
« Reply #3 on: January 09, 2019, 10:37 PM »
I have one. It’s similar to the other aftermarket ones. I have used it on occasion to cut large panels, however since the TSO rail square came out it has mostly sat in the systainer. All these parallel guides are all finicky to set up, but do work well whenused. Personally, unless you do a lot of panels or don’t have a table saw I would just get the rail square. It is much easier to just use a tick mark and use the square. It is a very accurate method.
Offline dlu
« Reply #4 on: January 10, 2019, 02:20 AM »
I don't have a table saw (been trying to avoid committing the space) and have been mostly pretty happy with the PGS. My biggest complaints are:
  • The stops are hard to get tight and tend to work loose.
  • The rail attachment is kind of clunky - it's harder than I'd like to get them on and off.
  • The foam insert in the Systainer is fine for shipping, but means that you have to break them down more than is ideal for frequent or convenient use. For example you have to take the rail attachments off. There is room in the case to store them with the first hunk of scale mounted to the rail attachment, but for some reason they didn't decide to do it that way.
On the other hand, I really like the short sections of scale, they make the PGS much easier to work with it tight quarters.
Offline TSO Products
    • TSO Products
« Reply #5 on: January 10, 2019, 09:22 AM »
look for TSO's new TPG-30 R Parallel Guide shipping in February.
Our extensive on-the-job BETA testing by  Pro and DIY woodworkers resulted in this innovative answer to the limitations and shortcomings of the parallel guides on the market up to now.
Look for an announcement shortly in the TSO Insider Newsletter and also in a separate post here on the FOG.
Hans
TSOproducts.com
Offline cpw
« Reply #6 on: January 10, 2019, 09:49 AM »
I totally agree that the foam cut Woodpecker's does is great for shipping, but is suboptimal for actually using it.  Definitely too much disassembly is required.
Online Richard/RMW
« Reply #7 on: January 10, 2019, 03:00 PM »
Hans, here's my own not-so-innovative answer...
Your squares have spoiled me, I stopped using 2 PG's as soon as I got one. I'm certain whatever you put out will be even better.
RMW
Hans
« Reply #8 on: January 10, 2019, 03:17 PM »
Hans
Hans, you a real tease  [tongue]
Try to publish some info while we wait would you... I spent 15 minutes googling TPG-30  [mad]
Mario
Offline wpz
« Reply #9 on: January 10, 2019, 03:20 PM »
I did something similar to RMW:
wpz
Offline justaguy
« Reply #10 on: January 10, 2019, 05:17 PM »
Hans
Same here  [big grin]
