Author Topic: Which sander for tabletops?  (Read 1233 times)
Offline Acarper76
« on: January 13, 2020, 07:42 PM »
I am using a Bosch orbital sander and I’m getting swirls regardless of how I move through the grits. I want to use a festool. Which model is best for
Tabletops?
Offline Alex
Re: Which sander for tabletops?
« Reply #1 on: January 14, 2020, 02:47 AM »
Offline Gerald_D
« Reply #2 on: January 14, 2020, 07:27 AM »
Agree with Alex- RS-2 is the best sander for this purpose.  It's a beast so I only pull this out when I'm doing large flat surfaces, but the beefiness makes it a joy to use- once you set it on the surface you let the sander do the work.
Regards,
Gerald
Gerald
I have Festools- Big and Small and a few other tools
Offline Mike Goetzke
« Reply #3 on: January 14, 2020, 08:36 AM »
Since you are getting swirls - are you using dust collection?
Offline Acarper76
« Reply #4 on: January 14, 2020, 08:53 AM »
Do I have to use another sander first for the heavier grits?
Offline Acarper76
« Reply #5 on: January 14, 2020, 08:54 AM »
I am getting little pigtail swirls, I have a dust collection bag but I’m going to buy the festool dust collector.
« Reply #6 on: January 14, 2020, 10:18 AM »
That's why I asked - years ago I had these issues when not using good quality paper and no active dust control. Sometimes grit is left behind and causes these marks you describe.
« Reply #7 on: January 14, 2020, 10:28 AM »
Tabletops?
Too little information, unless you just want to buy another sander.
I use a couple of Bosch RO sanders with good results.
Dust collection? Too much suction?
Offline Dogberryjr
« Reply #8 on: January 14, 2020, 04:43 PM »
This. I was getting those swirls, reduced suction on the DC and ::poof:: gone.
« Reply #9 on: January 14, 2020, 05:42 PM »
I read too fast, Mike is on the right track, dust and grit debris from the previous grit needs to be thoroughly removed before starting the next grit. You need a dust extractor to get the surface clean. Ideally you’ll get a dust extractor that allows you to reduce the suction in order to prevent the abrasive from digging too deep.
Even with my Bosch sanders I find it sufficient to increase the grit in 50% increments,
for example, 60 to 100 to 150 to 220 to 320. Or 80 to 120 to 180 to 240. It’s better to jump les than too much. I decide which grit schedule based on the final grit needed for the finish and make adjustments at the lower end (coarser grits).
Offline Bert Vanderveen
« Reply #10 on: January 14, 2020, 05:47 PM »
That will be the Festool RS 2 sander. Large and flat for big surfaces like tabletops.
https://www.festoolusa.com/products/sanding-and-brushing/direct-drive-orbital-sanders-for-fine-sanding/567696---rs-2-e-plus-usa#Overview
Funny: the RS 2 is called RS 200 in Europe. On the US website the same images are used as on the German, but there has been done some very sloppy Photoshopping to change the labeling : )
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950
Offline kcufstoidi
« Reply #11 on: January 14, 2020, 05:52 PM »
 While you can get swirls from any sander with improper technique you asked about getting a Festool sander for table tops. The RS2 has been recommended but personally I do tabletops and large flat surfaces all the time using an ETS 150/3 or ETS EC 150/5. Both with a hard blue pad which is the key to keeping the tops flat. IMHO the ETS EC/5 is a much more versatile sander that will achieve the same finished product with proper use.
Offline Alex
« Reply #12 on: January 14, 2020, 06:33 PM »
Where'd you find those pictures? The pictures in my link to the US website show the real RS 2, which has a different top shell (the black part) than the RS 200. That's no photoshop.
« Reply #13 on: January 15, 2020, 06:05 AM »
These pages:
https://www.festool.de/produkte/schleifen-und-buersten/rutscher-fuer-den-feinschliff/567764---rs-200-q#Übersicht
https://www.festoolusa.com/products/sanding-and-brushing/direct-drive-orbital-sanders-for-fine-sanding/567696---rs-2-e-plus-usa#/Accessories
Note the similarities between the two side shots: same bottom halves, etc. Lettering changed and contour of handle reshaped.
(I tried to post a picture, but it doesn't work…) == Well, it did, don't know what mojo is happening.
Offline Alex
« Reply #14 on: January 15, 2020, 06:12 AM »
ROFL, that's indeed a photoshop. Pretty disgraceful if you ask me, you should always show your buyers exactly what they get.
They can tell a guy to do some photoshopping, but they can't tell a guy to make some pictures. Sad.
Offline Marven
« Reply #15 on: January 20, 2020, 05:17 PM »
Here are a couple of great videos.
And this table top in action.
