Author Topic: What tool for renovating furniture  (Read 5819 times)
Offline Packard
Re: What tool for renovating furniture
« Reply #30 on: October 22, 2022, 09:45 AM »
Not every “restoration” needs or deserves to protect the original patina.  The former owner of my house added a sunroom and in the process removed two of the 70+ years old exterior doors.  The photo at the top shows what the door looked like before I attacked it.
About 4 hours of scraping with a hand scraper and probably 10 hours of sanding (random orbital and hand block sanding plus hand wiped poly resulted in an interior door that I felt I could re-introduce to the house.
So while I took away some originality, doing so made it presentable (by my standards) to restore to the home in a different capacity.
Until Zulan defines “restoration” we don’t know what to recommend.
Offline derekcohen
    • In The Woodshop
« Reply #31 on: October 22, 2022, 10:58 AM »
This is not apples vs apples.
Also, upcycling furniture is not restoration. You can do what you want when upcycling because the originality is deliberately destroyed, to be replaced with something new. Sand away!
So be sure to use the appropriate terminology. Restoring aims to be true to, even retain, originality. Sanding must be done judiciously.
Visit www.inthewoodshop.com for tutorials on joinery, hand tools, and my trials and tribulations with furniture builds.
Offline Steve1
« Reply #32 on: October 22, 2022, 03:01 PM »
Sanding isn't the primary way to do "stripping" of old finish. A chemical stripper is always the best bet as sanding can very often damage furniture in ways that are hard to recover from, especially with a lot of use of veneer over both solid wood and composite substrates.
OP may want to check out John's Furniture Repair on Youtube.
She always uses chemical strippers.  She has a "Shop Tour" video that discuss the various strippers, finishes, etc that she uses.
Offline Packard
« Reply #33 on: October 22, 2022, 03:15 PM »
[quote author=derekcohen link=topic=64609.msg678836#msg678836 Sand away!
[/quote]
I agree.  But we still don’t know how the O.P. Is defining “renovating” and if that means “restoration” or something else.
We need more context; more information.
There is a show on Motor Trend TV about restoring Mopar automobiles.  One episode spent most of the hour long show debating whether the car should be left all original and just cleaned up or if it should receive a full restoration.  There were good arguments on both sides.
As I recall they cleaned it us as a “survivor car”, though I suspect most buyers would prefer a pristine new looking and running version over the authentic “survivor” version.
I think, until you get to really valuable antiques that are largely irreplaceable, it is just a matter of what you want in your home.  Or if it is really valuable, and you don’t treasure it, then sell it and buy what you do like.
Offline ChuckS
« Reply #34 on: October 22, 2022, 03:53 PM »
Agreed. Upcycling is something else.
Renovating is NOT restoration either, whether we go by a dictionary definition or this: https://ultimaterenovations.com/what-is-the-difference-between-restoration-renovation/
By renovating, I can only assume that the OP is meaning to do whatever he wants without regard for the original color, shape or condition.
Furniture restorer Thomas Johnson usually doesn't use a sanding block when hand-sanding to avoid altering (flattening) the original shape.
Offline Willy Eckerslike
« Reply #35 on: October 22, 2022, 05:51 PM »
Given that the OP asked this question almost two years ago and hasn't been active since then I wouldn't hold your breath waiting for clarification.
My late father was a professional wood carver and furniture restorer.  I'm not even sure he owned a sander.
Upcycling, in the UK at least, appears to be a licence to part people that really should know better with vast sums of their money for some tarted up tat that I would think twice about using for firewood.
« Last Edit: October 22, 2022, 05:53 PM by Willy Eckerslike »
