Author Topic: What size extruded aluminum is this? Benchdogs.co.uk  (Read 851 times)
Offline KelleyCrafts
I have this MFT fence from Benchdogs.co.uk and it has an under tail piece but I don’t have a way to attach it to the main fence.
There has to be an item in the US that won’t take two weeks shipping that I can buy. A lot of you work with this type of stuff so hopefully someone can help.
Thanks in advance.
Offline savsuds
Re: What size extruded aluminum is this? Benchdogs.co.uk
« Reply #1 on: June 26, 2020, 10:57 PM »
I am not 100% sure if the bigger part is 20x40mm extrusion. If you measure it and it is 20x40mm, you can try this: Extension piece
Hobbyist just trying to have fun and not let my OCD ruin it for me.
« Reply #2 on: June 26, 2020, 11:10 PM »
Thank you!!! 20X40 was it. I never had to measure the stuff or work with it so I was clueless. Thanks! Ordered the straight line connector.
Offline savsuds
« Reply #3 on: June 27, 2020, 12:34 PM »
You should email them. If you recently got it, it should have had one under the small piece.
« Reply #4 on: June 27, 2020, 04:32 PM »
This has actually been about a three month journey getting parts from them to make this work and be accurate. Even this one with the little part attached is not correct on the scale, I fixed it on the grinder and I don’t want to wait another two weeks on top to get the connector. They have been really kind but not really quick so I’m just going to roll with what I have for now. The connectors should be here today so I’ll give them a shot.
Thanks again.
