I'm using the Conturo with 22mm x 1mm PVC edge banding on 18mm boards.
I've noticed that one of the glue lines is right at the face surface. When I trim the edges using the MFK700 EQ/B with the Festool 1mm radius bit it doesn't clean up all the glue but al ot sticks to the surface of the router bit and then some gets deposited on the face of the edge banding. I then need to clean up a lot of glue off the face and edgeband using the carbide blade.
I've tried turning down the amount of glue. But this gets to the point where the edgebanding hasn't adhered enough.
I tried moving the router quicker, and also slowing down the speed. I use vacuum extraction on the router. But I don't seem to have found away around it.
Any tips? Is there anything that can be sprayed on the router bit to stop the glue sticking and making a mess?
-Simon
