Author Topic: What RO90 pad for polishing gelcoat?  (Read 769 times)
Offline GarF
« on: October 13, 2021, 01:55 PM »
The gunwales of my laser dinghy need gelcoat repairs over the winter. I'll make a custom block to hand sand the profile after the initial build up. Once it's wet sanded to P1000 I'm hoping I can use my RO90 to finish the job with farecla G3. My 150mm ROS is far too big for this job - the profile is only about 30mm wide. Can anyone recommend what pad or foam I need for the compounding?
Cheers
G
Offline leakyroof
Re: What RO90 pad for polishing gelcoat?
« Reply #1 on: October 15, 2021, 01:39 PM »
Festool sells 80mm pads for polishing usage with the RO90, AND, they are discontinuing some of them, if not all of them. Check your local dealer for current info.
 But, others sell similar sized pads worldwide, so all is not lost.... [wink] [wink]
 Buy the 80mm pad you want, in the style you want. So, fine foam or honeycomb foam for light polishing or waxing.
 Medium foam, usually it's Orange among many of the pad makers, for heavier polishing or compounding.
 There's also sheep/wool pads available in small diameters with a Velcro backing, you can check with Auto Body Supply shops or houses since small or spot polishers are REALLY popular with Auto Body people right now, and stock of the small 2" or 3" velcro pads is usually pretty good.
Offline Chainring
« Reply #2 on: October 15, 2021, 09:29 PM »
Green pad from Festool. For the foam or wool pad, suggestions on this board might help, but I'd probably expand your search to something like the forums at autogeekonline.net.
« Reply #3 on: October 15, 2021, 10:52 PM »
Unfortunately, Festool doesn't offer a green pad...yellow, orange, blue, white and black.
Along with that line-up, Festool has discontinued all of the waffle pads in every size except for the black items. Then again, black pads were only offered in waffle style.
So, if genuine Festool pads are your thing, then now's the time for you to grab the bit. What's in inventory is what's available as Festool is allowing the existing inventory to die without replacing it.
As mentioned, Autogeek.net is another viable supplier of pads along with 3M, Swissvax and Lake Country.
https://www.autogeek.net/bupo.html
https://www.autogeek.net/3mautapprod.html
https://swissvax.us/collections/accessories?page=2
https://www.autogeek.net/lakecountry.html
Offline Spandex
« Reply #4 on: October 16, 2021, 04:44 AM »
I think they were probably referring to the backing pad (495625), which is green.
« Reply #5 on: October 16, 2021, 09:24 AM »
Gotcha...however that brings up the question of will Festool also be discontinuing the hard green backing pads for their Rotex sanders?
Offline Crazyraceguy
« Reply #6 on: October 16, 2021, 10:40 AM »
Yes, quite a conundrum. If the stop producing the actual buffing pads, why would they continue to make the mounting backer either? But, then again, lots of companies make sanders while not making the abrasives that they require?
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
Offline GarF
« Reply #7 on: October 16, 2021, 11:06 AM »
Thanks, I'll find out what stock is available here in UK. I'll have to do some more research to figure out which grades of foam pad I'll need to get from the 1000g silicon carbide to the final finish
Offline Spandex
« Reply #8 on: October 16, 2021, 05:26 PM »
I find N&B (www.powertool-supplies.do.uk) to be one of the cheaper online dealers and they appear to have stock of the foam pads:
https://www.powertool-supplies.co.uk/polishing/polishing-pads/polishing-pads-80-mm/
They also seem to have the backing pad:
https://www.powertool-supplies.co.uk/festool-fastfix-polishing-pad-pt-stf-d90-fx-ro90.html
Offline Chainring
« Reply #9 on: October 16, 2021, 08:37 PM »
Yep, exactly that one. I have it and the one for the RO 150. From what I understand, those are the official pads for polishing duties.
