Author Topic: What is your setup for grooving for back panels?  (Read 1978 times)
Offline kifi
« on: July 17, 2022, 03:59 PM »
Question more aimed at pros - what is your setup to groove side panels and top/bottom in order to accomodate a back panel? In terms of the back panel groove, I mean something about 8-10mm wide, that is offset about 15mm in from the edge
Offline woodbutcherbower
Re: What is your setup for grooving for back panels?
« Reply #1 on: July 17, 2022, 04:56 PM »
Quarter-inch router, 2-flute cutter and parallel guide. You’ll need either 4, 6, or 9mm cutters because that’s what thin sheet material such as MDF actually comes in.
« Last Edit: July 17, 2022, 04:59 PM by woodbutcherbower »
Offline Mini Me
« Reply #2 on: July 17, 2022, 07:46 PM »
Table saw
Offline tsmi243
« Reply #3 on: July 17, 2022, 08:14 PM »
Both.  Either.
If you're using 6mm ply, a 1/4" box joint blade in a tablesaw leaves a nice amount of wiggle room
Offline ChuckS
« Reply #4 on: July 17, 2022, 09:02 PM »
What's the size of your case?
A router can do any size, but not the table saw as the table top may not be big enough to handle the stopped rabbets or grooves.
Elsewhere on another forum, someone just reported a serious injury to his hand while trying to cut stopped dadoes on the table saw (not a SawStop). Avoid doing stopped cuts freehand.
Offline SRSemenza
« Reply #5 on: July 17, 2022, 09:15 PM »
I use a router with edge guide. Just use the size bit that matches the plywood thickness. If my box is 18mm thick I go 8mm deep. Generally 12 - 18mm from the back edge depending on the install situation for nailers or French cleats, etc.
 I route them all the way through instead of making them stopped. I do top, bottom, and sides. Unless there isn't some other cabinet part to hide the open ends of the grooves , I see no reason to do stopped. It's faster and easier to go all the way through end to end.
Offline Crazyraceguy
« Reply #6 on: July 18, 2022, 08:10 PM »
The only real need, cabinet wise, is on upper cabinets. Base cabs and drawer boxes, yes, I run them all the way though too. I generally do this with the router table. It gives great control over stopped dados.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Offline usernumber1
« Reply #7 on: July 19, 2022, 02:17 AM »
I would think the pros are using CNCs as much as they can
« Reply #8 on: July 20, 2022, 07:40 PM »
Absolutely, but there are times where a simple one-off is just easier to do manually. The CNC excels at multiple and oddly shaped parts though.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
Offline simonh
  • Hobbyist / Maker of the VCS-R
« Reply #9 on: July 21, 2022, 04:04 AM »
I'm not a pro... But when I'm doing lots of cabinets I set up the router table with a spiral bit of the desired groove size, set the fence offset and just batch them through on the router table.
-Simon
