Author Topic: What Festool Did You buy Today?  (Read 785159 times)
Offline Crazyraceguy
Re: What Festool Did You buy Today?
« Reply #2400 on: September 10, 2022, 05:20 AM »
Fixed the Pic, don't know what happened. It's the Wera style handle, but you can tell by the pic now.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Offline Muttley000
« Reply #2401 on: September 10, 2022, 09:30 PM »
I picked up the FS-HSK sanding block in the harder version.  It’s the least expensive festool I’ll ever buy lol
ETS EC 150
TS55 FEQ
CT 36
Offline squall_line
« Reply #2402 on: September 10, 2022, 10:33 PM »
I got the Centrotech bit set came today. It will go along with the longer bit holder and the manual driver handle that I got a week or so ago.
It seems the attachement is zero-size.
Did you get an actuall full Centrotec shaft driver, so it can accept the angle chuck etc., or the newer "direct" Centrotec holder ?
I am by now thinking of making a handle for the BA-CE Drill Adaptor so can use the angle and excentric chucks with it. Cannot seem to find the "shaft+chuck" handle anywhere.  [sad]
I had to buy an old, used (but well taken care of) 1/4" ratchet set CE to get the "full Centrotec driver" that accepts the centrotec chuck, right-angle, etc.  They're rare as hen's teeth now that FUSA stopped importing them (and/or Festool as a whole stopped making them).
I also have one of each of the other newer Centrotec-ish drivers.  Each one has a plus and minus depending on the task for which I am using it.
« Reply #2403 on: September 11, 2022, 05:18 AM »
The thing I was surprised by is the holding mechanism. It has a really strong magnet and apparently some kind of ball/spring to hold the groove, but it doesn't actually contact the round area that is the "stabilizing" part of the Centrotech chuck.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
Online Cheese
« Reply #2404 on: September 11, 2022, 09:30 AM »
Is this the driver you guys are talking about 495228?
« Reply #2405 on: September 11, 2022, 10:35 AM »
No, that's the one that holds an actual Centrotech chuck.
The one I got is like this
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
Offline squall_line
« Reply #2406 on: September 11, 2022, 10:40 PM »
Here's the three I have.
From top to bottom:
Centrotec handle from an OG 1/4 CE RA Set 37 (in a Classic Mini Systainer)
Centrotec handle from Sys-CE 2015 USA (in a T-Loc Sys I)
Separate handle that I keep under the insert in a SYS-CE MINI 1 TL TRA
As I mentioned, each has it's pluses:  The OG handle will accept Centrotec chucks, even those that are completely ludicrous like a full-size Jacob's chuck from a T-18, but also the super-handy right-angle chuck from the CXS/TXS sets
The handle from the Sys-CE 2015 USA set is the most solid, leasy-wobbly fit when inserting the long screwdriver blades
The newer Wera-handled driver is a bit wobbly, but solidly held and it fits nicely under the insert in the SYS-CE MINI tray, so it makes a handy travel companion.
I actually like the 1/4" ratchet set for all sorts of purposes, especially the hex bit inserts.
Online Cheese
« Reply #2407 on: September 11, 2022, 10:53 PM »
So is my assumption correct that your OG and my 495228 handle are the same thing?
Offline squall_line
« Reply #2408 on: September 12, 2022, 10:30 AM »
That would be a correct assumption/assessment.  I should have taken the chuck off for the picture.
Offline imdking
  • Tropical woodworking hobbyist
« Reply #2409 on: September 12, 2022, 07:49 PM »
Ok guys. Let's get back on topic. 😦.
Pictures of what you got today.
TS55 REBQ, 2 x FS 1400/2, FS 800/2, Festool carrying bag for rails, FS-AW Cable Deflector, Kapex KS 120 REB, CTM Midi, Domino DF 500, FS-HZ 160 ratchet lever clamps x2.
Offline woodbutcherbower
« Reply #2410 on: September 18, 2022, 02:47 PM »
It's always nice when two apparently unconnected posts connect. I recently posted about this build in the 'Member Projects' section;
https://www.festoolownersgroup.com/member-projects/gothic-victorian-break-front-kitchen-dresser/
So I delivered it and installed it yesterday to a super-happy customer, and gave her the invoice. It was a big-ticket item as you'll imagine, and she'd paid me online by the time I got home. So to celebrate, I decided to mark the occasion with a rather fine Turner Road 2014 Reserve Merlot from your fine Californian countrymen. It went down very well indeed. Very, very well.
So well, in fact, that I pulled the trigger and pre-ordered a TS60 as I drained the final glass  [big grin]
Expected delivery is the last week in October/first week in November. Really looking forward to it. I now just have to figure out what to do with my faithful TS55 and 20 blades ......
Kevin
« Last Edit: September 18, 2022, 04:09 PM by woodbutcherbower »
Offline kitfit1
« Reply #2411 on: September 18, 2022, 06:06 PM »
Kevin
I'll take the 20 blades as long as they is all sharp  [big grin]
Offline Lincoln
« Reply #2412 on: September 18, 2022, 06:11 PM »
Kevin
Always nice to celebrate the successful delivery of a job with a new tool :)
Offline Lincoln
« Reply #2413 on: September 19, 2022, 06:46 AM »
TPC18/4 basic
centrotec 3.5mm countersink bit
centrotec 5mm bit (replacing a lost one from my set)
EHL65 blade.
Offline Muttley000
« Reply #2414 on: October 10, 2022, 09:54 PM »
My FS/2 set came today, excited to play with it!
ETS EC 150
TS55 FEQ
CT 36
Offline twistsol1
    • Sawdustzone
« Reply #2415 on: October 23, 2022, 05:13 PM »
My two new Festool Systainer XXL 337's came today so now my drywall tools and my tile tools will have a non-cardboard home.
I spent hours looking for my tile tools a couple of weeks ago and eventually found them in the basement in a box labelled "Barbie clothes and accessories." Since my daughters are all married and have houses of their own, I'm sure this was a pretty old box. It was labelled "Tile Tools" on the side of the box facing the wall.
A shop full of tools and no talent
Offline HowardH
« Reply #2416 on: October 24, 2022, 10:09 AM »
I've been on a bit of a roll lately. Just picked up the new 1010 router and the FS/2 set.
Howard H
P1cc, T15, TID-18, RO150FEQ, ETS EC 150, MT55cc, RTS400, CT22, CT36E, 800, 1080, 1400, 1400 holey, 1900 rails, OF1400, OF1010, CSX, C18, LR32, VacSys, Vecturo, Domino, Qwas dogs, Parf Dogs, Zobo's, Syslite Uni, CMS GE, PM 1500, Jet J/P, FS-WA, Shaper Origin. Felder AF-14, TSC 55 KEB, Dash-Board bench system
Offline Coen
« Reply #2417 on: October 24, 2022, 11:29 AM »
The "old" FS/2 set or the new one?
Offline Frank-Jan
« Reply #2418 on: October 25, 2022, 02:29 AM »
Not today, but I forgot to post:
349930-0
FS-WA and wireless phonecharger
349932-1
Replacement rearleg for cs70 and hoseclip
The hoseclip that attaches the 27 mm part of the dustcollection to the side of the table broke, since I needed to order a replacement, I got the revised rear legset I had on my wishlist aswell. I had the previous version of the wheelset, but it didn't run smoothly, the new legs have the wheels integrated, and a complete legset has a lower price than the old wheelset. I don't really find the stabilisers usefull, but they aren't in the way if you keep them folded up either.
« Last Edit: October 25, 2022, 04:17 AM by Frank-Jan »
Offline Coen
« Reply #2419 on: October 26, 2022, 03:15 PM »
Are those the same legs on the CS 50?
Offline FestitaMakool
« Reply #2420 on: October 26, 2022, 03:53 PM »
Just a quick input regarding using the “old” Centrotec driver handle with the angle and eccentric chucks: You can also use any industry standard hex bit driver with the angle and eccentric chucks. - It only needs to be slim, aka the magnetic only, cause the lock-in collar ones are to fat to fit inside.
« Reply #2421 on: October 26, 2022, 05:05 PM »
"Technically" not Festool, but close enough.
The new Shaper Plate showed up today. The original shipping date that was given to me was Nov 4th, but it came in earlier than that. Now I'm going to have to figure out where/how to store it.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
Offline IrishPsych
« Reply #2422 on: October 26, 2022, 05:35 PM »
Snagged a 6 month older Domino Xl 700 kit. Two bits, some dominos left and the accessories never used. Got it for $1100. pretty happy with the price and I think I can still warranty register it. Seller paid cash and told me the date he bought it.
Offline Frank-Jan
« Reply #2423 on: October 27, 2022, 09:40 AM »
I don't think they are, the cs50's legs mount to the table from the outside vs the inside; but there are similar legs for the cs50 now (with the bolted on wheels and plastic outriggers)
Offline Coen
« Reply #2424 on: October 27, 2022, 10:21 AM »
Ah yes, the top is crimped on in reverse.
The legs of the CS 50 I use have the crimp get loose, so you have to kick it so it spreads all the way before it stands stable.
Offline pacificdune
« Reply #2425 on: November 02, 2022, 07:27 PM »
I found and purchased a used DX93 Deltex sander.  Very happy with being able to find this.
I was sanding recessed panels that were 4" wide, and none of the current sanders would fit.  Very happy with the purchase!
Offline memtew
« Reply #2426 on: November 03, 2022, 03:02 AM »
Domino DF 700  [thumbs up]
350251-0
Domino DF500 Q-Set / OF 1400 EBQ-Plus / ETS EC 125/3 EQ-Plus / Kapex 120 REB / TS 55 REBQ Plus / CXS Li 2,6-Set / SYS 1 CE-SORT / T 18+3 / CTL MIDI I x 2 / CT-VA-20 / TID 18 / BS 75 E-Set / Rotex RO 90 DX FEQ-Plus / OSC 18 E-Basic-Set / OF 2200 EB-Plus / PSC 420 HPC 4,0 EBI-Set / OF 1010 REBQ-Plus / SYS-MFT Fixing-Set / BHC 18 HPC 4,0 I-Plus / AGC 18-125 EB-Basic / SYS3 M 112 RA / FB D 15-35 CE-Set / ETS 125 REQ-Plus / TDC 18/4 I-Basic / SYSLITE KAL II-Set / ES-ETS 125 REQ / DOMINO XL DF 700 EQ-Plus / SV-SYS D14 / CTLC SYS I-Basic
« Reply #2427 on: November 05, 2022, 05:26 PM »
I went to the local dealer (WoodWerks)to place an order for an FS2424, since I was fairly sure they wouldn't have one in stock. I figured I would have to prepay, or at least put down a deposit, so I went in person. While I was there a CT15 decided that I needed it in my life.
They normally have one of those big FS5000 rails hanging on the wall, but it was gone.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
Offline Yardbird
« Reply #2428 on: November 05, 2022, 06:12 PM »
I think the 197" rail was discontinued.  Someone probably bought the one off the wall.  Can you imagine the problems shipping something like this without it being damaged?
Offline Peter Halle
  • Ain't so Small no More
« Reply #2429 on: November 05, 2022, 06:35 PM »
The number of those damaged in shipping was large.  Also had to go common carrier due to the length.  Festool USA actually had materials in their warehouse to build shipping boxes for those, but many a forklift won the squeamish.
