Finally, a CT 26E showed up pre-owned. Being a little disturbed by slight OCD to have used tools cleaned up I did with this as well. I scrubbed the outside which had its fair part of stains from paint, cement and plaster along with scuff marks. I did also dismantle it to get to its inner checking dust build up around motor and electronics. Dusted the whole inside (which wasn’t bad at all) Finally I mounted the handle and Bluetooth module which I had laying as new parts waiting for a used CT. I bought it (and the Festool level) from a carpenter who clearly took care of his tools.
The filter, which of most used CT’s I’ve seen have been totally clogged, like clay..
![Eek! [eek]](https://www.festoolownersgroup.com/Smileys/default/eek.gif)
was on now mine, in a near new state, along with totally clean tub and 4 new bags.
I even got loads of hose connectors, one 36mm and a 22mm AS hoses, stainless piping, HD adjustable floor nozzle, and even more hand nozzles in the purchase. Not to forget a brand new filter for water pick up. Not a single thing was broken, only slight wear on some parts, but totally insignificant. All that for $350. It was a bit of a clean up, but it was worth 1 1/2 hour. Now that I’ve checked it, it will probably run problem free a long long time.
Put to duty:
