Author Topic: What Festool Did You buy Today?  (Read 495342 times)
Offline niky1
Re: What Festool Did You buy Today?
« Reply #1440 on: May 29, 2019, 09:24 AM »
CMS-PS  561262 ..... [big grin] [big grin]
TS 55 EBQ, 2 x FS 1400/2, FS 800/2, PS 420 EBQ - Plus,  OF 1010 EBQ - Set + accessories, CXS Li 1,3 - Set, CXS Li 2,6 - 90 Limited Edition, DF 500 Q-Set + SORT-SYS DOMINO, set  ZOBO system, SYS 1 CE-SORT, PDC 18/4 Li 5,2 Set, SURFIX SYS3-SET, RTS 400 REQ-Plus + SYS-STF 80x133 + HSK-A 80x130, MFT 3 + SYS-MFT fixing set + FSZ 120, FSZ 300 + Veritas Parf Dogs, CMS-TS 55 R Set + all accessories, DOMINO  KV-SYS D8, KS 120 UG-Set KAPEX + all accessories, ETS EC 150/5 EQ-Plus + D27/22 x 3,5 m AS-GQ in SYS 3 T-LOC, CMS-OF, CMS-PS, OF 2200 EB-Set, LR 32-SYS, MFS 700, FS 2424/2-LR 32, MFK 700 EQ-Set, MFS-FS, MFS-VP 200, MFS-VP 400, FS 1400/2-LR 32.........
Offline tewlman
« Reply #1441 on: May 30, 2019, 09:50 AM »
new to the Festool addiction that started last week when I bought a like new Domino 500 for $550
Yesterday I bought a Midi
looking for a deal on a TS55 [unsure]
« Reply #1442 on: May 30, 2019, 11:47 AM »
@tewlman there are combination discounts, saw and vac -10%, saws and MFT - 10%. Check it out.
Offline Alanbach
« Reply #1443 on: May 30, 2019, 04:53 PM »
I bought a corded barrel grip Carvex from the Recon site and received it today.
Offline Jiggy Joiner
« Reply #1444 on: June 07, 2019, 02:26 PM »
This arrived today, the Vecturo OSC 18 accessory set:
I wasn’t sure I’d need these accessories but, now I can see lots of opportunities where they would be very welcomed, and more than useful.
I felt a bit like when I bought my first multi tool, in no time at all, I wondered how I’d managed for ages, without one? Then I remembered the accessory set hasn’t been out for ages  [doh]
Seriously though, I’m very pleased with the set, and the bonus is, although there’s some plastic but, the majority is metal!  [thumbs up]
« Last Edit: June 08, 2019, 07:01 AM by Jiggy Joiner »
Offline Coen
« Reply #1445 on: June 09, 2019, 12:04 PM »
Huh, although I knew the Vecturo was some Fein clone, I never made the connection of being able to fit the accessory set of the Festool on the Fein  [cool]
« Reply #1446 on: June 09, 2019, 04:55 PM »
@Coen Yes, the Vecturo is made for Festool by Fein, and they really are, apart from the colour scheme, more or less the same machine.
« Reply #1447 on: June 09, 2019, 05:02 PM »
Got an MFT SYS yesterday, very handy for site work:
Offline jobsworth
  • Festool Baby.....
« Reply #1448 on: June 28, 2019, 10:34 PM »
Went out and bought a Vac seperator unit. Man I dont know what I did with out it. I also bought some jig saw blades this one is for straight cutting only its thicker then the normal blades and longer than the normal ones. I need it to shorten some 4x4s on a bench I ecently made
Offline kmickey
« Reply #1449 on: July 04, 2019, 06:05 PM »
I happened to look at Festool recon when they had a DF-700 (Yesterday, July3rd).  Managed to register and buy it before it disappeared.   Very psyched.
Offline Ster1154
    • WoodEyes Woodworks
« Reply #1450 on: July 04, 2019, 06:39 PM »
Bought a Kapex today and I'm crossing my fingers that it doesn't produce fireworks
Offline Peter Halle
« Reply #1451 on: July 04, 2019, 07:31 PM »
Well, you do have a three year warranty.
And also 30 days to try and return if it doesn't meet your expectations.
Offline jjowen
« Reply #1452 on: July 22, 2019, 11:32 PM »
Side Extension Table for MW 1000. I could not justify the whole MW 1000 Mobile Workshop Set.
I am finding it more useful in my modest-sized workshop than I expected. For example; instant in-feed support for the CMS router table; instant support for long work piece. Looking forward to trying out an internal corner in which to clamp tricky MFS setups.
Disclaimer: All posts after 12:00pm on Fridays (GMT+10) should be independently verified for relevance and veracity.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #1453 on: July 23, 2019, 03:02 AM »
When I saw the first press release of the MW1000 I was not sure how good it would be. I then saw one at a show and thought that it was not especially stable.
However, having been using one for 3 months now I have completely changed my mind. I have a modest sized workshop and rely on things being moved around to suit the job in hand. I now routinely have the MW1000 close by with the constructor set in the top pull-out drawer. I have my jointer height at 900 mm and use either my MFT3 or the MW1000 as an outfeed table. I am currently in the middle of making a large dining table from solid oak. Planing the huge lumps of wood has not been easy but using the MFT3 as an outfeed table and then the MW1000 as an intermediate support has worked brilliantly.
301735-0
« Reply #1454 on: July 23, 2019, 03:37 AM »
...and I forgot to address the stability issue:
99% of the time stability is not an issue but I have found it very easy to push the MW1000 against a door frame or other solid object when I needed it not to move.
As I said, it is a great bit of kit and the extension table has 101 uses.
301737-0
Offline jobsworth
  • Festool Baby.....
« Reply #1455 on: July 23, 2019, 01:25 PM »
Just got a MW1000 extension table to use with my MFT3. It does come in handy especially since I’m doing site work for the next couple of weeks.
Didn’t have it room fir 2 MFT 3 in my truck. So this does the job
« Reply #1456 on: July 23, 2019, 03:24 PM »
The extension tables are very good, I’ve profiled a few pieces of timber like the MFT extrusion. I screwed one to my bench, another on a wall, and one outside of the workshop. This enables me to use the extension as a mini MFT. Maybe festool should make a free standing version but, it probably wouldn’t be stable enough given it’s size.
I have two of them, initially I thought they were over priced, not any more though.
Offline DynaGlide
« Reply #1457 on: July 23, 2019, 04:08 PM »
For all you clever CMS GE and mw1000 extension owners, how about a way to clamp securely to the CMS?
Instagram @matts.garage
« Reply #1458 on: July 24, 2019, 03:52 PM »
@DynaGlide I don’t have a CMS but, I have a couple of MW1000 extension tables.
You could, like I mentioned in an earlier post, profile a piece of timber close to the extrusion of the MFT.
In a post further up, regarding a plunge kit for my Supercut, you can see a MW1000 table, it is perched on one of the profiles I made up, that’s screwed to a stud wall.
If you get the profile right, the table will lock in like ot would on an MFT orthe mobile unit.
You can even just route a V in a piece of timber, and hold the table secure with a guide rail clamp or two.
If the profile is right, or even with a clamp it’s very sturdy.
So, if you can make up a profile that can mount to your CMS, the extension table will couple up.
This is one attached to a bench and clamped:
Offline Dove_Tail
« Reply #1459 on: July 24, 2019, 04:37 PM »
I've been lusting after the MFK 700 EQ set (edge banding router) for a while.  I forced myself to sell two old Porter Cable routers on Craigslist first before ordering.  I pulled the trigger ten minutes after I handed off the second PC.  Of course the new MFK cost more than I got for the two PCs.   [eek]
I saw a Conturo available on FestoolRecon for $1,661 and had to jump on it.  It arrived and looks great.
I hope to test out both this weekend.
Offline jobsworth
  • Festool Baby.....
« Reply #1460 on: August 15, 2019, 12:06 AM »
Picked up the MFT extension. Glad I did. It comes in handy
Offline ScotF
« Reply #1461 on: August 20, 2019, 01:33 AM »
The RAS on sale at Toolnut...it is a 2nd unit...one of my favorites.
Offline TBR
« Reply #1462 on: September 03, 2019, 05:48 PM »
At the weekend I ordered an of1400 and it arrived today. Couldn’t let a £50 off voucher go to waste. Now I need to find some projects to use it. Festool cutters are in the post arriving tomorrow.  A bit of an upgrade from the black and decker router I have had for 6.5 years. It cost me £66 so about 1/8 of the cost of the new one. http://www.amazon.co.uk/dp/B000Y8ZEVI/ref=pe_217191_31005151_3p_dp_1
Normal people... believe that if it ain't broke, don't fix it. Engineers believe that if it ain't broke, it doesn't have enough features yet.
Offline threesixright
« Reply #1463 on: September 04, 2019, 08:01 AM »
On the way ...
A... DF 500 / KAPEX 120 / DTS 400 / CXS  [embarassed]
Can't wait!
Offline TBR
« Reply #1464 on: September 04, 2019, 09:03 AM »
Does that accessory kit only fit the Supercut or does it fit the Multimaster as well?
Offline infer
« Reply #1465 on: September 04, 2019, 09:16 AM »
« Last Edit: September 04, 2019, 09:20 AM by infer »
Offline niky1
« Reply #1466 on: December 04, 2019, 08:49 AM »
OF 2200 EB-Set ..... uff
Offline presidentsdad
« Reply #1467 on: December 04, 2019, 03:37 PM »
DF 700 XL Set
PresidentsDad - TS75; FS1900; FS1400 LR32; CT36; RO150; DF700 XL; Seneca Small Mortise Kit;
Offline kmickey
« Reply #1468 on: December 05, 2019, 01:13 AM »
New style midi.  Being able to lower the vac speed makes a huge difference when using a rotex.  100x more controllable than with the regular shop vac I had.
Offline travisj
« Reply #1469 on: December 05, 2019, 10:47 PM »
My Black Friday Recon items arrived today: a pair of auto clamps, a ton of 6mm dominos, and a reconditioned C-18 basic.
