« Reply #1300 on: May 30, 2018, 03:18 PM »
Haven't bought much Festool for a while. Until today now that changed as I had the need for a major improvement in my paint removal sanding gear. I've gotten by with a Metabo Turbo tec 425 5 inch sander, but it's rather wobbly with a high center of gravity for working on vertical surfaces also I miss the efficiency of the pllug it and systainer storage with the metabo. I have speculated on getting either Rotex 125 or the etc etc 125 for the job og paint removal and finish preperation, but when I checked out the shop they had the Rotex 150 with the handle and being better for larger surfacing jobs I dove in. I just think for agressive paint removal or working with hardwoods the Rotiex i the most capable. The larger version seems to be the most popular for good reason, today I used it on som oak planks and it did a good job relatively easy sanding out uneveness left by planing with 60 gr granat and bringing it to finish (linseed oil for outdoor) ready with 120 gr.
So now I own the RO 150 to pair with the RO 90 for paint removal and wood surfacing.
« Last Edit: May 30, 2018, 03:44 PM by PreferrablyWood »
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set, 3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2 as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--. TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 . will get Domino DF 700 XL, CMS insert BS 120 Belt sander.
