Author Topic: What Festool Did You buy Today?  (Read 489891 times)
Online Knight Woodworks
Re: What Festool Did You buy Today?
« Reply #780 on: July 10, 2016, 10:04 AM »
JSF,
Welcome to the FOG. That's a nice assortment of tools, what's your next project?
John
Offline PreferrablyWood
« Reply #781 on: July 10, 2016, 11:01 AM »
I just bought an additional VL extension for the CMS GE I just received cause i felt it need a balance to the outfield table, and being a little blade shy I want to put a little more distance between me and mister sharp..It will also be needed when I'm going to be ripping some 4 meter long stock in the next couple of weeks.. I also bought the centering cone for the template work with the OF 1010
I ordered the extra VL extension today as well , just got to remount / replace the switch as its in the wrong place
Wonder why Festool didn't think of it DOH
Dale
Yes I see it can't be mounted with the switch in place, l will need to make some sort of movable yet sturdy mounting bracket for it..
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline JSF
« Reply #782 on: July 10, 2016, 04:12 PM »
JSF,
John
Thanks. First project will be a work table then a chest of drawers for my 3 year old daughter. It's going to take a while as I am recovering from a back surgery. I am just trying to get everything ordered so that I will be ready to start when able.
Offline jethreaux
« Reply #783 on: July 11, 2016, 04:09 PM »
Because I wanted the TS75 with a metric scale, I purchased one today. I was planning to purchase it later this fall. Since the MFT/3 is discounted 10% if purchased at the same time, I had no choice but to purchase it as well.
Offline Hugh
« Reply #784 on: July 12, 2016, 05:27 AM »
I'm just waiting on delivery of a SYS 2 today to finish tidying up the storage of my recent CMS delivery.
While I'm waiting I finally get to fire up in anger the CMS-GE, with TS55 and OF inserts.  I only went for the sliding table to go with it as with the DF 500, Domino set and extra dust hose it was getting a little ££££.
Offline Alicurly
« Reply #785 on: July 12, 2016, 10:47 AM »
Just recived this lot.  [big grin]
CTL SYS
ETS EC 150/5
EHL 65 EQ
SYSLITE DUO and stand
OF1010 EQB-Plus set and have added the trimming attachments.
Also picked up 3 Sys-Midi 3TL systainers.
And a Sys-Roll which is in use on the jobsite already.
Thinking now about getting a box trailer to carry all my systainers, Kapex and table saw.
My van drawer just isn't big enough to take all my systainers, plus my saws and dog cage.
This pic is the drawer in my old van, taken last year, I've since purchased more of the grey and green boxes.
Kapex on UG cart, Of1400, LR32set, RO90, Vecutro, CTL Midi, Domino 500, MFS400 + 700, Syslite duo, EHL65, ETS/EC 150/5, sysvac, OF1010
« Reply #786 on: July 15, 2016, 04:12 PM »
Today's purchase was a ct wings and some shaped 120g granat sanding blocks
Lots of the green stuff :))
Offline AJCruise
« Reply #787 on: July 15, 2016, 06:42 PM »
I bought the DWC 18-2500 Set and PDC 18/4 earlier this week.
The job I have on at the moment is to fit out 2 new build homes.
I have 150 Sq. metres of T&G red deal flooring to install, and all the drywall, but didn't fancy using loose screws (approx 16,000).
I damaged my hand late last year, (I cannot make a complete fist yet), so small items slip out my hand.
I don't use air, or gas, nailers for first fix (framing), so I needed a driver with a bit more muscle, without the noise of an impact model.
I have given both tools a good workout so far, and both have exceeded my high expectations of Festool quality.
I have cycled about 3000 screws through the DWC into the floor, without a single jam or misfire, while standing up, making it more comfortable and faster.
The PDC has plenty of torque, even at speed 3 and 4, to drive almost any screw size that I would use. I did turn it down to speed 1 to drive 7.5 x 120mm concrete screws and it drove them in with little effort.
I would like to hear about anyone else's feedback on the DWC, doesn't get mentioned very often here on the FOG.
Regards, Alan
PS-1E (First Festool!! Festo ~1989 and still going strong!),  TS55, RO90,  DWC 18-2500 Set, PDC 18/4, MFT/3,  KA-UG 120 Set, CTL Midi,  2x FS1400 Rails,  FS-Rapid,  Selection of FS screw clamps.
Offline Kev
« Reply #788 on: July 15, 2016, 07:00 PM »
@AJCruise I've got the older DWC in 12V and also in mains - both Protool. They've only had minor use. I'd sell them in a flash and upgrade to 18V DWC's but for some strange reason they're not on the market here in Oz at the moment.
Offline AJCruise
« Reply #789 on: July 15, 2016, 08:03 PM »
Kev,
I got the new 5.2Ah batteries with it, it went through 2,000 4x50mm wood screws on one battery charge, and saved me a day's work doing it with loose screws.
The PSC420 , BHC and HKC55 are next on the list.
Not having to drag around cables on the job would make life a lot easier.
I think Festool missed the mark by not making an HKC85 as the 55 variant won't cut 2X stock at 45 degrees. It would have plenty of power using the dual battery format on the TSC
Alan
Offline Kev
« Reply #790 on: July 15, 2016, 08:21 PM »
Kev,
Alan
@AJCruise
A dual power HK85 would be an awesome tool (2x18V's or a mains lead), but a dedicated cordless spinning the large blade wouldn't last long.
I'm looking forward to the local release of the HK85, but mostly because of the grooving attachment.
Offline AJCruise
« Reply #791 on: July 16, 2016, 03:49 AM »
Kev,
You're probably right about the load of a much larger blade, and never thought of the spindle cutter option.
I was thinking of something just large enough to cut through 2X with the thinner kerf width.
I hope Festool are looking at DeWalt's new 54/60V Flexvolt system.
The Kapex and Precisio, which are due an upgrade soon, would be ideal candidates for this, as well as the more powerful tools (TS75, HK85, OF1400/2200 etc.)
Thanks again for the feedback, Alan
Offline griffs
« Reply #792 on: July 19, 2016, 05:30 PM »
  just sold my midi and bought a ctl 26e.
« Reply #793 on: July 21, 2016, 03:49 AM »
Ordering the 466353 VERBINDUNGSSATZ 91549 IPM-VP-05-AV-ST corner threaded insert for the MFS so I can expand the possible configurations I'm getting two, I'd get four but they are expensive so l will wait on the last two.
I am also getting 4 FSZ 120 clamps so I will then have a total of 6 for using with the MFS setup.
An additional Set of MFS VB 700 extensions. My setup will then consist of 2x MFS 400, 2x MFS VB 700 and a MFS VB 1000 .
A FS2 1400 LR 32 guide rail combined with my FS2 1900 it will get me to 3300 length. For a mobile setup FS2 3000 isn't really practical.
« Last Edit: July 21, 2016, 09:52 AM by PreferrablyWood »
Offline goyya76
« Reply #794 on: July 21, 2016, 06:35 PM »
Today the second sys4 tl-sort 3 arrived  (The first one at 98 eur on amazon was at a decent price...when i saw it at 83 could not resist getting another!)
Ciao,
Francesco
Offline Jmacpherson
« Reply #795 on: July 22, 2016, 05:19 AM »
Collected my PDC 18/4 XL yesterday, can't wait to try it out.
« Reply #796 on: July 24, 2016, 04:45 AM »
Picked up a syslite kal 2 this week it pushes out an impressive amount of light for its size,  it's a great little work light think i'l be picking up another one in a couple of weeks
Offline Robert James Ross
« Reply #797 on: July 27, 2016, 09:46 AM »
PDC 18/4 needed a new drill with a 13mm chuck after my t-18 was stolen had been using my CXS for most drilling and anything over 9mm I would use my old bosch SDS what was a bit of a pain especially if there was no power handy.
I was waiting for my tax rebate before buying anymore tools but managed to knock my CXS of a marina where I am laying some decking into the salt water, fished it out but it is not working to well now. But considering how much I abused the poor little thing I am surprised it had lasted the 3 years I had it .
Offline rst
« Reply #798 on: July 27, 2016, 10:03 AM »
Bought the ETS-EC 150/5, already had an ETS/5 that I bought used and abused but worked great.  The EC is wonderful, much more like the air powered sanders that I used in the 70's at an industrial cabinet shop.
Offline Euclid
« Reply #799 on: July 27, 2016, 10:20 AM »
Nothing to get wildly excited about - but I wanted another SYS-1 to hold a (non-Festool) single-task toolkit; was going to go for a Tanos-branded one to get a contrasting colour - but I found that Amazon had the Standard (Compact?) Cleaning Kit (D27/36 K-RS Plus), complete with SYS-1 (and a foam base insert) for less than could I find the empty SYS. £29 inc delivery.
I know that kit is available elsewhere heavily discounted, so it's a modest saving - but welcome nonetheless.
Offline Kev
« Reply #800 on: July 27, 2016, 11:00 AM »
@Robert James Ross
Really sorry to hear your T18 was stolen. Stealing the very tools a man uses to make a living is a low act.
Offline Euclid
« Reply #801 on: July 27, 2016, 11:13 AM »
Also sorry to hear the fate of your CXS, Robert; I think I'd cry if I lost the use of mine!
Offline Grakat
« Reply #802 on: July 28, 2016, 06:00 AM »
Yes having anything stolen really sucks. Years ago I had about $10k of tools stolen, felt gutted, and have never really caught up from it, particularly on the cordless front.
Regards
Graham
Festool ETS150/3, TS55, CT26, DF500+ Domino set, PS300, HKC55, RO150
Offline Kev
« Reply #803 on: August 01, 2016, 12:56 AM »
Couldn't resist this .. will hopefully have my HK85 and bits tomorrow too [smile]
Offline fignewton
  • "Fine Quality Sawdust"
« Reply #804 on: August 01, 2016, 08:37 AM »
A Sys-roll, deep toolbox, and Sys-MFT, which I'm not sure I'm gonna keep since I can't lock it on top of any TLocs. I wanted it to go on top of a stack on the Sys-Roll as a small movable work station in case I wanted to clamp something small on it while working at the other tables.  May look to see if I can swap the top with a Sys-1.
TS55, MFT3+, OF1400, C12, CT-26, LR-32 system, Domino 500, RO125, MFK 700, Carvex w/ accsy, Sys-roll,  CXS, Kapex, UG with extensions, RO90
Offline rst
« Reply #805 on: August 01, 2016, 10:13 AM »
Just ordered another two Festool 492000 Dust Hood OF 1400, pulled to hard on the vac hose and yanked the hood into the 1/2" router bit.  Was routing slots and holes into 1/4" polycarbonate air diffuser for a refrigerated case.  Luckily I have another till these two arrive, hopefull will do better as I have 14 more to rout.  Going to attach my Y adaptor and another hose to claean out the jig rather than keep removing the router hose!  [blink]  [scared]  Just a side note, before buying the Festool routers I use now, five, clean up was a real PITA.  Now I clean up in minutes.   [big grin]
Online Peter Halle
« Reply #806 on: August 01, 2016, 11:46 AM »
@fignewton, the Sys-MFT locks on top of other T-Locs.
Offline leakyroof
« Reply #807 on: August 01, 2016, 12:52 PM »
  Thanks for pointing this out, he DID have me confused by posting that... [blink].  wonder if I should post a pic of my SYS-MFT in various places of the Systainer Stack it lives in.... [smile]
Offline fignewton
« Reply #808 on: August 01, 2016, 09:15 PM »
 :P I have to confess my ignorance.  I got it all home and was in a hurry to go help my neighbor replace two outside second floor window sills and beat the rain, and didn't pay close enough attention to what i was doing.  Confirmed you all were right when i got home tonight.  Thanks all.  love this place!
Fig
Offline Kev
« Reply #809 on: August 01, 2016, 10:22 PM »
Got my HK85 today .. but the FSK670 and the grooving unit are on backorder [sad]
