Author Topic: What Festool Did You buy Today?  (Read 468717 times)
Offline ScotF
Re: What Festool Did You buy Today?
« Reply #660 on: May 13, 2016, 12:54 AM »
Well I was thinking about adding a Rotex 125 to my arsenal to use in my sculpted Maloof inspired dining set I am building. The 6 inch Rotex is too big for many areas and the RO90 is too small, so I wanted the 125mm size to follow my RAS. After trying it out and the new ETS EC125, I was blown away by the power and feel of the new ETS and so I came home with one to try. I figured I could take advantage of the 30 days and if it does not work, I can swap it for the Rotex 125 (which I also liked). I think that I am going to be happy with the ETS and the brake, weight, ergonomics and power were amazing. Festool seems to have gotten things right with this sander.
« Reply #661 on: May 13, 2016, 05:54 PM »
Eventually bit the bullet and picked up a MFT3 basic today and a pair of clamping elements to go with it also got 2x sys4 tl sorts and the guide rail angle attachment
Lots of the green stuff :))
Offline blaszcsj
« Reply #662 on: May 13, 2016, 06:04 PM »
Got an OF1400 to round out the router family!
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
Offline rst
« Reply #663 on: May 13, 2016, 08:16 PM »
I just ordered a  sys combi II for my 1010 so I can put all my accessories in the drawer,  I already had done this same thing for to store my MFK 700 and bases.  I also ordered a sortainer sys 4 to put my electrical parts into (automatic door and mag lock parts and testing equiment).  Also ordered extra pads for my RO 90 and extra bags my Cts-Sys.
Offline TheMarvelousOne
« Reply #664 on: May 14, 2016, 07:06 PM »
Went to the local woodcraft today for a free dust collection "class", found out the only guy who has ever been super helpful passed away a month ago. Total bummer! So I bought my first Festool sander, ETS 125 and all the Brilliant 2 paper they had. 180, 220 and 400.
I was amazed that nobody in that place knew anything about the paper, sanders or much of anything related to Festool. I wanted to check out the Rotex 150 but nobody seemed to know anything about it and it was zipped tied down so I just bought the ETS for now.
Sent from my SM-G935T using Tapatalk
Offline Kev
« Reply #665 on: May 14, 2016, 10:56 PM »
@blaszcsj
Daddy bear's a mutant [scared]
Offline blaszcsj
« Reply #666 on: May 14, 2016, 11:20 PM »
It's kinda green!
Offline Holmz
« Reply #667 on: May 14, 2016, 11:30 PM »
Offline ear3
« Reply #668 on: May 15, 2016, 07:20 AM »
@blaszcsj How's the dust collection on that Makita?
Offline blaszcsj
« Reply #669 on: May 15, 2016, 08:29 AM »
@Edward A Reno III it is meh. But I have only used on solid surface where the chips are very stringy. They get clogged really fast in the small neck of the port. I imagine if I were doing a plunge cut in wood it would do ok. It has gobs of power though. The trigger switch is a little awkward at times but comfortable to grip.
Offline Kev
« Reply #670 on: May 15, 2016, 10:15 AM »
I had an 2000W Hitachi that had the heart of a prize fighter. Unfortunately rust kinda killed him. That thing was scary outside of a router table [eek]
Though they may lack refinement, some of the big old routers can produce a great result.
« Reply #671 on: May 15, 2016, 01:05 PM »
I'm not going to be that guy who makes a thread on something that's been brought up a lot so I'll ask it here instead. My new ETS 125 and CT-SYS, it seems like the suction is too powerful for the sander. I mean I turn them on and the suction won't even let the sander move. Cranked it up to 6 and it moved a little better. I used the CT-SYS on my old POS Dewalt sander and the sander performed normally.
Offline Kev
« Reply #672 on: May 15, 2016, 01:28 PM »
@TheMarvelousOne to compensate for not having variable suction, the hose on the CTL-SYS lets you bleed off air ... open it up and you'll be fine.
« Reply #673 on: May 15, 2016, 02:09 PM »
Thanks Kev. I also think it was a clamping issue as well. The piece I was sanding wasn't really clamped down. Just clamped down a chunk of cedar to the MFT and it worked well. Still jumpy if I tried to control the path of the sander but I'm sure that's part of the learning curve.
Offline griffs
« Reply #674 on: May 15, 2016, 03:49 PM »
  t18+ and the drywall screwgun , should have got the screwgun long ago!
Offline Kev
« Reply #675 on: May 15, 2016, 08:33 PM »
@griffs can you comment on the DWC? I've been told unofficially that it's not available on the local market here in Oz due to a minor change to a spring rate in the cartridge for better performance.
yeh - minor X-file [smile]
six-point socket
  • Guest
« Reply #676 on: May 16, 2016, 01:44 PM »
Ordered a Systainer SYS-STF Delta 100x150, to keep the DTS 400 EQ's sandpaper in. Should arrive Wednesday.
Kind regards,
Oliver
Online Cheese
« Reply #677 on: May 16, 2016, 02:39 PM »
I just ordered a  sys combi II for my 1010 so I can put all my accessories in the drawer...
A SYS-Combi 3
243706-0
243708-1
243710-2
« Last Edit: May 16, 2016, 02:51 PM by Cheese »
six-point socket
  • Guest
« Reply #678 on: May 16, 2016, 02:48 PM »
Looks great!
Kind regards,
Oliver
Offline GarryMartin
« Reply #679 on: May 16, 2016, 02:54 PM »
A SYS-Combi 3
@Cheese makes a good point @rst - although the SYS Combi II was correct for your MFK 700, hopefully you got the SYS Combi III for your OF 1010.
Offline VW MICK
« Reply #680 on: May 16, 2016, 02:55 PM »
@Cheese
That's a great idea. I like it
Offline GarryMartin
« Reply #681 on: May 16, 2016, 02:56 PM »
Courtesy of the Festool UK vouchers and a cheeky eBay voucher too, today the VAC SYS joins the arsenal.
Offline Kynasf
« Reply #682 on: May 17, 2016, 04:57 AM »
Very pleased to find a NOS Ras 115 from a UK dealer yesterday. It's just been delivered. It looks a beast!
Sent from my SM-G920F using Tapatalk
Offline Kev
« Reply #683 on: May 17, 2016, 05:32 AM »
@GarryMartin I see you're deploying it in the kitchen for your dinner plate. Messy eater are we? [big grin]
Offline GarryMartin
« Reply #684 on: May 17, 2016, 06:54 AM »
You been talking to my wife @Kev?
Offline griffs
« Reply #685 on: May 17, 2016, 04:44 PM »
hi kev.
  I was not aware of any problem with the dwc ,the one that i purchased works fine and are available in the full set, but the gun on its own has a waiting time of at least two weeks
  Clive.
Offline griffs
« Reply #686 on: May 17, 2016, 04:59 PM »
  I will get better ,(computer) [laughing] [laughing] [laughing]
six-point socket
  • Guest
« Reply #687 on: May 19, 2016, 01:20 PM »
Some swag I snatched off ebay arrived today. Someone was offering the folding ruler, pocket stick fix, twinbox, pencil and sticker for 20 bucks...
The Pica arrived from amazon, obviously not Festool ;)
Seems I need to re-oder the Sandpaper-Systainer from another source, the amazon marketplace dealer didn't deliver and doesn't communicate.
Kind regards,
Oliver
Offline Greg Powers
  • Metric convert
    • Stargate Unofficiial
« Reply #688 on: May 19, 2016, 01:46 PM »
Bought the Vac-Sys and the systainer of extra vacuum heads. Now I'am waiting for the Vacuum pump, The Excel5. I could just not bring myself to spend $800 on a vacuum pump.  [embarassed]
Greg Powers
Offline ear3
« Reply #689 on: May 21, 2016, 08:12 AM »
I went for one of the deep cuts, and got myself the copier/scanner tool for the routers, which works in tandem with the angle arm.  This think this might be the highest dollar per square inch item in the entire Festool lineup.
EDIT: Looks like I'm psychic  -- http://festoolownersgroup.com/festool-tools-accessories/attachment-that-not-everybody-know-is-in-the-market-for-of-1400-of-1010/msg460305/#msg460305
« Last Edit: May 27, 2016, 06:54 PM by Edward A Reno III »
