Author Topic: What Festool Did You buy Today?  (Read 480673 times)
Offline rst
Re: What Festool Did You buy Today?
« Reply #630 on: April 27, 2016, 08:27 PM »
I pre-ordered the CT-SYS and OF2200 package deal from Shane and Toolnut/Festoolproducts.com.
Offline jobsworth
  • Festool Baby.....
« Reply #631 on: May 06, 2016, 11:35 AM »
I bought the VL CMS ( just the stand) I already own a GE, the VL this will speed up my work flow quite a but
Offline LDBecker
« Reply #632 on: May 06, 2016, 08:02 PM »
I guess I'll play- last week bought a Kapex and the portable stand with extensions- this is an amazing upgrade to my 25 yr old Makita (which is still going strong, but doesn't have the capacity I need). The stand is really wonderful, and easily folds down for storage in my limited space. Thinking about a CT26 and 37mm hose... My 18 yr old Porter Cable and small hose is OK, but there is still more dust than I would like.
Online Peter Halle
  • Magnum - My new little boy
« Reply #633 on: May 06, 2016, 08:06 PM »
Congrats!
I personally love my Kapex but my CT is used more often.  If you go the CT route my guess is that even just the lower noise level will put a smile on your face.
Offline Kev
« Reply #634 on: May 06, 2016, 08:56 PM »
Yesterday ... OF2200 set.
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #635 on: May 06, 2016, 09:13 PM »
The RS 2E sander, with  Hole Punch and MPE Sanding Pad For Sheet Abrasives (and a bunch of sheet sandpaper).  Also purchased the 3.5m sleeved hose and CT Mounted Tool Holder my CT26.  Today I also went to Woodcraft and purchased the Festool 500076 SYS-MFT Tabletop Systainer 1, to sit on top of my CT26 (since I can't afford the MFT/3 yet)..  Now I just need a clamp and I will be set...
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
Offline LDBecker
« Reply #636 on: May 06, 2016, 10:56 PM »
Congrats!
Interesting interaction between my Kapex and the tool-controlled PC vac - If I leave the Kapex's laser turned on, the auto shut off sometimes doesn't work on the vacuum. Minor thing, but interesting. In favor of the CT, having the ability to dial down the suction would be good for sanding. I use mostly a Rotex RO 90, but it's a little small for larger jobs. For those i have my old Bosch 6" 1370 DEVS random orbital sander, but it's  A BEAST - heavy, and the dust collection isn't all that great (ok, but not great, funky little Bosch hose). Thinking about a 5" ETS EC125/3 for finish sanding... comments? The Bosch is ok for rough stuff, but I haven't been too happy with it for finer projects. The Rotex RO 90 is really nice, but a bit small for larger things...
Offline Kev
« Reply #637 on: May 06, 2016, 11:24 PM »
@LDBecker
Anything with ETS on it from Festool will give you a great finish and will also offer excellent DC.
The larger orbit ETS sanders are a good compromise if you don't have something that'll shred [wink]
Offline Hnnguyen85
« Reply #638 on: May 07, 2016, 12:07 AM »
Kapex just came in today and MFT/3 table just before the price increase.
Offline jobsworth
  • Festool Baby.....
« Reply #639 on: May 07, 2016, 03:13 AM »
Congrats!
I'd go for the 150 rather than the 125. No particular reason other if I go big I go big. Don't forget to check out the different pads.  I use the hard pad for flattening a panel works a good as a belt sander IMO and you might like the interface pad for the 90.
Online Claimdude
« Reply #640 on: May 07, 2016, 07:36 AM »
I bought the Vac-Sys and head set.
Jack
Offline griffs
« Reply #641 on: May 07, 2016, 04:36 PM »
    £50-£250 voucher could be tempting!
Offline LDBecker
« Reply #642 on: May 08, 2016, 01:10 AM »
[/quote]
I'm wanting something a bit lighter than my Bosch 6" - a 5" would be a nice compromise - hence the 125. I notice that there are a couple of versions of it - the Rotex RO 125 FEQ, the ETS EC 125/3 EQ (brushless motor), and the older ETS 125 EQ. TOO MANY CHOICES!!!! Probably leaning toward the brushless model...
Offline Hnnguyen85
« Reply #643 on: May 08, 2016, 01:24 AM »
[/quote]
You'll really like the brushless model, I have the ETS EC 150 and really like it. It's also very light weight compared to my old dewalt 5". If you haven't had the chance to, I'd suggest find a local dealer that stocks it and play around with it.
Offline LDBecker
« Reply #644 on: May 08, 2016, 02:38 AM »
[/quote]
You're probably right - BOTH the ETS EC 125 and 150 sanders weigh 2.6 lbs... that's about HALF of what my 6" Bosch 1370DEVS weighs. I can use the Bosch for more heavy-duty stuff, and the Festool ETS EC 150/3 brushless for the finer sanding. I'll look into them next week...
Offline Grakat
« Reply #645 on: May 09, 2016, 06:06 AM »
Hi everybody.
Increased the systainer count today. Festool Australia have the PS300 Trion barrel jigsaw on special with a free set of blades. I have some work for it so decided to go for it. The positive plugs on here for the PS300 also helped.
Now to research cutting plastic with it  [big grin]
Regards
Graham
Festool ETS150/3, TS55, CT26, DF500+ Domino set, PS300, HKC55, RO150
Offline niky1
« Reply #646 on: May 10, 2016, 04:12 PM »
PDC 18/4 Li 5,2 Set + SYS 1 CE-SORT ....... [big grin]
« Last Edit: May 10, 2016, 04:15 PM by niky1 »
TS 55 EBQ, 2 x FS 1400/2, FS 800/2, PS 420 EBQ - Plus,  OF 1010 EBQ - Set + accessories, CXS Li 1,3 - Set, CXS Li 2,6 - 90 Limited Edition, DF 500 Q-Set + SORT-SYS DOMINO, set  ZOBO system, SYS 1 CE-SORT, PDC 18/4 Li 5,2 Set, SURFIX SYS3-SET, RTS 400 REQ-Plus + SYS-STF 80x133 + HSK-A 80x130, MFT 3 + SYS-MFT fixing set + FSZ 120, FSZ 300 + Veritas Parf Dogs, CMS-TS 55 R Set + all accessories, DOMINO  KV-SYS D8, KS 120 UG-Set KAPEX + all accessories, ETS EC 150/5 EQ-Plus + D27/22 x 3,5 m AS-GQ in SYS 3 T-LOC, CMS-OF, CMS-PS, OF 2200 EB-Set, LR 32-SYS, MFS 700, FS 2424/2-LR 32, MFK 700 EQ-Set, MFS-FS, MFS-VP 200, MFS-VP 400, FS 1400/2-LR 32.........
Offline dalep
« Reply #647 on: May 10, 2016, 05:48 PM »
Had a bit of a splurge at the weekend with the help of an extra voucher or 2 ;-)
SYS MFT fixing set
FS-SYS/2 accessories set
Domino connector range SV-SYS D14
Module CMS TS55-R
CTL SYS dust extractor
OF 1400 Router Kit
CT Boom arm for CT36
Sliding Table CMS
Extension Table CMS
Guide Extension MFT/3-VL GB 240
LA-CS 50 Stopper
DF500 Domino Kit
DF700 Domino Kit
Module CMS-OF
CMS-GE
OS 400 Kit
OF 1010 Router Kit
SYS-PW power extension unit.
Dale
Offline Grakat
« Reply #648 on: May 10, 2016, 10:15 PM »
Ouch
Were they vouchers from the US Federal Reserve  [big grin]
That is a big shopping list. Enjoy the new tools.
Regards
Graham
Offline Mr_Mod
« Reply #649 on: May 11, 2016, 09:07 AM »
I had these 2 mysteriously turn up in the mail from Holland. Whats strange is that the package took quicker to travel from the other side of the world compared to a parcel from the other side of the town that were both shipped the same day. The one from the other side of town is expected to arrive Friday.
 [eek]
Offline dalep
« Reply #650 on: May 11, 2016, 01:32 PM »
Ouch
LOL, need to kit out a workshop so made use of a UK voucher, get £225 when spending £1500, i used 3, still not finished !!
There was also a LR-32 and a Vac Tool kit
Here is the stack:
Offline Vimmelman
« Reply #651 on: May 11, 2016, 01:39 PM »
Bought a new rotex sander - a RO 90 to replace my dx 93 and keep my RO 150 company.
But the sander has a new dust port? Anyone else seen this before? Think i got it straight from the factory.
Its a locking dustport. They sent along a new adapter for the 27mm hose(to replace the old) in the systainer aswell...
Offline copcarcollector
« Reply #652 on: May 11, 2016, 02:00 PM »
See this thread, its a new feature, but this is the first tool I have seen the new port on...
http://festoolownersgroup.com/festool-tools-accessories/cleantec-conneting-system/msg457008/#msg457008
Offline joiner1970
« Reply #653 on: May 11, 2016, 05:44 PM »
That's good that they sent you a new hose end too.
Sent from my ALE-L21 using Tapatalk
Offline Phil Beckley
« Reply #654 on: May 11, 2016, 05:55 PM »
Hi
The saws and sanders will be the first set of machines to have the new port fitted.
RG
Phil
Offline Holmz
« Reply #655 on: May 11, 2016, 06:51 PM »
Why ?
A 1/2 sheet is also good for finishing, and better chance of remaining flat.
A 6" round sander gives a large surface to try and remain flat over - rather than smooth and wavy.
The 5-mm also works for finishing.
The perfect combo is a 1/2-sheet with 2-mm and an 6"/5-mm random orbital (plus your Bosch as a trifecta)
Doesn't matter much. Do you need a 5" or would the 6" work?
Offline redbirdone
« Reply #656 on: May 11, 2016, 08:25 PM »
Went on a bad streak this week...bought the new CTL-SYS as well as the LR-32 set, the LR-32 95" guide rail and the Domino XL700 (plus a Systainer of each of the XL tenons).
I blame the IRS/tax code.  They limit Roth IRA contributions and earlier this month I maxed out this year so I got weak and decided to go Festool.  Next month will go into traditional savings account as I need to save up some money for material to actually use these tools on... :)
Offline Flatsawn
« Reply #657 on: May 11, 2016, 09:53 PM »
243404-0
Beats the alternative
Offline redbirdone
« Reply #658 on: May 11, 2016, 10:35 PM »
...and in another moment of weakness got the MFK700 kit to use with my (hopefully) future Conturo purchase.
Running out of room for the black and green tools.   :)
Offline Kev
« Reply #659 on: May 12, 2016, 12:09 AM »
I feel your pain!
