Author Topic: What Festool Did You buy Today?  (Read 511447 times)
Offline FestitaMakool
Re: What Festool Did You buy Today?
« Reply #1530 on: March 08, 2020, 08:01 PM »
Bought a second hand OF 1010, MY2004
For $100  [big grin] I got a very nice router with “sticky” columns, complete with original systainer. It even came with a brand new Plug It cable. And the only part I will have to get is a new turret where one of the depth stops have broken. Soon to be teared down and overhauled.
« Reply #1531 on: March 10, 2020, 12:01 PM »
@Cheese
Mine does not, that’s the OF 1400 hanging under there:
Thanks for the info...I measured .012" on one side of the insert and .024" on the other side. I'll check mine again because the differences in height are a concern. If it's proud of the base plate, it should be the same dimension all around the insert.
« Reply #1532 on: March 10, 2020, 04:09 PM »
I just realised, it could be the ring on the base plate of your router pinching the insert ring from behind. You could have accidentally moved the router when fastening it to the table. At least what I noticed is that the routers inner ring on the base just center over the protruding part of the insert ring.. and the protrusion is not that high..
Offline Nic Rhodes
« Reply #1533 on: March 13, 2020, 06:54 PM »
Bought an OFK 500, anyone got any recommendations for additional cutters if they are needed?
Offline jobsworth
  • Festool Baby.....
« Reply #1534 on: March 14, 2020, 11:04 AM »
ordered the new cutting table. cant wait to get it in Oct
Offline Alanbach
« Reply #1535 on: March 14, 2020, 10:12 PM »
@jobsworth - When do you move to Az?
Offline jobsworth
  • Festool Baby.....
« Reply #1536 on: March 15, 2020, 03:26 PM »
@Alanbach
Im homeless right now. Sold and moved out of my Calif house on the 11th. Waiting for my Az house to be finished/appraised and final inspected tentatively set for the 21st. Staying with in-laws our Stuff is in storage.
Offline Alanbach
« Reply #1537 on: March 16, 2020, 12:22 PM »
@jobsworth - Sounds like you are almost there! Are your in laws in Az. Or Ca.? In other words are you over at the construction site supervising everyday?
Offline jobsworth
  • Festool Baby.....
« Reply #1538 on: March 16, 2020, 01:02 PM »
No were in Las Vegas. I talk to the builder regularly. The problem were having is with the weather. Its been raining quite a bit there and one of the hold ups is getting the road to my house graded and drainage . It needs to be done and final inspected before the final on the house is done.
Offline Alanbach
« Reply #1539 on: March 16, 2020, 10:46 PM »
Well good luck! I am sure that you will be through this final stretch in no time! Congrats! I can’t wait to see your threads regarding the building of your shop and the countless projects that you will come up with!
Offline Coen
« Reply #1540 on: March 17, 2020, 06:30 PM »
(Attachment Link) (Attachment Link)
Ooh nice. The lowest depth stop isn't really something you will miss. When I got my OF1010 new I adjusted that 3rd depthstop all the way down. Straight from the box Systainer it limited how deep the 1010 could go.
Just curious; does yours say 22.000 rpm, 23.000 rpm of 24.000 rpm? I bought mine in 2005, the catalog of the year before said 22.000 rpm, my machine says 23.000 rpm (if I remember right) and the catalog of the next year said 24.000
(years might be off slightly)
« Reply #1541 on: March 18, 2020, 12:46 PM »
@Coen
It’s me, I need to have all my gear in best possible condition, even with not used features  [wink]
Also,
Mine says 10000 - 24000 rpm on the machine label. It is in fact a 2003My.
Systainer says 23000
Manual says 23000, but not the “Q” model, which passes 26000: (Edit: always funny how iOS treats image rotation.. [crying]
[ Specified attachment is not available ]
« Last Edit: March 18, 2020, 12:51 PM by FestitaMakool »
« Reply #1542 on: March 29, 2020, 03:29 PM »
@Cheese
Mine no longer has the issue either after some "quality" time with the ETS EC and some 320 Granat.  [big grin] [big grin]
Before the intervention there was a gap of .012" on one side and .024" on the other. It's now down to .0015" and .002" respectively. Here are some before & after shots.
« Reply #1543 on: March 29, 2020, 05:47 PM »
 [big grin] [big grin] That’s s the spirit!
Offline rst
« Reply #1544 on: March 29, 2020, 05:59 PM »
I ordered one of the new 5 meter 36mm hoses to use with my cordless tools.  Also ordered clips for when I need cords.
Offline alevan
  • Got bitten Dec 2013 - Help!
« Reply #1545 on: March 29, 2020, 06:10 PM »
Ordered the new STM 1800 work table and bought the RAS-115 at clearance price (new at almost half of original $) and the other disc pad for the RAS-115.
Kapex, Kapex UG Stand, TSC 55, TS55 REQ, OF1400, CT36, CT 36 AC, HL 850 Planer, HL 850 Bench Kit, Planex  225, ETS 150/3, RO150, RO90 DX, RTSC 400, RAS 115, TID 18, BHC 18, T15+3, CXS Set, Centrotec Installer Kit, DF 500, Carvex 420, Carvex Kit, Tradesperson Cleaning Set, Guide Rail Kit, MFT  Top, Parf Dogs, FS 1400/2, FS 1400/2 LR 32, LR 32 Kit, Precision Parallel Guide Set, MFS700 Set, Makita 118" Guide Rail, STM 1800 Table.
Offline jobsworth
  • Festool Baby.....
« Reply #1546 on: April 22, 2020, 09:54 AM »
Well I pulled the trigger and got the conturo. I have a lot of cabinets to build now and in the near future and couldn't see myself putting edge anding on all those with a iron. Also picked up a box of glue pucks and I didnt get te kit but got one accessory, the reel for long strips of banding as most of the cabinets will be roughly 8 ft high.
Oh I preordered the cutting table. After hauling all this ply off my truck into my temp shop, this cutting table will be a back and time saver for me.
Offline ctvader
« Reply #1547 on: April 22, 2020, 10:35 AM »
I rec’d my CT 15 vac on Monday.  Used it for all of 5 mins but so far, so good.
Offline KelleyCrafts
« Reply #1548 on: April 22, 2020, 12:03 PM »
I have a CT15 coming tomorrow. It will be put straight to work as a dedicated MFT vac. Already received the fast cap remote for it and an extra little splitter for the socket so I can plug some lights into it to trigger the auto start.
Offline Leemstradamus
« Reply #1549 on: April 22, 2020, 03:29 PM »
Hi, everyone I bought the TS55 REQ on Monday! I haven't used it yet. Now thinking about getting a dust extractor.
Offline Coen
« Reply #1550 on: April 24, 2020, 11:42 AM »
Do it. Your lungs will approve ;)
« Reply #1551 on: April 24, 2020, 01:02 PM »
Well yesterday I did! I got the CT MIDI and ROTEX RO 90 DX FEQ-Plus! I'm so excited!
Offline tywalt
« Reply #1552 on: April 24, 2020, 03:30 PM »
Finally pulled the trigger on a TSC 55 on Tuesday from the fine folks at Festools-Online.  Trying to be patient on the shipment as I'm sure they are backed up right now but figured I would come brag here while I wait!
« Reply #1553 on: April 24, 2020, 09:00 PM »
I did get those recently as well, love the CT Mini/Midi, and the quiet, nimble, aggressive, handy, versatile RO 90. They will never leave me - unless something substantially better comes along.  [big grin]
« Reply #1554 on: April 26, 2020, 02:51 PM »
I totally understand! I'll have to get the shop in some kind of order to post some pics.
Offline Euclid
« Reply #1555 on: April 29, 2020, 08:38 AM »
TSO rail connectors... a nicely thought out piece of kit, I'd say.
A big thank you to Axminster, whose customary good service is holding up well, notwithstanding the challenges facing retail and overloaded delivery networks. I've had several orders from Axminster in the last few weeks. Everything takes a wee bit longer than their usual next day service, but all has arrived correct and bang on time within an advised one hour delivery slot. I'm impressed.
Offline PreferrablyWood
« Reply #1556 on: April 29, 2020, 09:22 AM »
I'm restoring som kick strips made of brass on the teak wood doors I'm working on improving the security aspects and finishing as well. I've used 60-80-120-180 grits on the RO 90 and R0 150 it worked really well to bring back a surface that looked frankly unsalvageable to something pleasing to the eye once more. Still a lot of small scratches after the 180 gr. so I want to refine the surface further with finer grits. On an impuls I bought the granat screen net 240 og 320 instead of regular granat to sand out the scratches and will finish the surface with the platin 1000 and 2000 gr pads. Unfortunately they did not have a protection pad for the RO 150 so I'll be ordering one or two before using the granat screen so as not to damage the backing pad.
« Last Edit: April 29, 2020, 12:11 PM by PreferrablyWood »
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline Rick Herrick
« Reply #1557 on: April 29, 2020, 10:45 AM »
I recently bought the same and I would make one suggestion if you haven't already... Most of my time is with plywood so I changed over to the Universal blade and I can see a cut difference.  So far, so good.
Offline ART at WORK
  • Buy less Recycle more
« Reply #1558 on: April 30, 2020, 06:50 PM »
I just got the new FS WA/90. A pricy bit of Aliminium, and the only difference is no blue Anodising and a green piece of Rubber on the TSO clip. It was a lot cheaper for me to get this in Germany than to import the TSO original from the States.
Will give it a test run tomorrow.
Kapex 120 + UG Set, ETS 150/3, DF 500, RO 90, MFT/3, CTL 36 AC, RO 150, 0F 900, OF 2200, T15+3,  CDD 12, TS 55, A5 Router table, First Aid kit, LR 32 SYS, FS 800, FS 1400/2, FS 1400/2 LR32 FS2 3000, CTL Midi + Cleaning Set, Clamps, Parallel Guides, Centrotec drills, Zobo Forstner set and countersinks, Routers, Systainers, Sortainers, Sys Cart, Syslite
Offline CeeJay
« Reply #1559 on: May 01, 2020, 09:45 PM »
Five of these.
