Author Topic: What Festool Did You buy Today?  (Read 511442 times)
Offline Alex
Re: What Festool Did You buy Today?
« Reply #1470 on: December 06, 2019, 01:13 AM »
Not a Festool but a Fein FMM350Q MultiMaster because my 250 quit on me and I can't repair it because I can't figure out what's wrong with it.
Unfortunately it looks like I have to look for a new RAS too, because mine decided to quit on me right in the middle of a pretty large job. Well, it already had 15 years on the clock. Bit in a pickle now, Rotex won't do it, and the angle grinder has no DC. And on top of that, RAS is very hard to find now it's discontinued. OH Festool, WHY???
Offline JimB1
« Reply #1471 on: December 08, 2019, 03:39 PM »
I bought the Emerald edition Domino DF500 and an Emerald Sys2. Well, they arrived yesterday so close enough LOL.
-Jim
TS55 REQ, MFT/3, Domino DF500, CXS, OF 1010, RO 150, ETS 150/3, RTS-400, rectangle sanding block, Pocket StickFix Sanding Block and a CT Midi...
Offline niky1
« Reply #1472 on: January 30, 2020, 07:54 AM »
LR 32-SYS, MFS 700, FS 2424/2-LR 32 ......... [big grin]
TS 55 EBQ, 2 x FS 1400/2, FS 800/2, PS 420 EBQ - Plus,  OF 1010 EBQ - Set + accessories, CXS Li 1,3 - Set, CXS Li 2,6 - 90 Limited Edition, DF 500 Q-Set + SORT-SYS DOMINO, set  ZOBO system, SYS 1 CE-SORT, PDC 18/4 Li 5,2 Set, SURFIX SYS3-SET, RTS 400 REQ-Plus + SYS-STF 80x133 + HSK-A 80x130, MFT 3 + SYS-MFT fixing set + FSZ 120, FSZ 300 + Veritas Parf Dogs, CMS-TS 55 R Set + all accessories, DOMINO  KV-SYS D8, KS 120 UG-Set KAPEX + all accessories, ETS EC 150/5 EQ-Plus + D27/22 x 3,5 m AS-GQ in SYS 3 T-LOC, CMS-OF, CMS-PS, OF 2200 EB-Set, LR 32-SYS, MFS 700, FS 2424/2-LR 32, MFK 700 EQ-Set, MFS-FS, MFS-VP 200, MFS-VP 400, FS 1400/2-LR 32, VECTURO OSC 18 HPC 4,0 EI-Set, AGC 18-125 Li EB, T 18+3 HPC 4,0 I-Set, Edge sander ES-ETS 125 REQ-Plus .........
« Reply #1473 on: February 02, 2020, 10:26 AM »
This showed up at the door step yesterday.
Offline Alanbach
« Reply #1474 on: February 02, 2020, 10:43 AM »
@Cheese - Did you have to acquire this from overseas or were you able to buy it here as replacement parts? I came to Festool too late but this tool is a recent fascination for me.
« Reply #1475 on: February 02, 2020, 10:45 AM »
Overseas...took 3 days.
Offline TXFIVEO
« Reply #1476 on: February 02, 2020, 08:06 PM »
Got the beast sander...RS 2E.  What an awesome sander, the best sander in their lineup by far.
Offline johnyhuh
    • Tidbits
« Reply #1477 on: February 04, 2020, 11:11 AM »
Finally got the MFT/3.
Factory stops were off. Is this possible?
MFT/3 | DF500Q / Connector | ETS EC 150/3 | CT 26 w/ BT | TSC55 | LR32 | OF1400 EQ Router | Carvex PS 420 EBQ / Acc. | Universal Cleaning Set
Offline FestitaMakool
« Reply #1478 on: February 04, 2020, 11:45 AM »
Finally I got the PS-300, TS 55 and even lucky enough the TS 75 module to go with the CMS-GE/VL tables. I’m thinking modifying one function with the TS saw in it.
Offline PreferrablyWood
« Reply #1479 on: February 04, 2020, 02:15 PM »
I've bought the BHC SDS drill and the Vecturo OSC 18 v. Put to good use on som security upgrades on the doors af apartment building. Nice vibration dampning on both tools and efficient working. I'm going to get the Plunge attachment dust collection  for the Vecturo and dust collection for the BHC.
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
« Reply #1480 on: February 04, 2020, 02:45 PM »
It’s possible but it’s also possible they’re where they should be and you just don’t understand the reason. I didn’t on my first MFT.
First, Festool doesn’t consider it necessary for the rail to be precisely parallel to the columns of holes. The holes are just for passing clamps through but you can change the alignment if desired. However, since Festool doesn’t promise that the grid pattern is precisely square I wouldn’t bother.
What threw me was how sprung the rail was in relation to the front rail support pin. I had to pull the rail to the left to get it to fit over the pin. I was sure that was a factory mistake so I loosened the bolts fixing the rail to the hinge and then discovered that the slot in the rail is wider than the pin so the angle of the rail to the fence could vary a little every time it was it was set down.
To eliminate that variability the rail is sprung so that it is always tight against the left side of the pin. Just get in the habit of pulling the rail to the left and gently setting it over the pin. Avoid forcing it over the pin which will eventually carve a groove into the rail.
Offline Alex
« Reply #1481 on: February 04, 2020, 05:20 PM »
I went a bit crazy and bought a Ti15 yesterday. Body only, but after I've sold some of the accessories it came with, like the right angle adapter, I've only paid €15 for it. I couldn't pass on that opportunity. It came exactly at the right time, because I've got some custom designed furniture to make that will require about 750 screws. Let's see how it holds up.
« Reply #1482 on: February 04, 2020, 05:39 PM »
TI 15 for €15!  [blink]...
I have one, brand new, never used with TI FX adaptor. Got it as a part of a deal with lots of FT stuff. Let us know how you think of it. I have not tried it yet, since no 15V batteries in my stock of FT..
I might just keep it then.. it’s still a tool.. [big grin]
Offline Alex
« Reply #1483 on: February 04, 2020, 06:20 PM »
Well, you got it for free then. Mine's heavily used by a contractor who'd worn out the batteries and now switched to all Makita because it is cheaper. Technically 100% but it was very dirty, stickers all worn and sprayed with gold paint. But I spent an hour cleaning it up and now it almost looks like new again, except for the missing stickers.  Used it to drill some holes today, no screwing yet. Drilling went fine. It's heavier than my T15 though, that surprised me.
Btw, if I don't use a Festool I sell it off, costs enough, good to see some money back once in a while.
« Reply #1484 on: February 04, 2020, 07:09 PM »
..That’s the thing..y’ I kinda-ish recently renewed my Makita stable with the new DTD 171 BL impact (still got my 10 year old, and still going strong) It is very very good - same features as the new TID in fact🧐, I even got the new 12V BL version for lighter work (above head work) So I am kinda covered. Think I’ll push the TI 15 into an ad.
Thanks for the heads up Alex [embarassed]
Offline johnyhuh
    • Tidbits
« Reply #1485 on: February 06, 2020, 10:56 AM »
That makes sense. I was going off the dog holes. Did make the adjustment to align parallel with the holes and now it’s dead square. Cuts are super quick. Should have gotten it much sooner.
« Reply #1486 on: February 06, 2020, 04:16 PM »
I turned my recently purchased Vecturo OSC basic by buying the OSC-AH/TA/AV-Set into the set version. I guess I made a rather bad deal by buying the Basic, the battery separately  and then addition the accessories but funds were low last month so it ended up that way.  I need the plunge base for at tricky self made jig I'll be making for security upgrade on the 85 year old doors that I'm doing in the coming weeks. I'm sinking som brass hardware into the teak surface of the doors and I want to make nice job of it. The Vecturo will also be useful for doing some remedial surgery on sections of the door that were badly repaired in the past. Teak wood is getting scarce and my thought is if the doors are going to survive into the future then it's time to do the refurb now. Otherwise they would likely need to be replaced in the next decade or so that would be a shame- 13 doors and lots of fussy details so the gear I've just bought will help save time and improve the quality of the work.
« Last Edit: February 06, 2020, 04:19 PM by PreferrablyWood »
« Reply #1487 on: February 07, 2020, 05:25 PM »
7 days in transit and hundreds of miles, not even a scratch on the box..:
Very happy today  [smile] Big box’ internals in more manageable pieces did fit my car..:
The CMS-VL MFT/3 Router set.
« Last Edit: February 07, 2020, 05:27 PM by FestitaMakool »
Offline capww8
« Reply #1488 on: February 08, 2020, 09:47 AM »
TS55 to replace my dewalt track saw... been planning on doing this for a while and finally pulled the trigger on the emerald version with the extra blade. I’ll post my impressions of dewalt vs festool track saw once I get some time on the new stuff.
RAS ‘cause it was on sale, and I’m a sucker
Planex Easy ‘cause it was refurb and I’m a sucker
Two more systainers to hold random BS
$250 worth of sanding media for the two new sanders that I didn’t actually need, ‘cause I’m a sucker
1400 mm rail, ‘cause I couldn’t remember what length my other two tails are, and I wanted the $40 off.
« Reply #1489 on: February 08, 2020, 10:15 AM »
@Alex There’s a shop in Sweden that has the RAS 180 in stock, PM me if interested.
Offline Alex
« Reply #1490 on: February 08, 2020, 03:28 PM »
Thanks for keeping me in mind, but it's the 115 I was looking for, the 180 is too big for my taste.
And I've already found my replacement, had the extraordinary luck to find a used one at a tool dealer in my city, €175, unfortunately it came without the dust hood. But that was no problem because I already had one from my broken RAS.
Come to think of it, I hadn't bought a new tool in 6 years, but last 3 months I've bought 4 new used Festools and two others, I'm on a bloody shopping spree.
Offline Coen
« Reply #1491 on: February 09, 2020, 02:46 PM »
Not today, but yesterday(ish) I got the adapter to cut circles with the PS300; the Festool 490118 "KS-PS/PSB 300"
darn pricey piece of metal, although it beats routing the 20 circles D=250mm I want to make..
« Reply #1492 on: February 14, 2020, 09:28 AM »
When I read that the CMS system is now discontinued, I went on a search for the modules I've waited on getting, mostly because of lack of funds and no pressing need. On the other hand I'm pretty heavily invested in the CMS system as I have all the CMS GE table add ons the Router module and the TS 75 module. So not to miss out on the last two modules I'm missing I just bought the CMS Mod BS 120. I'll get at decent selection of the sanding paper for at start 80 grit and 120 grit. It comes with the angle adapter so and a short fence, so I have found a very sweet setup for little money. I'm an occasional user but have lack of time when I do start a project. More tools give faster higher quality results, and that will keep me in working.
The Band sander module as a few extra add on that I'll get mostly there are a few different sizes the the drums handy  for shaping curved pieces. I'll also use the sander for grinding metal så will need to source a spark trap for the vacuum .
I will only be missing the jigsaw adapter table for the CMS system which I'll get in the near future.
I can see why Festool needs to discontinue products as the market changes but hope that they reconsider keeping the CMS system going.
I like the portability and the small size, easy to store, aluminium doesn't rust and although fiddly to setup in the beginning I have now mastered the setup procedure so it's pretty good around.
Offline jcrowe1950
  • Festool Dealer Affiliate
    • Woodcraft Chattanooga, TN
« Reply #1493 on: February 14, 2020, 06:11 PM »
Boy do I envy you the CMS options you have in Europe. In the US, we only have the CMS-OF. I asked our regional sales rep if he had heard anything about the CMS being cancelled and he told me that all he knew was that the standalone version was being eliminated for both the GE and VL versions. If Festool Germany is eliminating the CMS for regulatory reasons, that's unfortunate. The router version is full of innovation and using the sliding table allows a lot of very sophisticated work. I'd actually love to see peoples' Festool shops in Europe....the methods of work seem very different from what I can tell.
   To piggyback on your post....my latest Festool purchase was actually a set of TSO guide rail connectors and they are impressive. Nice company and nice products.
Festool Specialist at Woodcraft, Chattanooga, TN
Offline Coen
« Reply #1494 on: February 16, 2020, 02:41 PM »
You can still buy the modules as "spare parts". I assembled my jigsaw module from 100% spare parts, hehe.
« Reply #1495 on: February 16, 2020, 03:19 PM »
Curious how you use the jigsaw module. What tasks does it excel at?
« Reply #1496 on: February 19, 2020, 03:42 AM »
Bad news about the buy it was cancelled by the Amazon.de seller so in this case the deal seemed to good to be true was just that false advertising on amazon.de for too low priced Festool.
Oh well I'll keep an eye out for the CMS MOD BS 120 but won't be fooled in this way again. The money isn't lost though I could have done with out my hopes getting dashed like this.
« Last Edit: February 20, 2020, 12:57 PM by PreferrablyWood »
Offline Coen
« Reply #1497 on: February 19, 2020, 04:58 PM »
See attached. When I was like 10-12 years old I made those with a fretsaw... but no way I am doing that now  [tongue]
Previously I also made a raster of thing aluminium plates with the jigsaw jerryrigged under the router module.
« Reply #1498 on: February 20, 2020, 10:39 AM »
So you're using it like a scroll saw?
The reason I'm interested is because I have an extra Trion & Carvex either of which I could throw in the PS module. Since Festool has discontinued the item, now would be the time to make a move if it was of some value to me. I love the GMS-GE for function & portability and just wonder how/if I would use the PS module. I've ruled out getting the TS 55 module and already have a 14" bandsaw. I've not needed a scroll saw in the past and don't see a need for one in the future.
Just thinking out loud.  [smile]
Offline Coen
« Reply #1499 on: February 20, 2020, 10:56 AM »
I had to google that word. For this project; yes. I guess it's more economical to just buy a dedicated machine for that, but I like the wider cut here (used a thin jigsaw blade; the 1.4mm) and the guiding options.
I tend to want to own "the whole set" in most cases. But it was definitely a buy that is gonna be on the expensive side in €/hour used...
