Author Topic: What Festool Did You buy Today?  (Read 511431 times)
Offline PreferrablyWood
Re: What Festool Did You buy Today?
« Reply #1050 on: February 28, 2017, 11:27 AM »
I ordered the MFS sled from Toolnut, now have all size extrusions and sled.
I guess the MFS sled is the best solution when using the MFS as it doesn't take away any depth capacity for sled work, so I probably need to get one as well.. Hope it works out for you..
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline Rustys
« Reply #1051 on: March 14, 2017, 05:36 PM »
I just purchased my new Festool fidget Cube. I chose the cordless model for $99.00 on special pre-order deal with Systainer. I'm hoping to purchase the accessories for only $75.00. It has a three year guarantee and provide nothing more than fidgeting functionality. These will go fast.
 [big grin]
Offline rst
« Reply #1052 on: March 15, 2017, 02:21 PM »
I used my MFS sled the other day to hog out the center of pattern for mirrors that I'm making for my daughter the jewelry designer.  A long ,long, long time ago I made a batch of 10-12 mirrors using a small cast iron fry pan as a pattern for the wood framed mirrors.  Being young and subscribing to the try it and then fix it method of design, I decided to use my drill press and a 1/2" milling cutter to hog out the center.  Being young and still having decent reflex's I ended up with 4 perfect curved slits in my left thumb as the bit grabbed and I jerked.  Meanwhile, back to the present, I thought since I had just bought the MFS slide, I'll use that to hog out the middle.  I had already used the MFS to make the circular pattern...and Mikey likes!  The problem with the slide is that it can only set for one length.  How to limit the length of router sliding??  I use Magswitch magnets for lots of uses...not the ones marketed to woodworkers, the heavy duty, pull your truck ones.  I have 200's and 400's that you can hang off the ceiling with...I used the 400 set to stop the router and had no worries of it shifting.  Love my MFS', sorry for those that did not get the chance to experiment with it.
« Reply #1053 on: March 15, 2017, 07:08 PM »
Picked up 2x sys carts, 3 mini systainers and some carved jigsaw blades today
Lots of the green stuff :))
Offline Trevin
« Reply #1054 on: March 16, 2017, 01:33 PM »
Happy Day!
I ordered the following and it was delivered yesterday!  Thanks Shane!
OF1400 Router
OF1400 Edge guide
DF700 XL
XL Domino asst
Seneca Domiplate for my DF500
Vac-Sys complete kit
Cadex 21g Nailer
Sortainer
Still waiting for Domino XL connector set and a Sys-ROCK
Cannot wait for the weekend!
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline kdzito
« Reply #1055 on: March 16, 2017, 02:28 PM »
The Carvex Accessory kit.  Not today, it was last Thursday.
Building one day at a time.
Offline kdzito
« Reply #1056 on: March 16, 2017, 02:29 PM »
Happy Day!
OF1400 Router
OF1400 Edge guide
DF700 XL
XL Domino asst
Cadex 21g Nailer
Sortainer
Trevin
It sounds like you won the lotto - twice!
Offline Cdwhyte
« Reply #1057 on: March 16, 2017, 05:15 PM »
First Festool, first post, Domino 500 with accessories and domino kit on order. Even with the potential 10% discount, was not willing to buy a dust extractor with it, just too expensive for my needs as a hobbiest doing woodworking in my 14x28 foot shed at home. I have most other tools I want/need, other than a good router table, so I'm hoping I don't get sucked down the festool path as I'm not sure I can afford to go too far.  Took me a while to finally pull the trigger on the Domino, hope I use it a lot and enjoy it.
Offline HarveyWildes
« Reply #1058 on: March 16, 2017, 05:20 PM »
Yeah - that's how I started as well.  Then I realized that you have to use some kind of dust extractor with it.  My old Festool mini was too inconvenient, so I ended up getting a CT 36 for the tool actuated switch onboard.
Offline copcarcollector
« Reply #1059 on: March 16, 2017, 05:23 PM »
@Cdwhyte
 [welcome] to the FOG and enjoy your new tools! Even if it's not a Festool vac, make sure that you do use some type of dust extraction when using the Domino. It helps cool the bit and pull debris out of the mortices.
Offline Cdwhyte
« Reply #1060 on: March 16, 2017, 07:02 PM »
Thanks @copcarcollector , I use a shop vac with the Rockler small port connectors for small tool dust collection. Works fine for my biscuit jointer, sanders, Kreg jig, etc, just loud, no variable speed, and no tool plug in.
Offline bkharman
« Reply #1061 on: March 16, 2017, 08:59 PM »
It will still work fine!!
Enjoy the new power cord smell...
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Offline DiscoStu
« Reply #1062 on: March 17, 2017, 03:53 AM »
My first Festool was a domino. I figured I'd get that and then the only other thing I craved was a TS55, well that was about two years ago and now my stack of systainers is about 12 feet tall! Be warned, it's a slippery path. As the other have said you really have to have extraction with a domino. With other tools dust extraction is nice or helps keep the cutting path clear etc but with a domino it's essential for it to work well. Enjoy.
Offline ear3
« Reply #1063 on: March 18, 2017, 05:07 PM »
Domino XL and 12/14 tenon assortment.
Have a bedframe project that I want to use the connectors on, and I'm also trying to expand my for-hire project capabilities to do RTA/KD work.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3
Offline leakyroof
« Reply #1064 on: March 18, 2017, 11:12 PM »
Bought a ETS EC 125/3 sander to try out for narrower work than my 150/5 is suited for.
Looked at the new version DTS 40O and its edge guard too. Surprised at how far away the spacing is on the guard as it sits from the sander body. But, Festool left the 'nose' or point of the Delta pad open and not enclosed by this guard while you're using it , so you can still get into corners or tight spots even with the guard mounted.... [scratch chin] [scratch chin]
Offline phineas
« Reply #1065 on: March 19, 2017, 12:56 AM »
The newer Festool saws come with a locking dust port connector that fits a 27mm hose.
Thanks. I measured the I.D. right after I posted and it is 27mm and its lockable, as you said.
A smooth dust port that is sitting on my workbench has an inner diameter of 30mm and an outer diameter of 39mm.  Bosch and Fein both have tool connectors that fit the Festool dust port.
I need an adapter to step down from either 1-1/4" or 1-7/8". I'll check those sources. Thanks for the tip.
Offline VesaS
« Reply #1066 on: March 21, 2017, 02:55 PM »
Bought PDC 18/4 Drill, BHC 18 Hammer Drill, SCA8 charger and one battery. Got that set quite easy for wallet  [smile]
Retailer had too big stock and want to get rid of some. Machines are basic versions, so they were without batteries.
260465-0
Vesa
Hobbyist with high demands (for tools)
Offline ChrisK1970
  • Wicked Awesome
« Reply #1067 on: March 21, 2017, 03:38 PM »
CT26! Yeah baby!
Dark Helmet.....Remember! Evil will always triumph over good. Because good is dumb!
Offline MLW
« Reply #1068 on: March 22, 2017, 01:52 AM »
I bought the awesome Festool dustbag today. It works like a charm.
Offline pillguy
« Reply #1069 on: March 23, 2017, 11:21 PM »
I sold my big tablesaw over the weekend and am going to use my bosch 4100 and festool stuff in my 10x16 workshop.  I am new to festool and bought a domino xl 700, both systainers of dominos, the lr32 system and 2 tracks. I got a makita track saw at home depot for $300 with a coupon.
I am looking forward to making good cabinets and am leaning to getting a MFT.
Offline Bob D.
« Reply #1070 on: March 25, 2017, 01:12 PM »
« Last Edit: April 04, 2017, 04:21 AM by Bob D. »
Offline SoonerFan
« Reply #1071 on: March 25, 2017, 02:19 PM »
Nothing too big for me......just new blades for my Kapex and TS55.
Offline ScotF
« Reply #1072 on: March 28, 2017, 12:16 AM »
I got a Centro technology Installers set...one of the last ones available. I debated, but I really like the bits from my other set and wanted to have some spares. I like the square drive bits too.
Offline Neal W
« Reply #1073 on: March 29, 2017, 04:34 PM »
Today I pulled the trigger on a TS55 REQ.  I'm upgrading from a grizzly track saw, which was OK, but I'm kind of hooked into the system aspect of Festool now (1400, Domino 500, ETS150/3, DTS400, LR32 set, holy rail).  It probably won't be here in time for the weekend, but I'm not sure if I will be able to use it anyhow.  Also picked up the TSO rail square yesterday.  My bank account is a bit lighter, but what else am I going to spend my tax refund on?
Turning perfectly good lumber into scrap and sawdust for more than 20 years!
Offline mattmass
« Reply #1074 on: March 29, 2017, 09:04 PM »
Always fun contributing to this thread :)
Finally got a T18. Wanted one forever.
Offline SoonerFan
« Reply #1075 on: March 29, 2017, 09:50 PM »
I debated this purchase as well.  I ended up getting one about 18 months ago.  I use it and the CSX as much as any Festool product I own.
Offline skids
« Reply #1076 on: March 29, 2017, 10:00 PM »
I got one today too! Should be a nice compliment to my CXS and Centrotec set!
The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it
Offline Osweezea
« Reply #1077 on: March 29, 2017, 11:26 PM »
Well, Ive been bit.  And bit bad.  It s the system concept for me that makes the most sense.  I work in the shop and in the field so either one i need to be versatile and flexible both in use and in transport.  So, in addition to my existing list
Kapex, UG Stand, wings
CT22
Domino XL
TS75
ETS 125
Pro 5
MFK 700
Last week I ordered
CXS set
T18 Airstream Set
Domino 500
OF2200
SYSROCK  ;D
CTL SYS VAC
2 ratchet clamps
Another Dust Deputy
and couldn't decide between the CT MIDI and the CT 26
Ended up ordering a CT26
Then found a used MIDI that I bought used locally that had another ETS 125 for a whopping $350!
I also got a used centrotec installers kit and a set of clamping elements.
Also the fasteners Systainer with all the cool bins!!
I used to think people who bought that much were crazy!  But I gotta say, I like this club!!
And most of that is in thanks to Timothy Wilmots and his youtube channel of his new shop and system workbench and his MFTC(Big thumbs up).  After a few big jobs through my new shop, I realized where I was losing money.  Watching Tim in his shop was an AHA!! moment for me.  Sheesh...I may need a vacation after I open all those packages.  Best of luck!
Its going to be a good few months of upgrades round the shop!!
« Last Edit: March 30, 2017, 02:41 AM by Osweezea »
- Legacy Woodworks -
Create Your Own Legacy
Offline Paul G
« Reply #1078 on: March 30, 2017, 12:06 AM »
Well, Ive been bit.  And bit bad....
.....After a few big jobs through my new shop, I realized where I was losing money.
Apparently still some money left over though  [big grin]
Enjoy the new tools!
+1
Offline woodsmann
« Reply #1079 on: March 30, 2017, 10:02 AM »
I'm placing an order before the price increase. Among other items, two new "families":
  • Domino 500 and Domino Assortment
    ETS EC 150/3, Abrasive Systainer, and grits from 80 to 400
I... can't... wait!   [blink]
Many thanks to Shane. He was able to answer my questions lightening fast!
Woodsmann
