Author Topic: What Do You Use To Mark Wood?  (Read 8286 times)
Offline darita
« on: September 20, 2018, 03:39 PM »
For the finish measurements, of course I use a fine pencil, however for breaking down sheets and boards, I've been using white chalk, just for gross markings.  Problem is, especially on the ply, the chalk is super tuff to get out with sandpaper.  When you think you've sanded it out, you really haven't and sometimes it shows up during finishing.
So, what can I use for marking while I'm just breaking down?
Offline Birdhunter
Re: What Do You Use To Mark Wood?
« Reply #1 on: September 20, 2018, 04:18 PM »
I use either a pencil mark or a strip of blue tape. Usually alcohol removes pencil marks. I use only alcohol with no oils (don’t use rubbing alcohol). I usually don’t mark the entire cut line only the beginning and end marks. If I want to mark the whole cut line, I apply blue tape and draw the line on it.
Birdhunter
Offline ChuckS
« Reply #2 on: September 20, 2018, 04:41 PM »
Using mostly hardwood for my projects. I mark stock with the pica dry pencils, if I want the marks to be seen easily (cabinet triangle markings, for instance) http://www.leevalley.com/en/wood/page.aspx?p=71121&cat=1,42935,42936,43509,71121
They, too, are not so easy to remove with alcohol or eraser; planing or sanding (100x or so) is usually required.
For line marking, pencils (0.3mm up to 0.7mm) are used.
If pencil traces are to be avoided, I use masking tape and pencils.
« Last Edit: September 20, 2018, 05:06 PM by ChuckM »
Offline darita
« Reply #3 on: September 20, 2018, 04:50 PM »
K...thanks.  I recently made a large box out of thin ply.  I used chalk marks to keep the orientation of the panels, prior to box jointing all the corners.  That's where I had the issues.
Offline lwoirhaye
« Reply #4 on: September 20, 2018, 06:22 PM »
Usually a standard pencil.  I'll use a lumber crayon, chalk or a carpenters pencil when marking rough boards for crosscutting prior to final milling.   I try to keep a yellow or white pencil around for finer marking on darker woods.
Offline Birdhunter
« Reply #5 on: September 20, 2018, 07:58 PM »
I use annotated blue tape to indicate parts that are supposed to go together. It’s just too easy to get mixed up. I normally use a Sharpie marker on the tape. When the parts are glued up, I peel off the tape.
Birdhunter
Offline rmhinden
« Reply #6 on: September 20, 2018, 09:37 PM »
I mostly use Zebra DelGuard 0.5mm Lead Mechanical Pencils.   It has an mechanism that makes it harder to break the lead.  See:     I think they are pretty cool and made in Japan.
I get them on Amazon, about $6. See:   http://a.co/d/ft3UjmD   They come in different colors.
They work well with the Incra rulers.
Offline Naildrivingman
« Reply #7 on: September 20, 2018, 10:18 PM »
@rmhinden How does the metal tip hold up to being dropped?  I’ve used Alvin 0.7 mm Draftmatics for many years, but the tips are pretty delicate.
Dance with who brung ya...
Offline rmhinden
« Reply #8 on: September 20, 2018, 10:24 PM »
Quote
I haven't broken any.   I occasional misplace them.   I lost one recently when I was using my CT22 to clean up shavings on my workbench and sucked up the pencil :-(   I decided I didn't want to take the bag apart to find it.
« Last Edit: September 20, 2018, 11:33 PM by rmhinden »
Offline Ajax
« Reply #9 on: September 20, 2018, 10:59 PM »
Blood
Kapex KS120, 2 x MFT/3, TS55 REQ, TS75, LS130, RTS400, RO90 DX FEQ, D90 Assortment, RO150 REQ, ETS 150/3, PRO5, D150 Assortment, DF 500, Domino 4/5/8/10 Assortment, DF700 XL, Domino 12/14 Assortment,  CT Midi, MFT/3, Kapex MFT, 2 x SysRoll
Offline zapdafish
« Reply #11 on: September 21, 2018, 08:18 AM »
with rough lumber chalk, jointer takes care of marks.  with ply a pencil and i usually just mark an inch at the start and inch at the end of the cut to align the track.
Pronouns: festool, festools
« Reply #12 on: September 21, 2018, 12:20 PM »
For smooth wood I like the Pentel Graph Gear.
https://www.amazon.com/gp/product/B000GAU2RU/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
If you remember to squeeze the pocket clip when you put it down you’ll never damage the tip since the pocket clip releases the lock that keeps the pencil point projected. The entire mechanism then withdraws into the barrel like a turtle’s head.
« Last Edit: September 21, 2018, 03:35 PM by Michael Kellough »
Offline rst
« Reply #13 on: September 21, 2018, 02:09 PM »
I'm with Micheal K, I keep 5 & 7mm in my carpenter pants/shorts pocket.  The 5mm works great with my new Woodpeckers Delvo squires as the retractable barrel fits perfectly into the holes.  I'm not wild about the pencil Woodpeckers supplied with the set but the Pentals work great.
Offline GoingMyWay
« Reply #14 on: September 21, 2018, 03:05 PM »
I bought a 12ct box of .7mm Paper Mate SharpWriter mechanical pencils last November for $3.32.  I still have a few. They've worked well for me.
One downside to them is that they're not refillable.  I keep a bunch spread around because I'm always misplacing my pencil.
Inquiring Minds Want to Know
Offline Birdhunter
« Reply #15 on: September 21, 2018, 03:09 PM »
I have several rOtring pencils around. All metal design with 0.5mm lead. They are perfect for Woodworking and Sudoko.
Birdhunter
Offline Longhair
« Reply #16 on: September 21, 2018, 07:07 PM »
I prefer a pen for sudoko
Offline Birdhunter
« Reply #17 on: September 21, 2018, 07:29 PM »
I pencil in the possible numbers in each square and erase them as they are eliminated. Can’t do that with a pen
Birdhunter
Offline Sparktrician
« Reply #18 on: September 21, 2018, 07:32 PM »
Same here.  I go so far as to mark inside, outside, front, back, top, bottom, plus any assembly notes or comments.  Once everything is out of glue-up, I peel off the tape and sand lightly.
- Willy -
Offline RobBob
« Reply #19 on: September 21, 2018, 07:39 PM »
Doesnt the Sharpie soak through the tape and mark the wood?
Sent from my SM-G960U using Tapatalk
Offline Birdhunter
« Reply #20 on: September 21, 2018, 08:46 PM »
I’ve never seen the Sharpie go through the blue tape.
Birdhunter
Offline HarveyWildes
« Reply #21 on: September 21, 2018, 09:23 PM »
Blood
Me too, not on purpose.
Grease pencils for mounting and planing.
Regular and mechanical pencils for everyday marking.
Blue tape if I really need to be careful.
Knives for cut lines.
Sharpie if I know it won't show.
I have a pica dry lead pencil, haven't figured out why it's special yet.
Offline ChuckS
« Reply #22 on: September 21, 2018, 10:04 PM »
Snip.
You can sharpen the lead!
Offline James Biddle
« Reply #23 on: September 21, 2018, 10:45 PM »
I discovered General's Charcoal White Pencils for marking on dark woods.  They sharpen like normal pencils.  Amazon carries them.
Offline Frank-Jan
« Reply #24 on: September 22, 2018, 04:33 AM »
I was curious what a non-refillable mechanical pencil looked like. Found this:
« Reply #25 on: September 22, 2018, 07:50 AM »
I've never had any issues with bleed-through.  Remember, blue tape is designed to prevent paint from getting through to protected surfaces.
- Willy -
« Reply #26 on: September 22, 2018, 08:19 AM »
How do you guys feel about the mechanical durability of these Pentels?  As I stated, I’ve been using the Alvin Draftmatics for years.  In addition to not dropping the pencil tip down (they seem to always land tip down kinda like jelly toast), the internal mechanics wear out in about one year.  I really like the Alvin’s, but at $15 each, they do get spendy.
Offline Birdhunter
« Reply #27 on: September 22, 2018, 09:04 AM »
I have a few rOtring pencils that are about 5 or 6 years old and going strong. If you drop them on the tip, they are toast.
Birdhunter
Offline rst
« Reply #28 on: September 22, 2018, 10:53 AM »
Naildriver...I keep two Pentals in my pockets at all times.  I tried various mechanicals before I settled on these.  I've never had one break.  As noted above the best thing is that the lead tube retracts up into the body even with the lead extended although I usually retract the lead anyway.  I have at least 6-8 and keep them anywhere I might need a pencil.  I've had Fastcaps Big boys, they fell apart still use Picas but the mechanicals do not need sharpening.
Offline demographic
« Reply #29 on: September 23, 2018, 09:39 AM »
Lumber crayon, chisel tipped carpenters pencil of a knife, depending on what I'm marking or the level of accuracy I need although the lumber crayon is mostly for writing sizes on framing so I can see that size when I'm back on the ground or writing down what part fits to whatever other part.
Its only used for writing on first fix items that aren't seen when its finished.
