Author Topic: Vecturo OSC 18Li  (Read 792 times)
Vecturo OSC 18Li
« on: January 12, 2020, 03:23 PM »
Hello!
Does anybody know if there exists blades for this machine which could cut 2-3mm steel plate??
Regards
Kåre!
Offline Bert Vanderveen
Re: Vecturo OSC 18Li
« Reply #1 on: January 12, 2020, 03:47 PM »
Fein has some cutters that will cut 2 mm sheet metal. Maybe you can find something more appropriate on their site:
https://fein.com/en_us/
« Last Edit: January 12, 2020, 05:35 PM by Bert Vanderveen »
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
Wishlist: ETS EC 125 w 150 pad, DTS
Offline grobkuschelig
« Reply #2 on: January 12, 2020, 04:36 PM »
Bosch make a couple of carbide teeth blades for sheet metal and steel bar cutting etc.
- OSL114C or OSL114MF
- OSL034C
Maybe those do what you need. Might be more readily available than Fein...
« Reply #3 on: January 12, 2020, 04:44 PM »
Does both the Fein and Bosch blades fit into the New Festool Vecturo??
« Reply #4 on: January 13, 2020, 10:00 AM »
The Vecturo has a „StarlockMax“ Tool holder.
Starlock is a Standard developed jointly by Fein & Bosch.
There are three Versions:
- Starlock
- Starlock Plus
- Starlock Max
The Plus and Max Versions are for Blades that require more power from the tool.
So only specific machines can drive these.
But they are downwards compatible.
So, when your machine is certified for Starlock Max (Vecturo, Fein SuperCut, Bosch GOP55..) it can also use Starlock Plus and Starlock Blades.
When your machine is certified for Starlock Plus (Fein Multimaster, Bosch GOP18V...) it can also use Starlock blades, BUT NOT STARLOCKMAX.
hope this helps...
Offline Knight Woodworks
« Reply #5 on: January 14, 2020, 05:24 PM »
Thanks!
Not the OP, but I found helpful.
John
