Author Topic: Vecturo and oscillating multitool Blades- What fits what reference  (Read 18445 times)
Offline SRSemenza
OK, so I am starting a topic with no content  [big grin]
       Hoping that this can become a reference (sticky) as to which blades fit which oscillating multitools. And maybe a good explanation of the various types of mountings.  Which types are compatible, cross compatible, backwards compatible , etc. There have been a number of topics  and questions on this over recent years and I still can't easily sort it out since it is spread through out the forum and there is also incomplete or over ridden terminology involved.
     I would like to keep it to  just the blades for ease of reference. Blade adapters OK, but not other accessories.
    Those who know.........................  please contribute to this topic. I think it will help a lot of people.
Offline yetihunter
Corded Vecturo uses an outmoded mount that was exclusive to the Fein Supercut before the adoption of Starlock.
Cordless Vecturo uses Starlock (Fein Multi-Talent), Starlock Plus (Fein Multi-Master) and Starlock Max (Supercut).
Before Starlock, Bosch came out with the OIS mount that much of the industry has adopted after Bosch moved onto Starlock.
I'm not aware of Starlock/OIS blades being interchangeable without adaptors.
Starlock and Starlock Plus blades are backwards compatible with the immediate previous generation of MultiMaster.
Plunge base for both Vecturos requires the longer Supercut/Starlock Max blades only made by Fein (or sold as Festool).
There's your jump off.
Offline Danie
Re: Vecturo and oscillating multitool Blades- What fits what reference
« Reply #2 on: October 20, 2020, 05:15 AM »
The Fein 63733005010 adaptor and clamping bolt will allow you to fit Fein Multimaster accessories on to the Festool Vecturo OS 400 which uses the Fein Supercut 2.0 mounting. I bought this adapter and it works fine with Multimaster accessories. But it seems that there is a problem when using the Festool plunge base: the adapter protrudes a half-inch which means that there's a gap between the Multimaster blades and the magnet.
The Fein 35222952050 adapter is required to fit Starlock blades on Supercuts tools with a quick in lock such as the Festool Vecturo OS 400. I haven't used it yet, but it seems that this adapter will accept Starlock, Starlock Plus and Starlock Max accessories.
Offline ElectricFeet
« Reply #3 on: October 21, 2020, 10:42 AM »
I'm trying to get hold of some Festool 500129 blades for my Vecturo OS 400, which are the long ones that work well with the magnet on the plunge base**, so I was doing a bit of research on this and came across the following pics on the Fein site, which is a useful reference:
**Am I right in thinking you can only use the long blades with the magnet?
Offline WP
« Reply #4 on: January 14, 2021, 11:16 PM »
According to the Festool live video on the OSC 18, only the long blades work with the magnet and turn speed down to 4.
Question - is there an adaptor to allow other blades to fit the OSC supermax fitting?
Offline DynaGlide
« Reply #5 on: January 15, 2021, 07:38 AM »
If your question is can you put the long blades on non-starlockmax, then no not that I could find. I picked up a Fein Multimaster last year with the intention of using it with the plunge base. Unfortunately, I didn't do enough research and I can't use long blades with Starlock Plus.
Instagram @matts.garage
Offline SouthRider
« Reply #6 on: January 15, 2021, 09:10 PM »
I sold my 15 year old Fein to my brother in law, and bought a corded Vecturo about a year after they came out (so I could get and use the accessories like the plunge base). I also bought ALL the adapters so I could use the myriad collection of blades I had accumulated.
Problem is now ANY time I want to use the saw I grab the blade I want for the application and then spend ten minutes fussing with WHICH adapter, WHICH bolt, and WHICH orientation of the adapter to use to mount the blade I want.
AND - about a year later the Fein died, brother in law took it to the local nail gun repair shop, they sent it to Fein - who LOST it, and sent him the newest most powerful model as a replacement.......
Last - Every time I need it now it seems that it's out somewhere about a hundred feet from electricity......... This IS a tool that deserves to be cordless.
"We, the willing, led by the unknowing, are doing the impossible, for the ungrateful. We have done so much, for so long, with so little, that we are now qualified to do almost anything, with nothing at all."
Offline SRSemenza
OK, so is this correct?
   No adapters
           Bosch Starlock fits        Festool OSC18.
           Bosch Starlock Plus fits Festool OSC18.
           Bosch Stralock Max fits Festool OSC18.
« Last Edit: March 13, 2021, 11:28 PM by SRSemenza »
Offline TinyShop
Ahhh, but you can use long blades with Starlock Plus tools:
https://www.festoolownersgroup.com/festool-tools-accessories/blade-recommendation-for-festool-vecturo-osc-18/msg615284/#msg615284
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline TinyShop
Ahhh, but didn't we figure out that we can use long blades with Starlock Plus tools?
Offline tbeaulieu
Yes ... https://www.oslotoolcompany.com/
Offline JINRO
« Reply #11 on: December 22, 2021, 09:21 PM »
I'm coming from Dewalt and Milwaukee multi tool and finally jumped on Vecturo.
I already have many blades for different occasions.  Do Vecturo accept blades from Dewalt/Milwaukee? or is there an adapter I can purchase? It seems like many are only talking about Bosch and Fein blades aside from Festool one.  I can't seem to find definite answer if Vecturo accepts universal blades.
Offline slavi.yordanov
« Reply #12 on: December 22, 2021, 09:25 PM »
It only works with Starlock. I recommend Bosch/Diablo. They are expensive but last forever. Fein blades are meh.
Offline JINRO
« Reply #13 on: December 22, 2021, 09:27 PM »
Ah... so looks like I can't use current blade sets I already have... but good to know Diablo makes compatible blade! :)
Offline squall_line
« Reply #14 on: December 22, 2021, 09:28 PM »
There's a bit of an explainer in this article, as well.
https://www.protoolreviews.com/starlock-oscillating-multi-tool-system/
« Reply #15 on: December 22, 2021, 09:31 PM »
Starlock is much better system from my experience. The good thing is the OSC18 is compatible with all types of starlock (regular, plus, max), unlike Bosch. They don’t have a cordless tool that works with Starlock Max blades.
Offline JINRO
« Reply #16 on: December 22, 2021, 10:03 PM »
Thank you all for explanation! :)
« Reply #17 on: December 23, 2021, 11:13 AM »
I've used this Fein adaptor on my OS 400 Vecturo.
Offline rst
« Reply #18 on: December 24, 2021, 09:02 AM »
I use the same Fein adapter to the the Bosch carbide blades which are my favorites.
« Reply #19 on: December 24, 2021, 10:04 AM »
And here's a photo of the Fein adapter and the Bosch carbide blade on an OS 400. These Bosch carbide blades are really killer in plaster, they just keep cutting forever, I'd imagine they're also very good for nails.
Offline Frank-Jan
« Reply #20 on: December 24, 2021, 04:23 PM »
I bought one of those bosch carbide blades a while back that had the mounting hole for the fein supercut, so no need for an adapter. They were selling the single blades at the counter on clearance because of the starlock (but they still were pretty pricey, so I didn't stock up, only got one to try) it lasted a long time, and I cut quite a few screws with it.
I also got a similar similar adapter to use the starlock blades on my old supercut.
I'm getting a cordless vecturo soon, there are "deals" regularly, but I'm still figuring out which one to get (bare tool, bare tool with free battery, set with the base etc.)
Offline Max Fracas
« Reply #21 on: January 03, 2022, 07:43 PM »
@Cheese, do you know the part number for the adapter shown in the first picture in reply #17? I have a corded OS400 and bought the Fein 35222952050 adapter hoping to use Bosch Starlock blades. It works, but the pin doesn’t have the four ridges that show in the pin in the picture you posted. Seems those ridges would make for a better fit in the Starlock blades. Could be I’m missing something!
« Reply #22 on: January 04, 2022, 10:14 AM »
Hey @Max Fracas try Fein number 63733005010. I'm pretty sure that's it.
