Author Topic: Vacuum Clamping  (Read 509 times)
Offline Dove_Tail
Vacuum Clamping
« on: August 10, 2019, 08:23 AM »
Reviews on the VAC SYS are all stellar and I'm not ready to spend $1,000
I'd like an alternative to the VAC SYS or $10,000 for a Barth vakuuLIFT  [big grin].
I just met a guy who used a venturi vacuum generator with a shop compressor and a set of vacuum pads. He said it worked great.
Here's what I've put together as a sub-$200 solution that may have potential:
Venturi Vacuum System from Infinity for $89 https://www.infinitytools.com/venturi-vacuum-system
Set of PodZ for $83 https://www.veneersupplies.com/produ...ping-Jigs.html
I understand that this is not as elegant as the VAC SYS...
Has anyone tried a version of this solution, or either of these components?
Offline infer
Re: Vacuum Clamping
« Reply #1 on: August 10, 2019, 12:28 PM »
Even though I find my vac sys excellent I was using some vacuum pods on my cnc before with good results. Just need a decent pump.
https://www.vakuumtisch.de/VacEasy-series
