Author Topic: boom arm questions?  (Read 841 times)
Offline festal
boom arm questions?
« on: May 04, 2022, 07:26 AM »
Hello all.
I recently got CT48 and boom arm.  I currently have 3.5m D36 hose and its a bit short.  Looking for ideas on how to extend it.  Don't want to shell out over $200 on 5m D36 hose.  I have few older d27 hoses but don't want to reduce the size.   Does D50 hose fit into the boom arm clips?  Any other ideas?  Would getting the bosch hose and cutting it to about 2m work and using the coupler to attach it between the d50 hose and D36 work?
Also I'm missing the power extension cord that comes with the boom arm, anyone have a picture of what it looks like?  what Part number is it?
Are the stabilizer feet needed?  my boom arm didn't come with them.
Thank you
Offline guybo
Re: boom arm questions?
« Reply #1 on: May 04, 2022, 09:03 AM »
Hi, mine was sold w/ 1meter 50mm hose item#4 to make up the difference, any 16 ga. plug it cord will work,using the bosch or any other hose will work,I took the stablizers off,and made a mini boom arm for the wcr 1000.Item #4 from what is listed can be purchased  from retailer.good luck guy
Offline festal
boom arm questions?
« Reply #2 on: May 04, 2022, 11:24 AM »
Yep mine came with 50mm extension hose as well but it seems that with my 3.5m hose attached it’s a bit shorter then I want it to be so trying to extend it a bit. Thank you for the part list
So just use the plug-it cord from the tool?
Offline guybo
« Reply #3 on: May 04, 2022, 11:31 AM »
Hi, I have plenty w/mft3 for any operation,and yes any plug it. [big grin] it is a system
Offline festal
« Reply #4 on: May 04, 2022, 11:32 AM »
Is your hose 3.5m or 5m? Yep it’s a system that I’m learning just looked up part 2 from your picture it’s $110 lol
Offline guybo
« Reply #5 on: May 04, 2022, 11:52 AM »
Hi, 3.5 and i made a small whip hose for extra lenght, however you can buy a 10m 16 ga. plug it .ihave one for a 2 hose planex. guy
Offline festal
« Reply #6 on: May 04, 2022, 04:52 PM »
Thats what i have and having hard time reaching stuff on the floor and i have to pull the vacuum close to me to get it to reach
Offline FestitaMakool
« Reply #7 on: May 04, 2022, 05:12 PM »
That’s a clever idea!  [smile]
