@LumberSmith I had the same problem until I realized that the rail/GRS will move unless you clamp it
so for a 4x8 sheet of ply
1) cut factory edge (no need to clamp rail)
2) cut one of the 4'/48" ply edges using the GRS and clamp rail
3) verify that rail hasnt moved during clamping cuz it might.
4) Register GRS on 8' edge which you cut factory edge off and set PG to desired width and clamp rail.
5) VERIFY THAT RAIL DIDNT MOVE DURING CLAMPING
6) cross cut to rough length make sure you can use one of the edges (48") that you previously cut and check for square.
Make sure your tape is not damaged bent or otherwise inaccurate.
Thats what I recently learned and it has been working fine for me since.
If you are joining two rails together to make the 8' cut make sure those rails are accurately joined together.
they maybe the issue.
@gunnyr Outstanding post .
