Author Topic: TSC 55 REB disassemble  (Read 1388 times)
Offline Stege
« on: January 14, 2022, 02:43 PM »
I will change the 10017862   Protective cover but I can't get the bolt out.
Offline Svar
Re: TSC 55 REB disassemble
« Reply #1 on: January 14, 2022, 03:11 PM »
It is pressed fit and can be pushed/hammered out towards the handle/motor side.
What model is it? Looks like the handle is not blocking the pin and you don't have to remove motor housing.
Offline Stege
« Reply #2 on: January 14, 2022, 03:37 PM »
thanks, it is a TSC 55 REB
Offline Svar
« Reply #3 on: January 14, 2022, 03:53 PM »
Good luck. Seems like they made an improvement. Press fit was on all previous models. I assume this one too. Handle side of the pin has tiny teeth/knurling around perimeter visible as is. Those chew into the aluminum housing securing it in place.
Offline Stege
« Reply #4 on: January 14, 2022, 04:10 PM »
That may well be the case. It has to hold up in the new part.
Offline Stege
« Reply #5 on: January 15, 2022, 06:06 PM »
Yes your answer was correct.
Big Thanks
Offline Svar
« Reply #6 on: January 15, 2022, 07:14 PM »
I found that on all TS saw I tried there is a little play between the pin and plunge part of the saw. Such that it can wobble laterally 0.1 mm or so, the pin is also slightly undersized. What I like on Mafell is that it's bronze bearings with perfect fit.
