Author Topic: Recommended profiles for LS 130? Useful starters?  (Read 1043 times)
Offline tbeaulieu
« on: January 14, 2022, 09:38 AM »
Hi! I have an LS 130 coming in for my home hobby shop. My idea is to use it for sanding juice grooves in cutting boards, softening (bull nose) 3/4" edges, such as shelves, getting into corners of shelving/cabinet builds, etc. I see that it comes with the 90 degree, which would handle the corners.
I've read that the 25mm concave would be good for roundovers of 3/4".
I'll figure out which convex I need for grooves.
What else? Any other common, useful profiles that you'd recommend?
Thanks!
Offline Coen
Re: Recommended profiles for LS 130? Useful starters?
« Reply #1 on: January 14, 2022, 01:06 PM »
From what I've read the pads dont have an infinite shelf life, so migt be best to not collect them all at start but buy as you need.
Offline tbeaulieu
« Reply #2 on: January 14, 2022, 01:08 PM »
Whaaaaa?! Having a hard time wrapping my head around that dirty pool.
« Reply #3 on: January 14, 2022, 01:34 PM »
They’re made from foam and foam doesn’t last forever. Sunlight is particularly harsh.
Offline squall_line
« Reply #4 on: January 14, 2022, 01:36 PM »
The pads use the same type of rubber foam that is found in many other consumer goods, including sneakers, that breaks down over time.
I have a friend who collects/collected Air Jordan sneakers.  He opened one box 10 years later to find an upper and a lower sole, but the foam holding them together was completely worthless and disintegrated.
As Coen mentioned, if you don't plan on using a particular pad for a few years, you're better off saving your money than finding it completely useless when you go to use it.
Offline Coen
« Reply #5 on: January 15, 2022, 06:27 PM »
Also keep in mind some dealers sell very few of those pads while always keeping stock, so they might have aged at the dealer..
