Author Topic: Ts55 clear view guard  (Read 955 times)
Offline Compasswoodwork
« on: December 30, 2020, 02:40 PM »
Hi guys,
Whilst sorting out my gear earlier, I took the plunge saw out of the box to clean it up a bit, and in the process I took out the clear view guard to clean it up but for the life of me I can't seem to get it to click back in, is there something I'm missing? I've got the green splinter guard but would prefer to whack the clear one back on.
Any tips would be greatly appreciated!
Offline Chris Wong
  • Festool Dealer
  • I make things that challenge me.
    • Flair Woodworks
Re: Ts55 clear view guard
« Reply #1 on: December 31, 2020, 12:57 AM »
I guess I’d start by making sure it’s not broken or deformed. Not sure how else I can help!
Chris Wong, http://FlairWoodworks.com
First Festool was a free pencil.
Shipping live-edge cribbage boards around the world since 2010.
Offline Frank-Jan
« Reply #2 on: December 31, 2020, 02:15 AM »
Have you removed the blade cover at some point to clean out the saw housing or replace the dust collection elbow?
In that case the little spring clip that holds up the view guard could be missing.
https://festoolownersgroup.com/index.php?pretty;board=ask-festool;topic=ts55-where-does-this-metal-clip-part-go.msg385930#msg385930
« Reply #3 on: December 31, 2020, 06:08 AM »
Thanks very much, yep that spring clip is missing! Will have to look around and hope that it didn't get swept up 😑
Offline Coen
« Reply #4 on: December 31, 2020, 07:33 AM »
Just to nit pick; that is the TS55R; not the older TS55?
« Reply #5 on: December 31, 2020, 09:18 AM »
It's the newer one yes, still can't find that clip  [sad]
Offline Frank-Jan
« Reply #6 on: January 01, 2021, 12:23 PM »
The TS55 doesn't have a clear viewguard, only a green anti-splinterthing, the even older ATF55 only has a clear viewguard, no option for an antisplinter-insert.
If you need to order a replacement the partnumber for the spring is 466084
« Last Edit: January 01, 2021, 12:27 PM by Frank-Jan »
Offline mino
« Reply #7 on: January 01, 2021, 08:27 PM »
Just forget it and use a worn-out green anti-splinter guard piece for uses where a good one is not needed. That way you can have the screw all the time in the saw and just put in a fresh/good anti-splinter piece when needed not worrying about the screw storage. For the occasional edge-cutting near a wall you can do without it anyway.
Mine it is sitting in my "unneeded Festool things bin" ever since I got the saw. Come to think of it, I may remove the spring next I clean the saw so it does not create unneeded obstruction when adjusting the green ones.
Another benefit is that without the spring you can put 165mm blades which would come in contact with (only) the spring otherwise.
8)
AGC 18(@AGC 125 flange), BHC 18, C 12, CTM 36, DRC 18/4, PSC 420, RS 200, TSC 55
Narex: EDH 82, EFH 36(fixed@LR32), EVP 13 H-2CA
My Precious FS/2: 376, 376, 376 holy, 632, 1016 holy, 2520
