Author Topic: TS55 accurate Mitre cut  (Read 206 times)
Offline Zebt
« on: May 12, 2020, 06:28 PM »
Hi, I'm cutting 100mm x 21mm teak.
Table set up as usual, straight edge set and checked with right angle, saw set to 45 deg.
I'm finding a tiny bit of variance in the accuracy of the cuts, I think it may be as the saw works harder and maybe twists slightly causing a variance, i've tried to be steady and slow. I need the accuracy as i'm doing 4 mitres to form a frame or open ended box (not a flat frame, if that makes sense!).
I've got my stock clamped down, i'm using two pieces of same stock either side under the guide rail to create stability.
My blade could probably do with a sharpen but it doesn't seem to struggle or burn too much, just a normal amount.
I'm about to try and do several shallow cuts to see if that works but thought I would throw this out there to see if the more experienced can give me some tips.
Many thanks!
Zeb
Offline Peter Halle
Re: TS55 accurate Mitre cut
« Reply #1 on: May 12, 2020, 07:09 PM »
In reading your post I take it that you are beveling the blade.  Correct?
If so, after a decade or so of using the track saw I can tell you that in my personal experience a non-sharp blade in this situation can indeed cause head scratching issues.
You might want to at least try to clean it and see if that helps.
Good luck!
