Author Topic: TS 75 Panther blade  (Read 622 times)
Offline bkharman
TS 75 Panther blade
« on: May 16, 2020, 01:20 PM »
I know over time, there have been people who say the panther blade is not worth it. I say they are wrong. Dead wrong!
I just ripped about 45’ of hard maple for some face frames and here was the worst kerf lines I saw. Probably because I had to stop moving the board for a second or two.
It does help that I am doing this in my CMS...
And as a PSA, definitely don’t forget to check your hose connection!
Project details coming soon!
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Offline bkharman
Re: TS 75 Panther blade
« Reply #1 on: May 16, 2020, 01:29 PM »
Here is the off cut ...
Cheers. Bryan.
Online ear3
« Reply #2 on: May 16, 2020, 04:04 PM »
Agreed.  Panther definitely worth it when ripping north of 2" on TS75.
Offline Rick Herrick
« Reply #3 on: May 16, 2020, 07:06 PM »
A side question... Is putting a track saw into this CMS the way we do tablesaw operations in Festool land ?  I am new to FT and had not seen any table saw options.  Can I do this with a TS 55 as well as the 75 ?
Offline FestitaMakool
« Reply #4 on: May 16, 2020, 07:38 PM »
Yes, but availability is scarce, even in Europe since Festool discontinued the entire CMS system here last autumn.
There’s two modules for both plunge saws: CMS-TS 75 and CMS-TS 55R (“R” being the latest version)
For table saw options there are now 3 in Europe. All three comes in a bare saw version and “set” version with all the bells and whistles.
See here: (For some reason Festool is naming CS 50 and CS 70 Precisio saws as “Trimming saws”
And the new TKS 80 as “Table saw” (Precisio saws, CS 50 and 70 are pull saws, as Mafell Erica)
First link Leads to the two Precisio saws (I have the CS 50 SET version)
https://www.festool.com/products/semi-stationary-work/trimming-saws
https://www.festool.com/products/semi-stationary-work/table-saw/575781---tks-80-ebs
Offline bkharman
« Reply #5 on: May 16, 2020, 07:39 PM »
It is not available to purchase in the US. It voids you’re warranty. It is not UL certified (not sure how aluminum can be UL) but it is one of the most useful things and is at the core of my setup.
Feel free to PM me if you want more details.
Cheers. Bryan.
Offline Thompmd
« Reply #6 on: May 16, 2020, 07:50 PM »
The cuts look great!
Newbie here but you guys suggested a panther blade for my TS75 on some 2-2.5” Walnut. Fantastic.
Sawstop Industrial Saw, TS75,2 1400 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,
« Reply #7 on: May 16, 2020, 08:33 PM »
Thanks guys.  This TKS 80 looks very interesting but also most likely pretty expensive.  Still haven't found the expected price.
« Reply #8 on: May 16, 2020, 11:01 PM »
I have only one Panther blade (for the 55) and it’s horrible. Guess I should buy one for the 75 and hope it’s better. Have had good results with the Universal blade even in thick hardwood (the reason I haven’t bothered with another Panther yet).
Offline bkharman
« Reply #9 on: May 16, 2020, 11:40 PM »
I agree that the 55 blade is not as good. I also think my CMS setup helps a bit. Being more like a true table saw.
Cheers. Bryan.
Offline Coen
« Reply #10 on: May 17, 2020, 07:47 AM »
CMS can still be bought new. Use Festool EKAT. You have to assemble yourself though. I bought the PS module that way.
