TS60 has a brushless motor, so I would expect the 50 or 60 Hz won't matter.
Hi, welcome to the fog,it shows they offer both in 110and 240v.So it may soon be offer statside, in120v.
@mino ; seems you were wrong
Aren't most electronic things designed for a + or - of 10% anyway? This would hit right close to that.
Not everything. The basic bedside alarm clocks use the mains frequency to keep track of time. They might work at 100-250V, but if you bring a European one to the USA and sync it at midnight, you will find your 07:00 alarm going off at 05:50. This was a big stink fours years ago when, due to some payment conflict between energy companies in the Balkans, all those in clocks in Europe got 5 minutes behind in two months (due to prolonged 49.9 Hz instead of 50). At that point people started to correct them manually... but in the following months they "repaired" the time gap by running 50.1...
Also some types of motors run at mains frequency; 3600 rpm in the USA, 3000 rpm in Europe.
But a lot of modern electronics just starts out with rectifying everything and those can be build to accept 100-250 50-60 Hz. Some of those phone adapters even work on 48V.
