Hello folks, I just spent a couple hours researching the rabbit hole that is track saw blades and I'm no further along
I have a corded Makita track saw which I plan to eventually replace with a TS55. I'm building a custom MFT style assembly table with some accessories from Dash-board and just ordered some new tracks so I figure now is the time to standardize my blades. So couple questions:
1. Any reason not to simply go with Festool blades? I don't mind the fact that they'll be 160mm vs 165mm that I'm currently using in the Makita. Price isn't my primary concern, rather cut quality and durability.
2. I suppose I should stick with the normal kerf versions, instead of the 1.8mm thin kerf blades as I'm using corded saws. The blade I'm currently using is Makita's thin-kerf 56T blade, and it seems ok, but cut quality is more important than speed to me in the end.
3. If I stick with all Festool blades of the same kerf, will they all register the same in terms of the splinter guard? I'd like to have a general purpose blade that I keep in the saw 80% of the time, but there are times when I want to be extra careful with veneered plywood or melamine etc or if I want to rip some hardwood which I'd want to swap blades for.
Would appreciate any advice. Thanks!
