Author Topic: TLC 6 vs SCA 8  (Read 2417 times)
Offline Mike35x95x1
TLC 6 vs SCA 8
« on: May 04, 2021, 06:07 AM »
Hi, does anybody know the difference?
Thank you
Mike
Offline Alex
Re: TLC 6 vs SCA 8
« Reply #1 on: May 04, 2021, 06:35 AM »
SCA 8 has Airstream and the TLC 6 doesn't.
That means it has a built in fan that cools the battery, so you can charge with a higher current, making for a faster charge. The fan also makes it pretty noisy. I don't like them, but everybody has to decide for themselves what they value most.
Offline Mike35x95x1
Re: TLC 6 vs SCA 8
« Reply #2 on: May 04, 2021, 06:40 AM »
(Attachment Link)
Thanks a lot
Offline threesixright
Re: TLC 6 vs SCA 8
« Reply #3 on: May 04, 2021, 08:28 AM »
The SCA 8 also has an indication how much time it takes to charge the battery / shows capacity.
Yeah as @Alex says, very noisy. The fan kicks in almost immediately and doesn't stop even when it's fully charged.
They could have made that a bit smarter with a NTC or so IMO.
Offline slavi.yordanov
Re: TLC 6 vs SCA 8
« Reply #4 on: May 04, 2021, 12:50 PM »
I really don’t think the SCA8 is too noisy. I prefer the faster charge times too. Footprint is the same too.
Offline Frank-Jan
Re: TLC 6 vs SCA 8
« Reply #5 on: May 04, 2021, 01:37 PM »
I have both a TLC 6 and a SCA 8 since oktober last year. (the tlc 6 came with the pdc -tid set, the sca 8 I bought seperately for the bhc basic I got at the same time). I like the SCA8 much better, the tlc 6 makes an annoying sound, like coil whine, the fan from the sca8 doesn't sound annoying, and I also like the charge-time indication.
Offline Paul_HKI
Re: TLC 6 vs SCA 8
« Reply #6 on: May 04, 2021, 02:06 PM »
Vote for the SCA 8 here too.
TSC 55, TS 55, DF 500, DF 700 (XL), OF2020EB+, OF900E, CXS, TXS, T18+3, PDC 18/4, RO 150, RAS 115.04e, RTS 400, ETS 125, ETS 150/5 EQ, CTL MIDI, FESTO SR151 E-AS, CTL-Sys, MFT/3, Sys-Roll etc.
Offline notenoughcash
Re: TLC 6 vs SCA 8
« Reply #7 on: May 04, 2021, 02:21 PM »
sca8
faster charge time, no anoying beep every 10 seconds, and charge time indication.
in fact it sounds the same as my makita
turns out that woodworking is 1% making things you'll use, 4% making bespoke high end firewood, 15% cleaning, and 80% looking for the bl**dy thing you just put down
Offline SRSemenza
Re: TLC 6 vs SCA 8
« Reply #8 on: May 06, 2021, 09:59 AM »
sca8
The TLC6 beeps every ten seconds?  Are their different versions?  I have not noticed mine beeping.
Offline mino
Re: TLC 6 vs SCA 8
« Reply #9 on: May 06, 2021, 01:35 PM »
For professional use, SCA 8. The noise is par for the course, but nothing too bad.
The fan is important when the battery is already "pre-heated" from use in a TSC or AGC etc. and you need it charged ASAP. If battery is too hot, the TCL chargers will refuse to charge until it cools down. That can add half hour to the charge time easily.
The time difference is not that big when the battery is exhausted but "cold" from light use.
For home/occasional use TCL 6 is better because there is usually no hurry and there is no noise either.
Ideally:
I would want to have two SCA 8 for quick charging coupled with two of TCL 6 when not in a hurry. :D
I have two SCA 8 and one TCL 3. I use the SCA 8 only when expect to need the battery again during a work session or when need to charge more than one battery.
Any other time I prefer the TCL 3.
I have all chargers "installed" in a charging station in the shop, so packing-unpacking is a non-issue. SCA 8 would get plus points there if I had to pack after a work session, including the charger.
When the Machine does not have a brain, use Yours.
Protool: AGP 125, VCP 260
My Precious: 2x 376, 376 holy, 632, 1016 holy, 1400 holy, 2400, 2x GRS 16 PE, GECKO-DOSH
Offline squall_line
Re: TLC 6 vs SCA 8
« Reply #10 on: May 06, 2021, 02:11 PM »
I'm one of those people who can hear the TCL-6 "whine" that people talk about.  I was in my basement the other day and heard it even though it wasn't charging, so I unplugged it.  My SCA-8 hangs out in the garage next to my Makita charger; they can play "dueling fans" whenever they want, in my opinion.
There are other tones I can't hear at all, but electronics whine is still right up there for me.  It's one of the ways I discovered my UPS was dying a few months ago, too, so it occasionally comes in handy.
Offline Rick Herrick
Re: TLC 6 vs SCA 8
« Reply #11 on: May 06, 2021, 04:17 PM »
I am in that camp as well.  The fan on the SCA seems kind of normal but that whining on the TCL drives me up a tree, even though its not really that loud.
Offline mrB
Re: TLC 6 vs SCA 8
« Reply #12 on: May 06, 2021, 05:31 PM »
I’m still under 40 (just) but I only noticed the whine of the TLC when someone writes pointed it out to me
Re: TLC 6 vs SCA 8
« Reply #13 on: May 07, 2021, 02:48 AM »
sca8
mine does.  im from the uk, so that might have something to do with it, but yes, it drives me up the wall.  mine's bust atm, so waiting on a spare part.
Offline Vegetable
Re: TLC 6 vs SCA 8
« Reply #14 on: May 07, 2021, 10:39 AM »
My TLC beeps and whines so bad I try to be in a different room when it is on. I've finally cracked and ordered an SCA 8.
Offline demographic
Re: TLC 6 vs SCA 8
« Reply #15 on: May 07, 2021, 11:17 AM »
I don't mind the fan noise because at least the fan is doing something useful but I have a TCL6 and that makes a bloody irritating beeping noise every few seconds.
They didn't need to have that noise and some wiseguy on here suggested I take it to bits and cut the buzzer wire.
Uh huh...
I honestly have no idea what they were thinking when they made that charger cos other than the beeping its fairly good.
Offline demographic
Re: TLC 6 vs SCA 8
« Reply #16 on: May 08, 2021, 04:20 AM »
For those who maybe live in a market where the TCL doesn't have a beeper? Ill describe what mine does.
When I first start charging it has a pretty quiet constant whine for maybe a minute or so,then during the main charging phase its quiet with a little 'Bip' every few seconds.
When the battery is fulky charged theres a constant whine again.
All of those noises are indicating things that can be shown with a LED.
I'm not so fussed about it making a noise when the battery is fully charged, that fulfills a function and tells me it can be removed and or disconnected.
Its the "Bip" every few seconds thats darn irritating.
I work in building sites and often the only place to charge batteries while I'm at work is in either the site office or the canteen.
A charger that makes a stupid unnecessary noise is likely to be switched off by anyone in that room which should otherwise be fairly quiet.
So, they made a quiet fast charger  [smile]
Then added a noise so irritating that it gets switched off before its charged [blink]
Offline rmhinden
Re: TLC 6 vs SCA 8
« Reply #17 on: May 08, 2021, 12:19 PM »
I don't have the TCL6 or SCA8, just the charger for the CXS drill that doesn't make any noises as far as I have noticed.
I was considering getting the T18 that use these chargers.   Hence my interest in this topic.
Do all of the TLC6 and SCA8 chargers make noises worldwide, or is it somehow only the UK version?    Do the USA versions make noise?
There are a lot of choices these days in cordless drills.    As much as I would like getting another Centrotec drill to leverage my investment in Centrotec bits/adapters, a noisy charger might make me reconsider this.
Bob
Re: TLC 6 vs SCA 8
« Reply #18 on: May 08, 2021, 02:04 PM »
I would be not too concerned about the noise. Yes its loud (SCA 8)/ hearable. But only when the battery is being charged. And is charges pretty fast (most < 45 mins). IMHO not worth looking for other battery platforms.
You can always make a soundproof (or limiting) cabinet  [tongue]
Offline Frank-Jan
Re: TLC 6 vs SCA 8
« Reply #19 on: May 08, 2021, 05:36 PM »
Funnily, I had never noticed the bleeping on the tlc 6 charger, today I used both chargers at the jobsite and found out mine bleeps too. On site I didn't notice the coil whine sound that much, previously I mostly charged the batteries at home. (I got a bunch of batteries with the new tools I got, because of the "get a free 5.2Ah bluetooth battery with every tool" deal.) I don't find the fan of the sca 8 noisy at all, the first generation of the makita li-ion chargers had fans of which the bearings made a lot of noise after a while, now those were noisy. (I mentioned it to a makita rep I met at a store, and he got me free replacement chargers.
« Last Edit: May 08, 2021, 05:43 PM by Frank-Jan »
